    Extruder motor doesn't move
    2.1k
      RepRapFirmware 2 last version was 2.05.1 released over a year ago and no longer updated.
      RepRapFirmware 3 is currently at version 3.2.2 and is actively being developed.
      https://duet3d.dozuki.com/Wiki/RepRapFirmware_3_overview
      zfengundefined 1 Reply Last reply Reply Quote 0
      • zfengundefined
        zfeng @Phaedrux
        @phaedrux How can I upgrade my board to RRF3?
          If you still have access to DWC. Upload these 3 zip files, one at a time in the system tab. Don't extract them. Reboot after each. Use M115 to verify the firmware has been applied.
          https://github.com/Duet3D/RepRapFirmware/releases/download/3.0/Duet2and3Firmware-3.0.zip
          https://github.com/Duet3D/RepRapFirmware/releases/download/3.2.2/Duet2and3Firmware-3.2.2.zip
          That will get your firmware and DWC up to date.
          You can see the change logs here:
          https://github.com/Duet3D/RepRapFirmware/wiki/Changelog-RRF-3.x
          For your config, might be a good idea to run through the configurator tool and generate a fresh set for RRF3.
          https://configtool.reprapfirmware.org/Start
          Backup your existing config files in the sys folder in case you want to switch back to RRF3. IT’s easy to switch back and forth, just upload the zip file for the version you want and then upload your config files.
          These documents will come in handy during the conversion.
          https://duet3d.dozuki.com/Wiki/Gcode
          • Dougal1957undefined
            Dougal1957
            I also see from your Config that you are setting T1 as active but you only have T0 defined.
            Maybe @droftarts or @Phaedrux can just confirm they are far more expert than I am!
              Phaedrux Moderator @Dougal1957
              @dougal1957 Almost. He is calling T1 at the end, but the tool he has defined is also T1. And the tool being defined doesn't have a heater assigned. I don't think that those things in themselves would cause a problem, but it's been a long time since I've used RRF2.
              Updating to RRF3 and using a cleaned up config.g might do wonders either way.
              • zfengundefined
                zfeng @Phaedrux
                @phaedrux I upgraded the firmware, but now I seem to have problem with the endstops. The settings for my endstops type before upgrading were all "active-low", and endstop location all at low-end. But after upgrading, the active-low button disappeared and I selected switch instead, but after updating the new config file, I could not homing any axis due to the G28X failed to enable endstops error.
                  Post your new config.g please.
                  I suspect that you'll just need to invert the signal by adding a ! to the pin name.
                  M574 X1 S1 P"!xstop"
                  • zfengundefined
                    zfeng @Phaedrux
                    @phaedrux ; Configuration file for Duet WiFi (firmware version 2.03)
                    ; generated by RepRapFirmware Configuration Tool v3.2.3 on Wed Jun 09 2021 17:54:24 GMT-0400 (Eastern Daylight Time)
                    M550 P"My Printer" ; set printer name
                    M552 S1 ; enable network
                    M586 P0 S1 ; enable HTTP
                    M586 P1 S0 ; disable FTP
                    M586 P2 S0 ; disable Telnet
                    M569 P0 S0 ; physical drive 0 goes backwards
                    M569 P2 S0 ; physical drive 2 goes backwards
                    M92 X80.00 Y80.00 Z400.00 E420.00 ; set steps per mm
                    M84 S30 ; Set idle timeout
                    M208 X230 Y210 Z200 S0 ; set axis maxima
                    M574 X1 Y1 Z1 S0 ; set active low and disabled endstops
                    M558 P0 H5 F120 T6000 ; disable Z probe but set dive height, probe speed and travel speed
                      Your config is still the same as before for RRF2. You'll need to redo it for RRF3.
                      I suggest trying to generate a fresh one with the config tool using what you have from your current config to inform you. That will give you the correct syntax at least and can tweak from there.
                      Also use M115 to verify that the firmware is actually update now.
                      • zfengundefined
                        zfeng @Phaedrux
                        @phaedrux Sorry pasted the wrong one.
                        ; generated by RepRapFirmware Configuration Tool v3.2.3 on Wed Jun 09 2021 18:36:12 GMT-0400 (Eastern Daylight Time)
                        M574 X1 S1 P"!xstop" ; configure active-high endstop for low end on X via pin !xstop
                        M574 Y1 S1 P"!ystop" ; configure active-high endstop for low end on Y via pin !ystop
                        M574 Z1 S1 P"!zstop" ; configure active-high endstop for low end on Z via pin !zstop
                        zfengundefined Phaedruxundefined 2 Replies Last reply Reply Quote 0
                        • zfengundefined
                          zfeng @zfeng
                          @zfeng I used M115 and verified it's updated.
                            Phaedrux Moderator @zfeng
                            @zfeng said in Extruder motor doesn't move:
                            Does this work now, or not?
                            zfengundefined 2 Replies Last reply Reply Quote 0
                            • zfengundefined
                              zfeng @Phaedrux
                              @phaedrux Using the config file I posted, it doesn't work.
                                What are the endstops?
                                What error do you get exactly when trying to home?
                                What is in your homing files now?
                                • zfengundefined
                                  zfeng @Phaedrux
                                  @phaedrux After I click Home X or Y or Z, the system would move down a little bit, then stop, not moving in the homing direction at all.
                                  • zfengundefined
                                    zfeng @Phaedrux
                                    @phaedrux G28 X, failed to enable endstops.
                                    This is the type of endstop I'm using. It worked before I upgrading the firmware.
                                    • zfengundefined
                                      zfeng @Phaedrux
                                      @phaedrux ; homex.g
                                      ; called to home the X axis
                                      G91 ; relative positioning
                                      G1 H1 X-235 F1800 ; move quickly to X axis endstop and stop there (first pass)
                                      G1 H2 X5 F6000 ; go back a few mm
                                      G1 H1 X-235 F360 ; move slowly to X axis endstop once more (second pass)
                                      G1 H2 Z-5 F6000 ; lower Z again
                                      G90 ; absolute positioning
                                        And if you click the switch does it change the LED at the board?
                                        • zfengundefined
                                          zfeng @Phaedrux
                                          @phaedrux Yes clicking switch changes LED light on the board.
                                            Can you remove the H2 from that line and test again? Does it still move slightly?
                                            If you send M119 what does it report for the status of the endstops? Does it change when the endstop is depressed?
                                            Can you try removing the ! from the pin name and doing the same tests?
                                            zfengundefined 3 Replies Last reply Reply Quote 0
