Extruder motor doesn't move
@phaedrux ; Configuration file for Duet WiFi (firmware version 2.03)
; generated by RepRapFirmware Configuration Tool v3.2.3 on Wed Jun 09 2021 17:54:24 GMT-0400 (Eastern Daylight Time); General preferences
M550 P"My Printer" ; set printer name; Network
M552 S1 ; enable network
M586 P0 S1 ; enable HTTP
M586 P1 S0 ; disable FTP
M569 P0 S0 ; physical drive 0 goes backwards
M92 X80.00 Y80.00 Z400.00 E420.00 ; set steps per mm
M566 X900.00 Y900.00 Z60.00 E120.00 ; set maximum instantaneous speed changes (mm/min)
M203 X6000.00 Y6000.00 Z180.00 E1200.00 ; set maximum speeds (mm/min)
M906 X800 Y800 Z800 E800 I30 ; set motor currents (mA) and motor idle factor in per cent
M208 X230 Y210 Z200 S0 ; set axis maxima; Endstops
M574 X1 Y1 Z1 S0 ; set active low and disabled endstops; Z-Probe
M558 P0 H5 F120 T6000 ; disable Z probe but set dive height, probe speed and travel speed
M557 X15:215 Y15:195 S20 ; define mesh grid; Heaters
M305 P0 T100000 B4138 R4700 ; set thermistor + ADC parameters for heater 0
M305 P1 T100000 B4138 R4700 ; set thermistor + ADC parameters for heater 1
M143 H1 S280 ; set temperature limit for heater 1 to 280C; Fans
M106 P0 S0 I0 F500 H-1 ; set fan 0 value, PWM signal inversion and frequency. Thermostatic control is turned off
M106 P1 S1 I0 F500 H1 T45 ; set fan 1 value, PWM signal inversion and frequency. Thermostatic control is turned on; Tools
Your config is still the same as before for RRF2. You'll need to redo it for RRF3.
I suggest trying to generate a fresh one with the config tool using what you have from your current config to inform you. That will give you the correct syntax at least and can tweak from there.
https://configtool.reprapfirmware.org/Start
Also use M115 to verify that the firmware is actually update now.
@phaedrux Sorry pasted the wrong one.
; generated by RepRapFirmware Configuration Tool v3.2.3 on Wed Jun 09 2021 18:36:12 GMT-0400 (Eastern Daylight Time); General preferences
M574 X1 S1 P"!xstop" ; configure active-high endstop for low end on X via pin !xstop
M574 Y1 S1 P"!ystop" ; configure active-high endstop for low end on Y via pin !ystop
M574 Z1 S1 P"!zstop" ; configure active-high endstop for low end on Z via pin !zstop; Z-Probe
M106 P1 S1 H1 T45 ; set fan 1 value. Thermostatic control is turned on; Tools
@zfeng I used M115 and verified it's updated.
@zfeng said in Extruder motor doesn't move:
M574 Z1 S1 P"!zstop" ; configure active-high endstop for low end on Z via pin !zstopDoes this work now, or not?
@phaedrux Using the config file I posted, it doesn't work.
What are the endstops?
What error do you get exactly when trying to home?
What is in your homing files now?
@phaedrux After I click Home X or Y or Z, the system would move down a little bit, then stop, not moving in the homing direction at all.
@phaedrux G28 X, failed to enable endstops.
This is the type of endstop I'm using. It worked before I upgrading the firmware.
@phaedrux ; homex.g
; called to home the X axis
G91 ; relative positioning
G1 H1 X-235 F1800 ; move quickly to X axis endstop and stop there (first pass)
G1 H2 X5 F6000 ; go back a few mm
G1 H1 X-235 F360 ; move slowly to X axis endstop once more (second pass)
G1 H2 Z-5 F6000 ; lower Z again
G90 ; absolute positioning -
And if you click the switch does it change the LED at the board?
@phaedrux Yes clicking switch changes LED light on the board.
Can you remove the H2 from that line and test again? Does it still move slightly?
If you send M119 what does it report for the status of the endstops? Does it change when the endstop is depressed?
Can you try removing the
from the pin name and doing the same tests? -
@phaedrux Before I change anything today, the xyz homing all went fine... I don't know why. But the issue of extrude/retract not active still the same.
@phaedrux ; Configuration file for Duet WiFi (firmware version 3)
; generated by RepRapFirmware Configuration Tool v3.2.3 on Thu Jun 10 2021 17:46:43 GMT-0400 (Eastern Daylight Time); General preferences
@phaedrux Another question I have is: what is the unit of the numbers in the machine movement control? Is it mm?
Yes that is movement in millimeters.
Add this
T0
M302 P1 ; Allow cold extrusion
to the end of your config.g and see if you're able to activate the extruder then.
If that doesn't work, Since this is a tool that will be using an external heater controller you could follow the advice in the cold extrusion wiki entry to define the tool without a heater associated at all.
https://duet3d.dozuki.com/Wiki/Gcode#Section_M302_Allow_cold_extrudes
Note: One limitation of M302 is that it requires a thermistor to be present for the temperature to be monitored. If your system does not have a thermistor or heater to be monitored, you can define your tool in M563 without a heater to disable cold extrusion protection on that tool. ex: M563 P0 S"Pump" D0 F0 Note the lack of H parameter.
So in your case
; Tools M563 P0 D0 H1 F0 ; define tool 0
You would remove the H1 entirely.
@phaedrux I want to send the temperature signal from PID to the Duet board, do I need adapters to do it? I saw online there's some kind of daughter board for thermocouple. I'm using Duet 2 ethernet, which daughter board should I purchase?
Can you give more info on your external temperature controller?
