    Extruder resetting after purging
    • taconiteundefined
      taconite
      Hey guys,
      in the start-g.code of my sliver (Cura version 4.6). I would like to purge the Hot-End. This why I call a script called "purge_print"
      After the filament is pushed the extruder is moving backwards the amount that was pushed in the macro. Setting the extruder to 0 with G92 is not working - now is the big question: Why?
      Thank you for your help!
      ;this file is for purging at start of the print
      G1 X-154 Y-83 F10000
      G92 E0
      G1 E25 F300
      G92 E0
      G4 P1500
      ;Brush
      G1 X-148 Y-82 F2000
      while iterations<0
      	G1 X-141 Y-69 F10000
      	;G1 X-139 Y-76 F10000
      	G1 X-148 Y-82 F15000
      G1 X-102 Y-57 F15000
      Custom ANET A8
      Custom Delta: D-PATCH (Delta Printer with Automatic Tool CHanging) https://forum.duet3d.com/topic/16082/d-patch?_=1596131234754
      All I do here is under this license: CC BY-NC-SA
        I suggest you switch Cura to use relative extruder moves instead of absolute if you haven't already. Then no need to reset the extruder position at all.
        What do you have in the rest of your slicer start code? Can you share the first 50 lines or so of a sliced file?
        • taconiteundefined
          taconite
          @phaedrux Thank you for your answer
          M291 P"Heating up bed than nozzle" R"Preparing Print" T5 ; Display message
          G28
          M106 P10 S0.25
          M190 S{material_bed_temperature}
          M106 P10 S0.4
          M109 S{material_print_temperature}
          G29 S1
          M98 P"Alarmsound.g"
          G1 Z30 F15000
          M98 P"print_purge"
          G1 X0 Y0 F18000
          G92 E0
          M106 P10 S0.5
          M291 P"Printing" R"Print..." T5 ; Display message
          Cura is on relative extruder moves already. I thought maybe it could be fixed with G92
          it is independent from the sliced file, I tried it with multiple files
          Custom ANET A8
          taconiteundefined 1 Reply Last reply Reply Quote 0
          • taconiteundefined
            taconite @taconite
            ;Layer height: 0.1
            ;MINX:-70.881
            ;MINY:42.231
            ;MINZ:0.3
            ;MAXX:-39.606
            ;MAXY:72.174
            ;MAXZ:5
            ;POSTPROCESSED
            ;Generated with Cura_SteamEngine 4.6.1
            T0
            M82 ;absolute extrusion mode
            G28
            M106 P10 S0.25
            M190 S80.0
            M106 P10 S0.4
            M109 S230
            G29 S1
            M98 P"Alarmsound.g"
            G1 Z30 F15000
            M98 P"print_purge"
            G1 X0 Y0 F18000
            G92 E0
            M106 P10 S0.5
            M83 ;relative extrusion mode
            G1 F4200 E-5
            ;LAYER_COUNT:48
            ;TYPE:CUSTOM
            ; Movement of the Toolchanger with every layer
            G91 ;relative positioning
            G1 U0.1
            G90 ;back to absolute positioning
            ;LAYER:0
            M107
            G0 F7200 X-44.974 Y45.591 Z0.3
            ;TYPE:SKIRT
            G1 F4200 E5
            G1 F3600 X-44.667 Y45.934 E0.02297
            G1 X-43.962 Y46.85 E0.05767
            G1 X-43.488 Y47.604 E0.04443
            G1 X-40.948 Y52.11 E0.25806
            G1 X-40.668 Y52.655 E0.03057
            G1 X-40.512 Y52.991 E0.01848
            G1 X-40.136 Y53.969 E0.05227
            G1 X-40.001 Y54.405 E0.02277
            G1 X-39.806 Y55.17 E0.03939
            G1 X-39.72 Y55.687 E0.02615
            G1 X-39.674 Y56.034 E0.01746
            G1 X-39.606 Y57.145 E0.05553
            G1 X-39.611 Y57.597 E0.02255
            G1 X-39.66 Y58.385 E0.03939
            G1 X-39.779 Y59.158 E0.03902
            G1 X-40.058 Y60.291 E0.05821
            G1 X-40.198 Y60.718 E0.02242
            G1 X-40.599 Y61.707 E0.05324
            G1 X-41.011 Y62.495 E0.04436
            G1 X-43.687 Y67.029 E0.26266
            G1 X-44.009 Y67.53 E0.02971
            G1 X-44.222 Y67.835 E0.01856
            G1 X-44.925 Y68.702 E0.05569
            G1 X-45.237 Y69.035 E0.02277
            G1 X-45.805 Y69.583 E0.03938
            G1 X-46.459 Y70.104 E0.04172
            G1 X-47.367 Y70.705 E0.05432
            G1 X-47.761 Y70.928 E0.02259
            G1 X-48.467 Y71.282 E0.0394
            G1 X-49.238 Y71.581 E0.04126
            G1 X-50.322 Y71.892 E0.05626
            G1 X-50.769 Y71.986 E0.02279
            G1 X-51.916 Y72.14 E0.05774
            G1 X-52.812 Y72.174 E0.04473
            G1 X-57.998 Y72.12 E0.25874
            G1 X-58.588 Y72.091 E0.02947
            G1 X-58.947 Y72.06 E0.01798
            Custom ANET A8
            Phaedruxundefined deckingmanundefined 2 Replies Last reply Reply Quote 0
              Phaedrux Moderator @taconite
              @taconite said in Extruder resetting after purging:
              M82 ;absolute extrusion mode M291 P"Heating up bed than nozzle" R"Preparing Print" T5 ; Display message G28 M106 P10 S0.25 M190 S80.0 M106 P10 S0.4 M109 S230 G29 S1 M98 P"Alarmsound.g" G1 Z30 F15000 M98 P"print_purge" G1 X0 Y0 F18000 G92 E0 M106 P10 S0.5 M291 P"Printing" R"Print..." T5 ; Display message M83 ;relative extrusion mode
              G1 F4200 E-5
              Cura starts with absolute extrusion enabled regardless of what you have configured and only changes to relative extrusion right before it starts the main print.
              As you can see from the gcode it starts with M82 and M83 only shows up at the end after your macro has been called followed by a 5mm retraction. So add M83 to the start of your purge macro to ensure it's relative there.
              Are you sure it's retracting the full 25mm and not just the -5mm move?
              taconiteundefined 1 Reply Last reply Reply Quote 1
              • deckingmanundefined
                deckingman @taconite
                @taconite Another thing you can try is adding M400 after the extruder move. This will ensure the move finishes before any other commands are executed.
                • taconiteundefined
                  taconite @Phaedrux
                  @phaedrux ah perfect - thank you! I will try that. I guess in this file I reduced the purging from 25 to 5 so with the skirt I will get material to flow again.
                  @deckingman alright - will add the M400 aswell!
                  Custom ANET A8
