    Height map fine tuning
    • juliann
      juliann last edited by
      I am totally new to 3d printing and am building a Rat Rig V-Core 3 500x500x500, quite a big challenge to me :-)...
      I would appreciate if somebody would give me some advice to fine tune the settings.
      I think all is already configured, but I am not sure if there is any errors or settings that need improving.
      Duet 3 Mini 5+ + Expansion Mini 2+
      Duet Web Control 3.3.0-rc3
      Extruder LGX
      Mosquito Magnum w/ HightTemp 450C SliceEng thermistor.
      BL Touch 3.1
      Keenovo AC 1500w bed
      This is my config.g
      code_text
      ```; General preferences
      G90                                     ; send absolute coordinates...
      M83                                     ; ...but relative extruder moves
      M550 P"duet3"                        ; set printer name
      M669 K1                                 ; CoreXY
      G29 S1                                  ; Set Units to Millimeters
      ;M552 P0.0.0.0 S1                        ; enable network and acquire dynamic address via DHCP
      M586 P0 S1                              ; enable HTTP
      M586 P1 S0                              ; disable FTP
      M586 P2 S0                              ; disable Telnet
      M569 P0.0 S0 D3                         ; physical drive 0.0 goes forwards
      M569 P0.1 S0 D3                         ; physical drive 0.1 goes forwards
      M569 P0.2 S0 D3                         ; physical drive 0.2 goes forwards
      M569 P0.3 S1 D3                         ; physical drive 0.3 goes forwards
      M569 P0.4 S1 D3                         ; physical drive 0.4 goes forwards
      M569 P0.5 S1 D3                         ; physical drive 0.5 goes forwards
      M584 X0.4 Y0.3 Z0.0:0.1:0.2 E0.5        ; set drive mapping
      M350 X16 Y16 Z16 E16 I1                 ; configure microstepping with interpolation
      M92 X80.00 Y80.00 Z800.00               ; set steps per mm
      M906 X1000 Y1000 Z800 I30               ; set motor currents (mA) and motor idle factor in per cent
      M84 S30                                 ; Set idle timeout
      M566 X400.00 Y400.00 Z6.00 E120.00 P1          ; set maximum instantaneous speed changes (mm/min)
      M203 X10800.00 Y10800.00 Z1000.00 E3600.00     ; set maximum speeds (mm/min)
      M201 X3000.00 Y3000.00 Z100.00 E3600.00        ; set accelerations (mm/s^2)
      M208 X510 Y500 Z500 S0                             ; set axis maxima
      M574 X1 S1 P"io2.in"                           ; configure active high endstops
      M574 Y2 S1 P"io1.in"                           ; configure active high endstops
      M574 Z1 S2                                     ; configure Z-probe endstop for low end on Z
      ;; BLTouch
      M950 S0 C"io3.out"                     ; Create a servo pin on io3
      M558 P9 C"io3.in" H3 F500 T12000    ; set Z probe type to unmodulated and the dive height + speeds
      ;M558 H30                                     ;*** Remove this line after delta calibration has been done and new delta parameters have been saved
      G31 P25 X-28.00 Y-13.00 Z0.90          ; set Z probe trigger value, offset and trigger height, more Z means closer to the bed
      ;;M671 X-4.5:150:304.5 Y-4.52:305:-4.52 S5       ; define positions of Z leadscrews or bed levelling screws
      M671 X-4.5:250:504.5 Y-4.52:505:-4.52 S5       ; Define positions of Z leadscrews or bed levelling screws
      M557 X30:300 Y15:300 P5                        ; define 5x5 mesh grid
      ; BED HEATER
      M308 S0 P"temp0" Y"thermistor" T100000 B3950 A"Bed"    ; configure sensor 0 as thermistor on pin temp0
      M950 H0 C"out0" T0                                     ; create bed heater output on out5 and map it to sensor 0
      M307 H0 B0 S1.00                                       ; disable bang-bang mode for the bed heater and set PWM limit
      M140 H0                                                ; map heated bed to heater 0
      M143 H0 S120                                        ; set temperature limit for heater 0 to 110C
      ;; BED Heater PID Tune JEN
      M307 H0 B0 R0.795 C325.9 D3.08 S1.00 V23.9
      M950 F0 C"out3" Q500                   ; create fan 0 on pin out3 and set its frequency
      M106 P0 C"Hotend Fan" S0 H1 T45 L255   ; set fan 0 name and value. Thermostatic control turned on for Hotend
      M950 F1 C"out4" Q500                   ; create fan 1 on pin out4 and set its frequency
      M106 P1 C"Layer Fan" S0 H-1 L255       ; set fan 1 name and value. Thermostatic control is turned off
      ; Lights
      ;M950 P2 C"out8"                                    ; create output for lighning via DC DC SSR
      M563 P0 D0 H1 F1           ; define tool 0
      G10 P0 X0 Y0 Z0            ; set tool 0 axis offsets
      G10 P0 R0 S0               ; set initial tool 0 active and standby temperatures to 0C
      M308 S1 P"temp1" Y"thermistor" T500000 B4723 C1.196220e-7 ; PARA SLICE ENGINNERING HIGH TEMP
      M950 H1 C"out1" T1         ; create nozzle heater output on out2 and map it to sensor 1
      M307 H1 B0 S1.00           ; disable bang-bang mode for heater and set PWM limit
      M143 H1 S250               ; set the maximum temperature in C for heater
      ;;M307 H1 B0 R2.539 C213.7:208.8 D8.22 S1.00 V23.9	; JEN 12V
      M307 H1 B0 R2.856 C126.3 D6.76 S1.00 V23.9			;JEN 24V
      ; EVA 2 / BMG / E3D V6
      M92 E400         ; set extruder steps per mm, 1.8 angle/step
      M906 E800         ; set extruder motor current (mA) and idle factor in per cent
      M575 P1 B57600 S1;enable panelDue UART
      M501                                               ; load saved parameters from non-volatile memory
      M911 S10 R11 P"M913 X0 Y0 G91 M83 G1 Z3 E-5 F1000" ; set tension thresholds and actions to run on power loss
      M404 N1.75 D0.4                                 ; Filament width and nozzle diameter
      ;DHT Sensor on IO4
      M308 S10 P"io4.out+io4.in" Y"dht22" A"Chbr Temp[C]"
      M308 S11 P"S10.1" Y"dhthumidity" A"Chbr Hum[%]"
      ;M591 P3 C"e0_stop" S1  ; filament monitor connected to E0_stop
      M591 D0 P3 C"io5.in" S1 ; R85:115 L24.15 E3.0 	; Duet3D rotating magnet sensor for extruder drive 0 is connected to E0 endstop input, enabled, sensitivity 24.8mm.rev, 70% to 130% tolerance, 3mm detection length
      T0```
      code_text
      Bed.g
      code_text
      ```M561 ; clear any bed transform
      ;G30 P0 X25 Y25 Z-99999 ; probe near a leadscrew
      ;G30 P1 X250 Y475 Z-99999 ; probe near a leadscrew
      ;G30 P2 X475 Y25 Z-99999 S3 ; probe near a leadscrew and calibrate 3 motors
      G30 P0 X30 Y30 Z-99999 ; probe near a leadscrew
      G30 P1 X250 Y479 Z-99999 ; probe near a leadscrew
      G30 P2 X470 Y30 Z-99999 S3 ; probe near a leadscrew and calibrate 3 motors
      G29  ; probe the bed and enable compensation```
      code_text
      Thanks in advance!
      Regards
      Julián.
      juliann Phaedrux 2 Replies Last reply Reply Quote 0
      • juliann
        juliann @juliann last edited by
        @juliann
        I almost forgot, I have the Duet Magnetic filament monitor as well.
        Thanks!
        peter247 1 Reply Last reply Reply Quote 0
        • peter247
          peter247 @juliann last edited by peter247
          @juliann Not sure if you need the extra 0. on the drives if you are not using cam expansion broad.
          you have missed E , M906 X1000 Y1000 Z800 I30 - seen it's, in its own section !!!
          Ender 5 plus linear rail and hemera powered by duet 2 wifi , CR10s pro v1 with bltouch mostly stock , BLV mgn Cube slowly being built powered by duet 3 mini 5+
          juliann 1 Reply Last reply Reply Quote 0
          • juliann
            juliann @peter247 last edited by
            @peter247
            Thank you I will double check that.
              Phaedrux Moderator @juliann last edited by
              @juliann said in Height map fine tuning:
              The command doesn't match the comment. G29 S1 loads the heightmap, which shouldn't be done in config.g.
              Otherwise that bed looks quite flat. Maybe a slight dip to the back?
              bahnstormer 1 Reply Last reply Reply Quote 0
              • bahnstormer
                bahnstormer @Phaedrux last edited by
                @phaedrux said in Height map fine tuning:
                What is best practice for location of "G29 S1"? To put that in the slicer start code?
                  Yes, slicer start gcode is a good spot, or the end of homeall if you want to have it active for jogging around before a print or something.
