Duet 2 Wifi Bltouch isn't working.
Hello people on the internet,
I have a problem with the duet 2 wifi V3.2.2 it has a expansion breakout board V1.1 and a bltouch V3.1.
When I turn on the duet 2 wifi the bltouch does the self test but, when I send the M280 Px S10 code nothing happens. Also the M280 Px S120 code doesn't work. I have changed many things in my config code but nothing seems to make my bltouch work.Also I have a breakout expansion board, and I have the yellow cable of the bltouch connected with Heater7 PWM pin on the breakoutboard, and the red cable of the bltouch connected to the 5V+ of the breakout board, and the brown cable of the bltouch connected on the GND of the breakoutboard.
I have the White cable of the Bltouch connected on the Z_probe_in and the black cable of the bltouch connected on GND of the Z probe.
Here is the config file
; generated by RepRapFirmware Configuration Tool v3.2.3 on Thu Apr 01 2021 12:58:22 GMT+0200 (Midden-Europese zomertijd); General preferences
M550 P"Olga" ; set printer name; Network
M551 P"26627243" ; set password
M552 S1 ; enable network
M586 P0 S1 ; enable HTTP
M586 P1 S0 ; disable FTP
M569 P2 S0 ; physical drive 2 goes forwards
M584 X5 Y6 Z7 E3 ; set drive mapping
M350 X1 Y1 Z1 I0 ; configure microstepping without interpolation
M350 E16 I1 ; configure microstepping with interpolation
M92 X101.85916357881 Y76.87484044 Z77.28312866 E420.00 ; set steps per mm
M566 X30.00 Y30.00 Z2.50 E120.00 ; set maximum instantaneous speed changes (mm/min)
M203 X8000.00 Y8000.00 Z2000.00 E1200.00 ; set maximum speeds (mm/min)
M201 X30.00 Y30.00 Z2.50 E250.00 ; set accelerations (mm/s^2)
M906 X400 Y400 Z400 E800 I70 ; set motor currents (mA) and motor idle factor in per cent
M208 X2400 Y1400 Z950 S0 ; set axis maxima; Endstops
M574 Z1 S2 ; configure Z-probe endstop for low end on Z; Z-Probe
M558 P9 C"^zprobe.in" H5 F100 T2000
M950 S0 C"exp.heater7"
G31 X20 Y0 Z3.3 P25;Heaters
M307 H1 R2.698 C89.1 D4.55 S1.00 V24.0; Fans
M106 P0 S1 H1 T45 ; set fan 0 value. Thermostatic control is turned on
M106 P1 S0 H-1 ; set fan 1 value. Thermostatic control is turned off; Tools
G10 P0 R0 S0
M563 P1 F0
G10 P1 X0 Y0 Z0
G10 P1 R0 S0
; set initial tool 0 active and standby temperatures to 0C
; Custom settings are not defined,
Diagnostics
If somebody has a idea what is wrong or could be wrong please answers.
Thanks in advance -
@fireghost2013 When you use the expansion breakout board, it acts similarly to the Duex5 expansion board. That is, the operation of Heater 7 PWM is inverted. So change your M950 line to:
M950 S0 C"!exp.heater7"
See this thread for a similar setup (and I still need to add a note to the BoB page): https://forum.duet3d.com/topic/22225/bltouch-not-responding-to-code
@droftarts
Thank you, that was the problem, thank you very much you are amazing
