    Hypothetical question regarding acceleration and latency
    • 3DPMicro
      3DPMicro last edited by
      Cartesian, Duet 2 Ethernet (or Duet 3), X axis - external driver and servo with S curve acceleration off the Expansion Breakout Board, Y axis - stepper w/ trapezoidal accel. driven by onboard driver.
      Could this scenario cause print issues because of mismatched motion profiles or latency between the two?
      o_lampe 1 Reply Last reply Reply Quote 0
      • o_lampe
        o_lampe @3DPMicro last edited by o_lampe
        @3dpmicro
        IMHO, everytime one motor runs slower than jerk setting, the mismatching ramp-up/down profiles come into play.
        Eg. at the turning point of circles
        //edit It would probably show most, when both motors run below jerk speed?
        3DPMicro 1 Reply Last reply Reply Quote 0
        • 3DPMicro
          3DPMicro @o_lampe last edited by
          @o_lampe thanks for the input. There's also potentially a speed/distance range where the move is in accel/decel for a significant amount of time that might cause issues. Outside of theory I may have to just try and see.
          • o_lampe
            @3dpmicro
            OTOH we are allowed to use different accel and jerk settings for X and Y axes. That alone would cause non-conform motion profiles.
            But I'm not aware of any complaints. Mostly because we set them identical. (and G1 always picks the slowest setting?)
              dc42 administrators @o_lampe last edited by
              @o_lampe said in Hypothetical question regarding acceleration and latency:
              Not so. The actual acceleration and jerk used on X and Y will be in proportion to the movement distances for that move.
              • o_lampe
                o_lampe @dc42 last edited by
                That's clever! So we don't have issues with linear acceleration, but external drivers with 'S' curved accel would be a problem?
                At least when they are mixed with linear acceleration drivers
                  External drivers that have a latency between receiving step pulses and moving to the requested position could cause mismatches in the XY tracking. If both X and U used those drivers and they had equal and constant latency then X and Y would track properly.
