Filament monitor troubleshooting
If it works generally, but just not detecting enough movement, I would say keep tuning.
https://duet3d.dozuki.com/Wiki/Duet3dFilamentMonitor_RotatingMagnetVersion#Section_Calibration
@phaedrux this is the message I'm getting in the console:
M591 D0
Pulse-type filament monitor on pin e0stop, enabled, sensitivity 28.400mm/pulse, allowed movement 50% to 150%, check every 18.6mm, no data receivedI have no clue what is going on with this thing.
@fart_plume said in Filament monitor troubleshooting:
The BTT "Smart" runout sensor's sensitivity should be 7mm try this and see what you get:
M591 D0 P7 C"e0stop" L7 R50:200 E15 S1
also on a bondtech direct dive. Works a treat for me.
@nurgelrot said in Filament monitor troubleshooting:
still a no go this what I get on the console messages:
m591 d0
Pulse-type filament monitor on pin e0stop, enabled, sensitivity 7.000mm/pulse, allowed movement 50% to 200%, check every 15.0mm, no data received -
@fart_plume Right. That's correct. they only receive data during a print. should switch to :
Pulse-type filament monitor on pin io4.in, enabled, sensitivity 7.000mm/pulse, allowed movement 50% to 200%, check every 15.0mm, no calibration data while printing. I cant remember what condition they collect calibration data under... if in doubt cut the filament.
@nurgelrot , the problem is it is stopping a few seconds into the print. It keeps saying too little movement.
apparently it only collects data if you are printing from a SD card, which I don't.
finally got it working. Of all the stupid things(of course). Apparently someone at the factory was having a really bad day. The cable wiring wasn't even the way it was supposed to be for their own boards.
Long dash tracer to signal
x tracer to Vcc
no tracer Gnd -
@fart_plume Yeah you can pretty much never trust the wiring on 90% of anything in the 3d printing world. best just to trace everything out yourself. --Glade you go it fixed.
@nurgelrot Yeah me too, I was tempted to chuck it. good thing I'm stuborn. lol
