    Duet 3 restarts during printing
    70
    • RedFlash
      RedFlash last edited by RedFlash
      Hi.
      My HevORT with a Duet 3 board restarts after a couple minutes printing.
      The board had the firmware 3.3rc3, a toolboard and an accelerometer installed when the error appears the first time. I completely erase and reinstalled 3.2.2, changed the SD card and disconnected the toolboard and the LIS3DH.
      It still appears.
      M 122
      RepRapFirmware for Duet 3 MB6HC version 3.2.2 running on Duet 3 MB6HC v0.6 or 1.0 (standalone mode)
      Board ID: 08DJM-956BA-NA3TJ-6J1FG-3S86S-TU9YS
      Used output buffers: 1 of 40 (20 max)
      Static ram: 149788
      Dynamic ram: 93284 of which 44 recycled
      Never used RAM 115716, free system stack 188 words
      Tasks: NETWORK(ready,195) ETHERNET(blocked,103) HEAT(blocked,278) CanReceiv(blocked,927) CanSender(blocked,371) CanClock(blocked,351) TMC(blocked,50) MAIN(running,1117) IDLE(ready,19)
      Owned mutexes:
      Last reset 00:47:17 ago, cause: software
      Last software reset at 2021-06-06 15:22, reason: MemoryProtectionFault mmarValid daccViol, GCodes spinning, available RAM 115676, slot 1
      Software reset code 0x4163 HFSR 0x00000000 CFSR 0x00000082 ICSR 0x00427804 BFAR 0x000000cd SP 0x2041fbe0 Task MAIN Freestk 1670 ok
      Stack: 00000000 00000000 00000000 00000000 00000081 00442ab5 004296c6 41030000 00000000 00000001 00000000 0046b1e7 2042b6e4 00000000 00000000 0046b535 00000000 0046b6e9 a5a5a5a5 ffffffff 2042b6e4 2041e168 2042ba7c ffffffff 00000000 00000003 2042ba78
      Error status: 0x00
      Aux0 errors 0,0,0
      Aux1 errors 0,0,0
      MCU temperature: min 39.2, current 39.5, max 40.9
      Supply voltage: min 24.0, current 24.1, max 24.1, under voltage events: 0, over voltage events: 0, power good: yes
      12V rail voltage: min 12.0, current 12.1, max 12.2, under voltage events: 0
      Driver 0: position 0, standstill, reads 3177, writes 15 timeouts 0, SG min/max 0/0
      Driver 1: position 0, standstill, reads 3178, writes 15 timeouts 0, SG min/max 0/0
      Driver 2: position 0, standstill, reads 3178, writes 15 timeouts 0, SG min/max 0/0
      Driver 3: position 0, standstill, reads 3178, writes 15 timeouts 0, SG min/max 0/0
      Driver 4: position 0, standstill, reads 3178, writes 15 timeouts 0, SG min/max 0/0
      Driver 5: position 0, standstill, reads 3178, writes 15 timeouts 0, SG min/max 0/0
      Date/time: 2021-06-06 16:10:09
      Slowest loop: 5.86ms; fastest: 0.05ms
      === Storage ===
      Free file entries: 10
      SD card 0 detected, interface speed: 25.0MBytes/sec
      SD card longest read time 1.3ms, write time 0.0ms, max retries 0
      === MainDDARing ===
      === AuxDDARing ===
      Heater 1 is on, I-accum = 0.0
      Segments left: 0
      Movement lock held by null
      HTTP is idle in state(s) 0
      Telnet is idle in state(s) 0
      File is idle in state(s) 0
      USB is idle in state(s) 0
      Aux is idle in state(s) 0
      Trigger is idle in state(s) 0
      Queue is idle in state(s) 0
      LCD is idle in state(s) 0
      SBC is idle in state(s) 0
      Daemon is idle in state(s) 0
      Aux2 is idle in state(s) 0
      Code queue is empty.
      === Network ===
      Slowest loop: 5.95ms; fastest: 0.02ms
      Responder states: HTTP(0) HTTP(0) HTTP(0) HTTP(0) HTTP(0) HTTP(0) FTP(0) Telnet(0), 0 sessions Telnet(0), 0 sessions
      HTTP sessions: 2 of 8
      • Ethernet -
        State: active
        Error counts: 0 0 1 0 0
        Socket states: 5 2 2 2 2 0 0 0
        === CAN ===
        Messages queued 11344, send timeouts 25528, received 0, lost 0, longest wait 0ms for reply type 0, free buffers 47
      • SIam
        SIam last edited by SIam
        After this happens,
        enter M122 in the console and post the output here
        ok im to fast 😉
        Hypercube-Evolution-Hybrid, Piezo Orion, Orbiter
        Duet WiFi 1.02 or later + DueX5
        RepRapFirmware for Duet 2 WiFi/Ethernet 3.4.0beta4 (2021-09-27 11:30:36)
        Duet WiFi Server: 1.26
        Duet Web Control 3.4.0beta4 (2021-09-27)
        SIam 1 Reply Last reply Reply Quote 0
        • SIam
          SIam @SIam last edited by SIam
          Try to install on all boards (if you have some additional boards) with the latest beta RRF 3.3 rc3
          RedFlash 1 Reply Last reply Reply Quote 0
          • RedFlash
            RedFlash @SIam last edited by
            @siam
            It was installed and i downgraded. All modules were disconnected.
            • SIam
              SIam @RedFlash last edited by
              @redflash This error which is now showing in your log should be fixed with rrf 3.3 rc2 if you have the same error with 3.3 rc 3 please post the result from m122 with the latest firmware
              • RedFlash
                RedFlash @SIam last edited by RedFlash
                @siam
                It was the same with 3.3rc3, but in the log there was „cause:watchdog“.
                I‘ll update again i take a new M122.
                  dc42 administrators @RedFlash last edited by
                  @redflash please install the latest 3.3RC3+ build from https://www.dropbox.com/sh/nmpsl9a3jfsumm5/AAA6adSjEcd1AM_j5_tVberGa?dl=0 and try again. If is still resets, post another M122 report.
                  • RedFlash
                    RedFlash @dc42 last edited by
                    It still resets.
                    6.6.2021, 17:21:15 	M122
                    RepRapFirmware for Duet 3 MB6HC version 3.3RC3 (2021-05-26 12:29:42) running on Duet 3 MB6HC v0.6 or 1.0 (standalone mode)
                    Used output buffers: 10 of 40 (24 max)
                    Static ram: 150784
                    Dynamic ram: 92436 of which 380 recycled
                    Never used RAM 110592, free system stack 192 words
                    Tasks: NETWORK(ready,25.8%,232) ETHERNET(notifyWait,0.1%,117) HEAT(delaying,0.0%,295) Move(notifyWait,0.0%,302) CanReceiv(notifyWait,0.0%,945) CanSender(notifyWait,0.0%,374) CanClock(delaying,0.0%,333) TMC(notifyWait,7.9%,93) MAIN(running,65.5%,924) IDLE(ready,0.6%,29), total 100.0%
                    Owned mutexes:
                    Last reset 00:00:17 ago, cause: watchdog
                    Error status: 0x00
                    Aux0 errors 0,0,0
                    Aux1 errors 0,0,0
                    Step timer max interval 130
                    MCU temperature: min 39.3, current 40.2, max 40.4
                    12V rail voltage: min 12.1, current 12.1, max 12.2, under voltage events: 0
                    Driver 0: position 0, standstill, reads 33139, writes 15 timeouts 0, SG min/max 0/0
                    Driver 1: position 0, standstill, reads 33139, writes 15 timeouts 0, SG min/max 0/0
                    Driver 2: position 0, standstill, reads 33139, writes 15 timeouts 0, SG min/max 0/0
                    Driver 3: position 0, standstill, reads 33139, writes 15 timeouts 0, SG min/max 0/0
                    Driver 4: position 0, standstill, reads 33140, writes 15 timeouts 0, SG min/max 0/0
                    Driver 5: position 0, standstill, reads 33140, writes 15 timeouts 0, SG min/max 0/0
                    Date/time: 2021-06-06 17:21:14
                    Slowest loop: 4.16ms; fastest: 0.05ms
                    === Storage ===
                    SD card longest read time 1.0ms, write time 0.0ms, max retries 0
                    === MainDDARing ===
                    === AuxDDARing ===
                    Segments left: 0
                    === CAN ===
                    Messages queued 157, send timeouts 155, received 0, lost 0, longest wait 0ms for reply type 0, peak Tx sync delay 0, free buffers 49 (min 49), ts 90/0/0
                    Last cancelled message type 30 dest 127
                    === Network ===
                    Slowest loop: 2.33ms; fastest: 0.02ms
                    HTTP sessions: 1 of 8
                    - Ethernet -
                    State: active
                    6.6.2021, 17:16:25 	M32 "0:/gcodes/CFFFP_towel_holder.gcode"
                    File 0:/gcodes/CFFFP_towel_holder.gcode selected for printing
                      @redflash that's not the firmware from the folder that I linked to.
                      RedFlash 2 Replies Last reply Reply Quote 0
                      • RedFlash
                        RedFlash @dc42 last edited by RedFlash
                        Oh man. Didn`t see the +. Hold on..
                        • RedFlash
                          6.6.2021, 17:42:42 	M122
                          RepRapFirmware for Duet 3 MB6HC version 3.3RC3+4 (2021-06-05 16:20:17) running on Duet 3 MB6HC v0.6 or 1.0 (standalone mode)
                          Used output buffers: 1 of 40 (18 max)
                          Static ram: 150896
                          Dynamic ram: 92432 of which 392 recycled
                          Never used RAM 110472, free system stack 216 words
                          Tasks: NETWORK(ready,27.8%,272) ETHERNET(notifyWait,0.1%,117) HEAT(delaying,0.0%,331) Move(notifyWait,0.0%,302) CanReceiv(notifyWait,0.0%,946) CanSender(notifyWait,0.0%,373) CanClock(delaying,0.0%,340) TMC(notifyWait,7.0%,93) MAIN(running,64.4%,924) IDLE(ready,0.6%,29), total 100.0%
                          Owned mutexes:
                          Last reset 00:00:18 ago, cause: software
                          Last software reset at 2021-06-06 17:42, reason: MemoryProtectionFault mmarValid daccViol, GCodes spinning, available RAM 107616, slot 0
                          Software reset code 0x4163 HFSR 0x00000000 CFSR 0x00000082 ICSR 0x00427804 BFAR 0x20028009 SP 0x2041b168 Task MAIN Freestk 1657 ok
                          Stack: 00000000 00000001 00000001 00000000 00000000 0047a427 0047a426 61030000 00000000 0047a427 2042b7e8 00000000 00000000 0047a76f 00000000 20419408 00000000 00000000 198a2d17 a5a5a5a5 a5a5a5a5 2042d834 00000000 00000001 00000000 0047a427 2042d834
                          Error status: 0x00
                          Aux0 errors 0,0,0
                          Step timer max interval 125
                          MCU temperature: min 40.7, current 41.2, max 41.3
                          Driver 0: position 0, standstill, reads 38456, writes 15 timeouts 0, SG min/max 0/0
                          Driver 1: position 0, standstill, reads 38456, writes 15 timeouts 0, SG min/max 0/0
                          Driver 2: position 0, standstill, reads 38456, writes 15 timeouts 0, SG min/max 0/0
                          Driver 3: position 0, standstill, reads 38456, writes 15 timeouts 0, SG min/max 0/0
                          Driver 4: position 0, standstill, reads 38456, writes 15 timeouts 0, SG min/max 0/0
                          Driver 5: position 0, standstill, reads 38457, writes 15 timeouts 0, SG min/max 0/0
                          Date/time: 2021-06-06 17:42:41
                          Slowest loop: 4.01ms; fastest: 0.05ms
                          === Storage ===
                          === MainDDARing ===
                          === AuxDDARing ===
                          Segments left: 0
                          === CAN ===
                          Messages queued 164, send timeouts 162, received 0, lost 0, longest wait 0ms for reply type 0, peak Tx sync delay 0, free buffers 49 (min 49), ts 94/0/0
                          === Network ===
                          Slowest loop: 2.47ms; fastest: 0.02ms
                          - Ethernet -
                          State: active
                          6.6.2021, 17:34:44 	M32 "0:/gcodes/CFFFP_towel_holder.gcode"
                          dc42 2 Replies Last reply Reply Quote 0
                            @redflash thanks, I am looking into it.
                              @redflash I suspect a hardware fault. When did you purchase the Duet 3? For how many weeks or months did the printer work properly?
                              • RedFlash
                                It‘s a Fysetc clone from Ali, 5 month in use.
                                I will throw that crap away and get a real one.
                                Thanks a lot for your help.
