Toolboard Heater Fault
I've found out that if I heat in increments it doesn't fault. If I go directly to 210 it'll fault. It didn't fault if I set it to 80c, wait for it to heat up, set it to 160c, wait to heat up, than set to 210.
@dhusolo said in Toolboard Heater Fault:
M307 H1 B0 R2.824 C282.4:110.0 D9.82 S1.00 V25.7
From those parameters, I think your hot end must have a high thermal mass, a high powered heater, and good insulation. However, turning on the print cooling fan cools the heater a lot. Does that sound right?
Please run M307 H1 and check that it reports that those are the parameters.
I suggest you try reducing the R parameter. Too high and it will fault while heating up; too low and the temperature will overshoot. Try R2.0.
@dc42 It's a mosquito liquid hotend from Slice Engineering. Yesterday I received a new thermistor and heater cartridge from them for that block. I double checked the crimps on the thermistor JST connectors and the wire ferrules on the heater cartridge are good. I don't think it's the cooling fan though. I re-ran PID tuning without the fan and this is the result.
M307 H1 B0 R3.722 C283.2:94.4 D8.95 S1.00 V25.7
This is my sensor settings
M308 S1 P"20.temp0" Y"thermistor" A"Hotend" T100000 B3950 C7.06e-8
M307 H1
Heater 1 model: heating rate 3.722, cooling time constant 283.2/94.4, dead time 8.95, max PWM 1.00, calibration voltage 25.7, mode PID Computed PID parameters: setpoint change: P5.4, I0.106, D33.6, load change: P5.4, I0.263, D33.6
mosquito liquid
50w heater cartridge
thermistor high temperature -
@dhusolo I have the same problem with dyze extruder, something new about your PID tuning ?
@tom33 Nothing new that I can know of. I've been dong the same method for 2 years now
@dhusolo you and I have pretty much the same hardware; I don’t see any of that behavior. I’m perplexed.
@nuramori With the exception of me using the orbiter and a twin 4010 blower setup vs your custom planetary extruder extruder and 5015 blower they're identical. My design is highly inspired by yours LOL.
@dhusolo as I suggested before, try reducing the R parameter in the M307 command.
@dhusolo the only thing I can think of is, did you fill the heater and temp sensor with the boron nitride paste to ensure thermal transfer for both the heater and sensor?
@nuramori I have not. I'm using a slice thermistor and heater cartridge. I know with the glass bead thermistor you're supposed to fill with the paste but I didn't think I needed to with the cartridge style
@dhusolo yep. The instructions say to fill the space with the paste and set the heater and cartridge temp sensor in it.
@dhusolo odd - when I received my mosquito liquid it had a tube of it - I’m not sure about the thermal paste you linked - I would find out it’s temperature range. The thing about the boron nitride paste they include/sell; it hardens into a ceramic like mass that holds the thermistor and heater in place as well as transfer the thermal energy.
I've added the Boron Nitride Paste, replaced the tool board with a new one and uploaded the board and the Tool Board to RRF3.3 but the situation hasn't changed.
I've re-ran the PID tune with
M303 H1 S210
and this was the resultAuto tuning heater 1 completed after 3 idle and 10 tuning cycles in 606 seconds. This heater needs the following M307 command: M307 H1 B0 R2.919 C268.2:112.6 D6.85 S1.00 V24.7
If I try to heat to 210c I get a heater fault at around 80c. But I've noticed I don't get a fault if I heat to 60c, wait for the temperature to stabilize, than heat to 120c, than to 180c than to 210.
As a temporary fix I set the hotend temp in the slicer to 0 and created a macro that is called during the starting script. I know it's a bit archaic but it works.
T0 ; Select tool 0 M568 P0 S60 ; set active tool temperatures to 60c M116 G4 S1 M568 P0 S120 ; set active tool temperatures to 120c M116 G4 S1 M568 P0 S180 ; set active tool temperatures to 180c M116 G4 S1 M568 P0 S210 ; set active tool temperatures to 210c M116 G4 S1
; Configuration file for Duet 3 (firmware version 3) ; executed by the firmware on start-up ; ; generated by RepRapFirmware Configuration Tool v3.3 on Sat Jul 11 2020 20:25:37 GMT-0500 (Central Daylight Time) ; ================= General preferences =================== M80 ; Turns on the ATX power supply G4 S1 ; Wait for tool board G90 ; send absolute coordinates... M83 ; ...but relative extruder moves M669 K1 ; select CoreXY mode ; ====================== Network =========================== ;M586 P0 S1 ; Enable HTTP ;M586 P1 S0 ; Disable FTP ;M586 P2 S0 ; Disable Telnet ; ======================= Drives =========================== M569 P20.0 S1 ; physical drive 0.0 goes backwards-Extruder M569 P0.1 S0 ; physical drive 0.1 goes backwards-X stepper M569 P0.2 S0 ; physical drive 0.2 goes backwards-Y stepper M569 P0.3 S0 ; physical drive 0.3 goes backwards-Z left stepper M569 P0.4 S0 ; physical drive 0.4 goes backwards-Z right rear stepper M569 P0.5 S0 ; physical drive 0.5 goes backwards-Z right front stepper M584 X0.1 Y0.2 Z0.3:0.4:0.5 E20.0 ; set drive mapping Z3=Left Front, Z4= Right Rear, Z5=Right Front ; ===================== Drive Settings ===================== M350 X16 Y16 Z16 E16 I1 ; configure microstepping with interpolation XY .9 degree ZE 1.8 degree M92 X100.00 Y100.00 Z400.00 E675.35 ; set steps per mm XY .9 degree ZE 1.8 degree -Orbiter M203 X12000 Y12000 Z800 E7200.00 ; Set maximum speeds (mm/min) mm per minute/60=mm per second X12000 Y12000 M201 X1800.00 Y1800.00 Z100.00 E800.00 ; Set accelerations (mm/s^2) M566 X800.00 Y800.00 Z150.00 E700.00 ; Set maximum instantaneous speed changes (mm/min) M906 X1600 Y1600 Z1600 E1000 I30 ; Set motor currents (mA) and motor idle factor in per cent M84 S120 ; Set idle timeout ; ================ Independent Z Leveleing ================= M671 X-20:344:344 Y162.2:303.7:48.7 S10 ; leadscrew pivot point: ; ===================== Axis Limits ======================== M208 X-18 Y0 Z0 S1 ; set axis minima M208 X325 Y325 Z445 S0 ; set axis maxima ; ======================= Endstops ========================= M574 X1 S1 P"20.io1.in" ; configure active-high endstop for high end on X via pin i01.in M574 Y2 S1 P"0.io3.in" ; configure active-high endstop for high end on Y via pin i02.in M574 Z1 S2 ; configure Z-probe endstop for low end on Z ;M591 D0 P1 C"0.io4.in" S1 ; configure filament runout sensor for high end on extruder drive 0 via pin i03.in ; ======================== Z-Probe ========================= M950 S0 C"20.io0.out" ; create servo pin 0 for BLTouch M558 P9 C"^20.io0.in" H10 F300 T9000 ; set Z probe type to bltouch and the dive height + speeds G31 P500 X0 Y-19.2 Z2.760 ; set Z probe trigger value, offset and trigger height ; ======================== Heaters ========================= M308 S0 P"0.temp0" Y"thermistor" A"Bed" T100000 B4725 C0.0000000706 ; configure sensor 0 as thermistor on pin temp0 M308 S1 P"20.temp0" Y"thermistor" A"Hotend" T100000 B4680 C6.455513e-8 ; configure sensor 1 as thermistor on pin temp1-Matrix M950 H0 C"0.out1" T0 ; create bed heater output on out0 and map it to sensor 0 M950 H1 C"20.out0" T1 ; create nozzle heater output on out1 and map it to sensor 1 M307 H0 R0.238 C1283.9 D25.20 S1.00 ;Set PID for bed heater POST RRF 3.2.3 beta M307 H1 B0 R2.919 C268.2:112.6 D6.85 S1.00 V24.7 ; Set PID for Hotend .4Bmm nozzle RRF 3.3 M140 H0 ; map heated bed to heater 0 M143 H0 S100 ; set temperature limit for heater 0 to 100C M143 H1 S260 ; Set temperature limit for heater 1 to 260C ;M308 S2 P"mcu-temp" Y"mcu-temp" A"Duet" ; Configure MCU sensor ;M307 H1 B0 R3.722 C283.2:94.4 D8.95 S1.00 V25.7 ; ========================= Fans =========================== ;M950 F0 C"20.out1+^out2" Q500 ; create fan 0 on pin out9 and set its frequency M950 F0 C"20.out1" Q500 ; create fan 0 on pin out9 and set its frequency M106 P0 C"Layer Fan" S0 H-1 ; set fan 0 value. Thermostatic control is turned off M950 F1 C"0.out8"; Q25000 ; create fan 1 on pin out8 and set its frequency M106 P1 C"WC Fan" H1 T40 ; set fan 1 value. Thermostatic control is turned on ;M106 P1 C"WC Fan" H-1 S0 ; set fan 1 value. Thermostatic control is turned on ; ======================== Tools =========================== M563 P0 D0 H1 F0 ; define tool 0 G10 P0 X0 Y0 Z0 R0 S0 ; set tool 0 axis offsets ; ===================== Custom settings ==================== M564 H0 ; Let the Jog buttons work blv: added to allow jog buttons ; ====================== Miscellaneous ===================== M575 P1 S1 B57600 ; enable support for PanelDue M911 S10 R11 P"M913 X0 Y0 G91 M83 G1 Z3 E-5 F1000" ; set voltage thresholds and actions to run on power loss ;M574 S1 P"^!0.io1.in" ; Define Emergency endstop - emergency stop switch condition M950 J1 C"0.io5.in" ; Create GPIO pin for On button wired NO M581 T2 P1 S1 R0 ; T2-Run Trigger 2; P1-J1; S1-When button pressed; R0-trigger any time M582 T2 ; Monitor external trigger 2 ; ====================== Duet 3 (ID#0) ==================== ;0.out0 NC ;0.out1 Bed heater ;0.out2 NC ;0.out3 NC ;0.out4 NC ;0.out5 NC ;0.out6 NC ;0.out7 NC ;0.out8 Fan 1-Layer Fan ;0.out9, ;0.out4.tach NC ;0.out5.tach NC ;0.out6.tach NC ;0.io0.in PanelDue ;0.io1.in NC ;0.io2.in NC ;0.io3.in Y Endstop ;0.io4.in NC ;io5.in GPIO pin for on trigger ;0.io6.in NC ;0.io7.in BLTouch Signal pin ;0.io8.in Off button C ;0.io0.out PanelDue ;0.io1.out NC ;0.io2.out NC ;0.io3.out NC ;0.io4.out NC ;0.io5.out NC ;0.io6.out NC ;0.io7.out BLTouch Servo pin ;0.io8.out NC ;pson Power on SSR 3+ ;0.spi.cs0 NC ;0.spi.cs1 NC - this can be your PT100 board ;0.spi.cs2 NC ;0.spi.cs3 NC ;0.temp0 Bed heater ;0.temp1 NC ;0.temp2 NC ;0.temp3 NC ;0.mcu-temp Virtual Temp Sensor ; ================ Toolboard 1 (CAN ID#20) ================ ; 20.out0 - Hotend Heater ; 20.out1 - NC ; 20.out2 - Parts cooler on printhead ; 20.out2_tach0 - NC ; 20.out1_tach0 - NC ; 20.io0.in - NC ; 20.io1.in - X min active low endstop switch ; 20.io2.in - Reserved for filament monitor ; 20.io0.out - NC ; 20.temp0 - Extruder Thermistor ; 20.temp1 - NC ; 20.button0 - NC ; 20.button1 - NC ; 20.CAH_H - Duet CAN1_H ; 20.CAH_L - Duet CAN1_L
@dhusolo it sounds to me that tuning has over estimated the M307 R parameter. Try reducing it by 25%.
@dc42 I reduced it it R2.199 and It successfully heated directly to 200c with no fault. I guess now my concern is why it's doing this now. It seems like If I use the unmodified PID values if the thermistor is directly connected to the Duet 3 board I don't have this issue.
Also DWC will report the hotend is in a fault state but it doesn't tell me what the error is
That will be fixed in a future firmware version, perhaps in RRF 3.4.
