    Duet3/PI issue - DCS is not started
    • toy4x4
      toy4x4 last edited by
      My Raspberry Pi 4 Model B no longer sees the Duet3 board via the 26 pin ribbon cable.
      In a nutshell, I do not see 3.3v on pin 22 to signal the PI. I did all the troubleshooting via the below thread and had the same results at all steps. This includes the v3.2.2 firmware via m115 and the voltage measurement checks. I tried multiple 26 wire ribbon cables, 2 raspberry PI 4B and multiple new SD card images.
      It worked fine through 3 Benchy prints and when I cycled the power before the 4th, I got the DCS is not started error.
      Let me know what info you would like. I have the Duet3 connected via USB and YAT.
      Thanks!
      https://forum.duet3d.com/topic/21640/duet3-dcs-is-not-started
      toy4x4 1 Reply Last reply Reply Quote 0
      • toy4x4
        toy4x4 @toy4x4 last edited by
        I have the Duet3 running in stand alone mode. Info:
        M115 from YAT:
        Back to SBC Mode and info:
        sudo journalctl -u duetcontrolserver -ef
        gpioget gpiochip0 25
        config.g
        ; generated by RepRapFirmware Configuration Tool v3.2.3 on Fri May 21 2021 17:05:16 GMT-0500 (Central Daylight Time)
        G90                                          ; send absolute coordinates...
        M83                                          ; ...but relative extruder moves
        M550 P"Monstrosity"                          ; set printer name
        M669 K1                                      ; select CoreXY mode
        M569 P0.0 S0                                 ; physical drive 0.0 goes backwards
        M569 P0.1 S0                                 ; physical drive 0.1 goes backwards
        M569 P0.3 S0                                 ; physical drive 0.3 goes forwards
        M569 P0.4 S0                                 ; physical drive 0.2 goes forwards
        M569 P0.2 S1                                 ; physical drive 0.2 goes forwards
        M584 X0.0 Y0.1 Z0.3:0.4 E0.2                     ; set drive mapping
        M350 X16 Y16 Z16 E16 I1                      ; configure microstepping with interpolation
        M92 X160.00 Y160.00 Z1600.00 E404.62            ; set steps per mm
        M566 X900.00 Y900.00 Z60.00 E120.00          ; set maximum instantaneous speed changes (mm/min)
        M203 X6000.00 Y6000.00 Z600.00 E1200.00           ; set maximum speeds (mm/min)
        M201 X500.00 Y500.00 Z120.00 E250.00          ; set accelerations (mm/s^2)
        M906 X800 Y800 Z800 E800 I30                 ; set motor currents (mA) and motor idle factor in per cent
        M84 S30                                      ; Set idle timeout
        ;Dual Z
        M671 X-140:140 Y15:15  ; leadscrews at left (connected to Z) and right (connected to E1) of X axis
        M208 X-130 Y-155 Z0 S1                             ; set axis minima
        M208 X130 Y155 Z400 S0                       ; set axis maxima
        M574 X1 S1 P"io1.in"                         ; configure active-high endstop for low end on X via pin io0.in
        M574 Y1 S1 P"io2.in"                         ; configure active-high endstop for low end on Y via pin io1.in
        M574 Z0                                   ; configure Z-probe endstop for low end on Z
        M950 S0 C"io7.out"                           ; create servo pin 0 for BLTouch
        M558 P9 C"^io7.in" H5 F120 T6000             ; set Z probe type to bltouch and the dive height + speeds
        m558 A10 R1 S0.006                           ; Additional Mesh requirements
        G31 P500 X17.75 Y38.1 Z.995                ; set Z probe trigger value, offset and trigger height
        M557 X-100:130 Y-100:155 P2                     ; define mesh grid
        M308 S0 P"temp0" Y"thermistor" T100000 B4138 ; configure sensor 0 as thermistor on pin temp0
        M950 H0 C"out0" T0                           ; create bed heater output on out0 and map it to sensor 0
        ;M307 H0 B0 S1.00                             ; disable bang-bang mode for the bed heater and set PWM limit
        M307 H0 R0.884 C317.6 D3.43 S1.00 V24.2
        M140 H0                                      ; map heated bed to heater 0
        M143 H0 S120                                 ; set temperature limit for heater 0 to 120C
        M308 S1 P"temp1" Y"thermistor" T100000 B4138 ; configure sensor 1 as thermistor on pin temp1
        M950 H1 C"out1" T1                           ; create nozzle heater output on out1 and map it to sensor 1
        M307 H1 R2.275 C244.1 D5.68 S1.00 V24.2      ; disable bang-bang mode for heater  and set PWM limit
        M143 H1 S280                                 ; set temperature limit for heater 1 to 280C
        M950 F1 C"out4" Q500                         ; create fan 0 on pin out4 and set its frequency
        M106 P1 C"HotHead" S0 H1 T45
        ;M106 P0 C"HotHead" S0 H-1                               ; set fan 0 value. Thermostatic control is turned off
        M950 F0 C"out5" Q500                         ; create fan 1 on pin out5 and set its frequency
        ;M106 P1 C"Print Cooler" S1 H1 T35                            ; set fan 1 value. Thermostatic control is turned on
        M106 P0 C"Print Cooler" S0 H-1
        M563 P0 D0 H1 F0                             ; define tool 0
        G10 P0 X0 Y0 Z0                              ; set tool 0 axis offsets
        G10 P0 R0 S0                                 ; set initial tool 0 active and standby temperatures to 0C
        M575 P1 S1 B57600                            ; enable support for PanelDue
        T0 ; Sets Tool0 as default
          Thanks, taking a look to see if there is anything else we'd like you to try.
          • T3P3Tony
            T3P3Tony administrators @Phaedrux last edited by
            @toy4x4 please email email warranty@duet3d.com and cc the reseller that you purchased from. You will receive a reply with a link to a form to fill in within 24h.
            www.duet3d.com
