    Duet 2 Wifi TronXY X5SA Z probe setup 2
    149
    • Pyper
      Pyper last edited by
      Re: Duet 2 Wifi Tronxy X5SA Z probe setup
      I was reading the thread above and am hooking up exactly the same probe. I have + and - going to an always on fan plug and the signal going to the Z Probe Signal. I used the code mentioned by pr0xyfl00d3r for config.g:
      M574 Z1 Z2 S2 ; Set endstops controlled by probe
      M558 P5 I1 H5 F120 T6000 A10 R0.5 S0.005 B0 ; Set Z probe type to modulated and the dive height + speeds
      G31 P500 X-35 Y0 Z0.26 ; Set Z probe trigger value, offset and trigger height
      M557 X10:300 Y20:310 S50 ; Define mesh grid
      It is still not homing. The Z moves up a wee bit, then stops.
      What else do I need to check?
      Thank you!
        RRF 2 I assume?
        Do you get any errors in the console?
        Post your full config.g and a photo of the wiring setup?
        Pyper Phaedrux 2 Replies Last reply Reply Quote 0
        • Pyper
          Pyper @Phaedrux last edited by Pyper
          @phaedrux
          The errors I get are:
          G28 Error: in the macro line 15: G30 Z probe 0 not found
          Error: in the macro line 9: G30: Z probe 0 not found
          Error: Homing failed
          Here is my config.g
          ; generated by RepRapFirmware Configuration Tool v3.2.3 on Sat May 29 2021 18:31:29 GMT-0500 (Central Daylight Time)
          M550 P"TronXY X5SA-500-Pro"                        ; set printer name
          M669 K1                                            ; select CoreXY mode
          M569 P0 S1                                         ; physical drive 0 goes forwards
          M569 P1 S1                                         ; physical drive 1 goes forwards
          M569 P2 S1                                         ; physical drive 2 goes forwards
          M569 P3 S1                                         ; physical drive 3 goes forwards
          M584 X0 Y1 Z2 E3                                   ; set drive mapping
          M92 X80.00 Y80.00 Z400.00 E92.60                   ; set steps per mm
          M566 X900.00 Y900.00 Z60.00 E120.00                ; set maximum instantaneous speed changes (mm/min)
          M203 X6000.00 Y6000.00 Z180.00 E1200.00            ; set maximum speeds (mm/min)
          M201 X500.00 Y500.00 Z20.00 E250.00                ; set accelerations (mm/s^2)
          M906 X1200 Y1200 Z1700 E1000 I30                   ; set motor currents (mA) and motor idle factor in per cent
          M208 X500 Y500 Z600 S0                             ; set axis maxima
          M574 X1 S1 P"xstop"                                ; configure active-high endstop for low end on X via pin xstop
          M574 Y1 S1 P"ystop"                                ; configure active-high endstop for low end on Y via pin ystop
          M574 Z2 S2                                         ; configure Z-probe endstop for high end on Z
          M308 S0 P"bedtemp" Y"thermistor" T100000 B4138     ; configure sensor 0 as thermistor on pin bedtemp
          M307 H0 B1 S1.00                                   ; enable bang-bang mode for the bed heater and set PWM limit
          M308 S1 P"e0temp" Y"thermistor" T100000 B4138      ; configure sensor 1 as thermistor on pin e0temp
          M950 F0 C"fan0" Q500                               ; create fan 0 on pin fan0 and set its frequency
          M106 P0 S0 H-1                                     ; set fan 0 value. Thermostatic control is turned off
          M950 F1 C"fan1" Q500                               ; create fan 1 on pin fan1 and set its frequency
          M106 P1 S1 H1 T45                                  ; set fan 1 value. Thermostatic control is turned on
          M575 P1 S1 B57600                                  ; enable support for PanelDue
          I will see if I can get a picture. It isn't pretty (still proto-wiring)
          Phaedrux droftarts 3 Replies Last reply Reply Quote 0
            Phaedrux Moderator @Pyper last edited by
            @pyper said in Duet 2 Wifi TronXY X5SA Z probe setup 2:
            Post your homing files. That seems to be where the problem is.
            Pyper 1 Reply Last reply Reply Quote 0
            • Pyper
              @phaedrux
              Home All:
              ; homeall.g
              ; called to home all axes
              ; generated by RepRapFirmware Configuration Tool v3.2.3 on Sat May 29 2021 18:31:30 GMT-0500 (Central Daylight Time)
              G1 H2 Z5 F6000          ; lift Z relative to current position
              G1 H1 X-505 Y-505 F1800 ; move quickly to X or Y endstop and stop there (first pass)
              G1 H1 X-505             ; home X axis
              G1 H1 Y-505             ; home Y axis
              G1 X5 Y5 F6000          ; go back a few mm
              G1 H1 X-505 F360        ; move slowly to X axis endstop once more (second pass)
              G1 H1 Y-505             ; then move slowly to Y axis endstop
              G1 X15 Y15 F6000        ; go to first bed probe point and home Z
              G30                     ; home Z by probing the bed
              ;G91                    ; relative positioning
              ;G1 Z5 F100             ; lift Z relative to current position
              ;G90                    ; absolute positioning
              HomeX.G
              ; homex.g
              ; called to home the X axis
              G1 H1 X-505 F1800 ; move quickly to X axis endstop and stop there (first pass)
              G1 X5 F6000       ; go back a few mm
              G1 H2 Z-5 F6000   ; lower Z again
              HomeY.G
              ; homey.g
              ; called to home the Y axis
              G1 H1 Y-505 F1800 ; move quickly to Y axis endstop and stop there (first pass)
              G1 Y5 F6000       ; go back a few mm
              G1 H1 Y-505 F360  ; move slowly to Y axis endstop once more (second pass)
              HomeZ.G
              ; homez.g
              ; called to home the Z axis
              G1 X15 Y15 F6000 ; go to first probe point
                Phaedrux Moderator @Phaedrux last edited by
                @phaedrux said in Duet 2 Wifi TronXY X5SA Z probe setup 2:
                RRF 2 I assume?
                Can you send M122 and post the results? Your config has a mix of RRF2 and RRF3 syntax. Which firmware version are you actually running?
                • droftarts
                  droftarts Moderator @Pyper last edited by
                  @pyper as @Phaedrux said, your probe config is for RRF 2, while the rest is for RRF 3. As it’s the probe that’s not working, I’m going to assume you are running RRF3.
                  In your config.g, delete this line, it is incorrect, and using the probe for Z endstop is already defined a couple of lines earlier:
                  This line is also wrong for RRF3:
                  You need to define the pin the probe is connected to. You also have ‘I1’ set, which inverts the probe signal in RRF2, but not in RRF3. Try:
                  M558 P5 C"!^zprobe.in" H5 F120 T6000 A10 R0.5 S0.005 B0
                  The ! character inverts the signal, and the ^ character activates the pull up resistor, which should help prevent spurious readings. You may need to add/remove one or both of these if the probe reading goes the wrong way; check in DWC dashboard for Z-probe reading, should be 0 when not triggered, and 1000 when triggered.
                  FYI NPN probe wiring is described here: https://duet3d.dozuki.com/Wiki/Connecting_a_Z_probe#Section_NPN_output_normally_open_inductive_or_capacitive_sensor
                  • Pyper
                    @phaedrux
                    Here is everything but the network info:
                    M122
                    RepRapFirmware for Duet 2 WiFi/Ethernet version 3.2.2 running on Duet WiFi 1.02 or later
                    Board ID: 08DJM-9178L-L2MS8-6JKF0-3SN6Q-TTFYR
                    Used output buffers: 3 of 24 (12 max)
                    Static ram: 23460
                    Dynamic ram: 73124 of which 24 recycled
                    Never used RAM 15472, free system stack 193 words
                    Tasks: NETWORK(ready,180) HEAT(blocked,310) MAIN(running,451) IDLE(ready,20)
                    Owned mutexes:
                    Last reset 00:00:47 ago, cause: power up
                    Last software reset at 2021-05-31 18:23, reason: User, GCodes spinning, available RAM 15320, slot 0
                    Error status: 0x00
                    Aux0 errors 0,0,0
                    MCU temperature: min 25.3, current 29.4, max 29.6
                    Supply voltage: min 24.1, current 24.2, max 24.3, under voltage events: 0, over voltage events: 0, power good: yes
                    Driver 0: position 0, standstill, SG min/max not available
                    Driver 1: position 0, standstill, SG min/max not available
                    Driver 2: position 0, standstill, SG min/max not available
                    Driver 5: position 0
                    Driver 6: position 0
                    Driver 7: position 0
                    Driver 8: position 0
                    Driver 9: position 0
                    Driver 10: position 0
                    Driver 11: position 0
                    Date/time: 2021-06-02 13:56:58
                    Cache data hit count 56058210
                    Slowest loop: 4.05ms; fastest: 0.21ms
                    === Storage ===
                    Free file entries: 10
                    SD card longest read time 1.0ms, write time 0.0ms, max retries 0
                    === MainDDARing ===
                    === AuxDDARing ===
                    Segments left: 0
                    Movement lock held by null
                    HTTP is idle in state(s) 0
                    Telnet is idle in state(s) 0
                    File is idle in state(s) 0
                    USB is idle in state(s) 0
                    Aux is idle in state(s) 0
                    Trigger is idle in state(s) 0
                    Queue is idle in state(s) 0
                    LCD is idle in state(s) 0
                    Daemon is idle in state(s) 0
                    Code queue is empty.
                      So as suspected, you have RRF3 installed. And most of your config is using the RRF3 syntax, however your probe configuration is for RRF2. So try the M558 line given by @droftarts and see how it goes.
                      • Pyper
                        Pyper last edited by Pyper
                        @droftarts
                        Thank you
                        I made the changes but the movements are still the same.
                        If I manually hit my endstops, I can see the X and Y light up on the Duet and the Z-Probe goes to 1000 on the dashboard and Panel Due when I hold a piece of metal under it.
                        Perhaps my wiring is wrong? Or does it remember where the print head is (manually hitting the endstops switch = bad idea)?
                        On my motors I have a black/green/red/blue wire. I flip red and blue before plugging into the Duet, correct? The Duet shows black/green/blue/red. But I can hit 10mm X or Y and it does move correctly.
                          Are you still getting these errors?
                          Can you post your config.g now that you've made changed?
                          If you send M98 P"config.g" what errors does it report if any?
                          Use M119 to get the status of the endstops. When unpressed they should report untriggered. When depressed they should report as triggered.
                          • Pyper
                            I am getting no errors.
                            I think the Z motors are homing in the wrong direction.
                            If I use M564 S0 H0 I can hit Z+ in the dashboard and it does in fact move up correctly. But when I home, it goes down. Should I remove that '!' in the line droftarts posted?
                            Here is my current config.g:
                            M558 P5 C"!^zprobe.in" H5 F120 T6000 A10 R0.5 S0.005 B0  		; Set Z probe type to modulated and the dive height + speeds
                            Lord have mercy I think my end stops are reversed...! I can move the print head until it touches the X and Y endstops (I see the lights on the Duet), but when I run M119 like you said, I get "M119
                            Endstops - X: not stopped, Y: not stopped, Z: not stopped, Z probe: not stopped". If I move the print head off the end stops (no endstop lights are lit), I get "M119
                            Endstops - X: at min stop, Y: at min stop, Z: not stopped, Z probe: not stopped"
                            Phaedrux droftarts 4 Replies Last reply Reply Quote 0
                              I'm confused. Or maybe you're confused.
                              Z+ should move the bed and nozzle farther apart.
                              Z- should move them closer together.
                              If you need to change the direction of the Z motors use the M569 S to change direction right at the driver settings.
                              • droftarts
                                droftarts Moderator @Pyper last edited by droftarts
                                @pyper moving the bed in a positive direction should increase the distance between the nozzle and bed, so move the bed down, and a negative move reduces the distance between bad and nozzle, so the bed goes up. So sounds like your Z motors are going the wrong way. You can flip the direction by changing the S parameter in the M569 command that relates to the Z axis in config.g.
                                The comments in the commands are, unfortunately, a little confusing, as they assume the machine is a Prusa-style bed slinger, where the X axis is mounted on the Z, so the nozzle moves ‘up’ with positive Z move.
                                Edit: ninja’d (again) by @Phaedrux !
                                • Pyper
                                  @phaedrux
                                  Perhaps I am confused. I assumed Z+ moved the bed UP and Z- moved the bed DOWN.. for a CoreXY?
                                    In that case you invert the signal by adding a ! to the pin name.
                                    ex: M574 X1 S1 P"xstop" becomes M574 X1 S1 P"!xstop"
                                      @phaedrux
                                      No. Think of it as the distance between the bed and nozzle becoming larger or smaller.
                                      • Pyper
                                        @phaedrux
                                        Ok, after reversing the Z motor and the endstops, it homed on all axis!
                                        Thank you so much, I'm sure everyone is thinking "how does this guy drive a car?" haha
                                        Onward!
                                        • droftarts
                                          @pyper the micro switches used as endstops on my TronXY X5S were wired NO (normally open); wires connected to the centre pin and the common pin (one of the outer pins) on the micro switch. I expect your X5SA is the same. We recommend wiring micro switch endstops as NC (normally closed) as it reduces false triggering. To do this, simply move the wire connected to the centre pin to the other outside pin (there are only three pins). You also then don’t need to invert the endstop signal with the ! character. I have done this on my machine See https://duet3d.dozuki.com/Wiki/Connecting_endstop_switches#Section_Microswitch
                                          • Pyper
                                            Pyper @droftarts last edited by
                                            @droftarts
                                            Ian,
                                            I checked my switches and the outer pin does nothing that I can see. I used a multi meter and checked continuity on the outer-outer and inner-outer for that pin, and it never had any continuity for any switch setting. Should I get new end stop switches?
                                            • droftarts
                                              @pyper The pins should be labelled C (Common), NO (normally open, centre pin) and NC (normally closed). You should have continuity between NC and C when switch is not depressed, and continuity between NO and C when not depressed. There is no continuity between NO and NC. If you don't have continuity between NC and C, then possibly it's just a really cheap switch packaged as a microswitch!
                                              It's usually not too much of a problem having the microswitches wired NO, but the voltage is floating, so any interference (eg from high voltage such as heater wires or stepper motor wires) can possibly trigger the endstop. This doesn't happen when wired NC.
                                              Here's mine, wire NC, pin labels just about visible:
                                              • Pyper
                                                @droftarts
                                                Ahh, I see you wired up directly to the switch.
                                                I was probing through the 3-wire jack. I guess they didn't even run traces for NC.
