Extruder motor doesn't move
@phaedrux Before I change anything today, the xyz homing all went fine... I don't know why. But the issue of extrude/retract not active still the same.
@phaedrux ; Configuration file for Duet WiFi (firmware version 3)
; generated by RepRapFirmware Configuration Tool v3.2.3 on Thu Jun 10 2021 17:46:43 GMT-0400 (Eastern Daylight Time); General preferences
M550 P"My Printer" ; set printer name; Network
M552 S1 ; enable network
M586 P0 S1 ; enable HTTP
M586 P1 S0 ; disable FTP
M569 P0 S0 ; physical drive 0 goes backwards
M92 X80.00 Y80.00 Z400.00 E420.00 ; set steps per mm
M566 X900.00 Y900.00 Z60.00 E120.00 ; set maximum instantaneous speed changes (mm/min)
M203 X6000.00 Y6000.00 Z180.00 E1200.00 ; set maximum speeds (mm/min)
M906 X800 Y800 Z800 E800 I30 ; set motor currents (mA) and motor idle factor in per cent
M208 X230 Y210 Z200 S0 ; set axis maxima; Endstops
M574 X1 S1 P"!xstop" ; configure active-high endstop for low end on X via pin !xstop
M574 Y1 S1 P"!ystop" ; configure active-high endstop for low end on Y via pin !ystop
M574 Z1 S1 P"!zstop" ; configure active-high endstop for low end on Z via pin !zstop; Z-Probe
M558 P0 H5 F120 T6000 ; disable Z probe but set dive height, probe speed and travel speed
M557 X15:215 Y15:195 S20 ; define mesh grid; Heaters
M143 H1 S280 ; set temperature limit for heater 1 to 280C; Fans
M106 P1 S1 H1 T45 ; set fan 1 value. Thermostatic control is turned on; Tools
@phaedrux Another question I have is: what is the unit of the numbers in the machine movement control? Is it mm?
Yes that is movement in millimeters.
Add this
T0
M302 P1 ; Allow cold extrusion
to the end of your config.g and see if you're able to activate the extruder then.
If that doesn't work, Since this is a tool that will be using an external heater controller you could follow the advice in the cold extrusion wiki entry to define the tool without a heater associated at all.
https://duet3d.dozuki.com/Wiki/Gcode#Section_M302_Allow_cold_extrudes
Note: One limitation of M302 is that it requires a thermistor to be present for the temperature to be monitored. If your system does not have a thermistor or heater to be monitored, you can define your tool in M563 without a heater to disable cold extrusion protection on that tool. ex: M563 P0 S"Pump" D0 F0 Note the lack of H parameter.
So in your case
; Tools M563 P0 D0 H1 F0 ; define tool 0
You would remove the H1 entirely.
@phaedrux I want to send the temperature signal from PID to the Duet board, do I need adapters to do it? I saw online there's some kind of daughter board for thermocouple. I'm using Duet 2 ethernet, which daughter board should I purchase?
Can you give more info on your external temperature controller?
@phaedrux It's a very common Inkbird PID controller. The thermocouple from the extruder head is a K-type thermocouple.
If the thermocouple is already going to the PID controller how do you hope to connect it to the Duet as well?
Do you have a link for that unit?
@phaedrux I plan to use a dual thermocouple connector to split the thermocouple signal, so that one goes to the PID and the other goes to the Duet board.
Ok, yes if you've got a dual thermocouple with two junctions with their own wires then yes, you could run one to the controller and one to the Duet. You would need the Duet Thermocouple Daughterboard to be able to read the temp.
https://duet3d.dozuki.com/Wiki/Thermocouple_daughter_board
https://duet3d.dozuki.com/Wiki/Connecting_thermocouples -
Hi, now the temperature is all set, but I have some problems with the extruder motor. I used the expansion portion (highlighted in the red square shown below) of the board for extruder signals. The channels I connected are E2, but I couldn't setup the config file to use the E2 motor because it isn't listed.
You'll need to alter the config manually to add non-standard mappings.
@phaedrux Could you please explain how to do that?
If you're using E2 that equates to driver 5 on the duex.
So in your M584 command, For the extruder drives you would list all the extruder that will be connected to the main Duet drivers and then add 5 for the expansion header.
M584 X0 Y1 Z2:3 E4:5
just as an example.Have you seen this yet? https://duet3d.dozuki.com/Wiki/Using_external_stepper_motor_drivers
@phaedrux Hi, my extruder motor needs 5V, while the Duet board output is 3.3V, I'm thinking of buying a breakout board like this:
https://duet3d.dozuki.com/Wiki/Duet_Expansion_Breakout_Board
Will it work? -
@zfeng said in Extruder motor doesn't move:
I'm not sure what you mean by this. The stepper motor drivers are constant current drivers. The rated voltage on the motor isn't a requirement.
@phaedrux I'm not using motor drive output, I'm using the expansion portion of the board, which is 3.3V output. But my extruder motor needs 5V.
@phaedrux Since I'll use the E2 of the expansion to wire my extruder motor, how to modify the config code to use the E2? I won't use the E0 and E1.
My config.g Driver code is below:
M584 X0 Y1 Z2 ; set drive mapping
M350 X16 Y16 Z16 I1 ; configure microstepping with interpolation
M92 X80.00 Y80.00 Z400.00 ; set steps per mm
M566 X900.00 Y900.00 Z60.00 ; set maximum instantaneous speed changes (mm/min)
M203 X6000.00 Y6000.00 Z180.00 ; set maximum speeds (mm/min)
M201 X500.00 Y500.00 Z20.00 ; set accelerations (mm/s^2)
M906 X800 Y800 Z800 I30 ; set motor currents (mA) and motor idle factor in per cent
M84 S30 ; Set idle timeout -
I already answered that I think.
@phaedrux said in Extruder motor doesn't move:
Do you mean your external driver needs 5v?
