Can't upload to printer
517
  • undefined
    norwestie
    Due to my config.g file disappearing (not blank but gone), I formatted a new 32GB card, copied the files and did a bed level. Then I attempted a print. The upload showed 97% complete then the errors shown below:
    5/28/2021, 2:39:48 PM Error: Failed to write to file, error code 1. Card may be full.
    Error: HTTP: could not write upload data
    Error: Failed to delete file 0:/gcodes/AKLP_power strip bracket.gcode.part
    Error: Failed to create folder 0:/gcodes in path 0:/gcodes/AKLP_power strip bracket.gcode.part
    5/28/2021, 2:39:48 PM Failed to upload AKLP_power strip bracket.gcode
    Operation failed (Reason:
    Your Duet rejected the HTTP request: could not create file
    Anycubic Kossel Linear Plus
    Duet Mini 5+ Ethernet
    Firmware 3.3RC2
    • undefined
      How was the new card formatted?
      This tool is recommended: https://www.sdcard.org/downloads/formatter/
      undefined 1 Reply Last reply 28 May 2021, 23:45 Reply Quote 0
      • undefined
        norwestie @Phaedrux
        @phaedrux
        Formatted in Win10 Fat32
        Firmware 3.3RC2
        • undefined
          Try that formatting tool and try again fresh, but I wonder if it's the SD card socket that is the problem.
          undefined 1 Reply Last reply 29 May 2021, 04:32 Reply Quote 0
          • undefined
            norwestie @Phaedrux
            @phaedrux I have had more problems with this board than anything I can think of. Granted, some are of my own doing but this is a ridiculous way to file a warranty claim, through a public forum. I'm ready to pull it out and go back to the stock Anycubic board. At least it worked.
            Firmware 3.3RC2
            • undefined
              I understand your frustration. The reason for the forum is to assist users in the setup and troubleshooting since more often than not it's not a hardware issue that a warranty replacement would solve. The alternative with other hardware is basically "you're on your own", so at least you've got support here. 😃
              In this case I think it's safe to say that there is an issue with the SD card hardware which we are investigating. If you'd like to start the warranty replacement process please send an email to warranty@duet3d.com and CC your reseller. Include a link to this forum thread and the details of your original purchase. You'll receive a reply with a form to fill out.
              Sorry for the inconvenience. We do stand by the product and will get it sorted for you.
              undefined 1 Reply Last reply 30 May 2021, 16:13 Reply Quote 0
              • undefined
                norwestie @Phaedrux
                @phaedrux I shut off the printer/board and powered back up the next day and it is connected again and looking normal. No change in SD card, just power-cycling
                Firmware 3.3RC2
                undefined 1 Reply Last reply 31 May 2021, 17:34 Reply Quote 0
                • undefined
                  norwestie @norwestie
                  @norwestie But again, can't upload to card and I followed the instructions for formattting a new 16GB card
                  Firmware 3.3RC2
                  undefined 1 Reply Last reply 31 May 2021, 17:44 Reply Quote 0
                  • undefined
                    Phaedrux Moderator @norwestie
                    @norwestie said in Can't upload to printer:
                    That's unfortunate. You will be getting an email regarding your warranty claim shortly.
                    5 out of 9
