    Z-Probe dig into bed
    1.2k
    • b3nitroundefined
      b3nitro
      Hi Guys,
      I did a search on the forum but couldnt find anything similar to my problem
      I got a fusion3 f410 printer with duet3d ethernet board and the automatic bed leveling stopped working suddently. The probing is done by electrical connection from the 3.3v of the board going to the hotend, slowly closing up distante to bed until it toutches aluminium foil tape wraped under the bed that toutches aluminium sheet and ground to the board
      Nozzle is perfectly clean, tape is in perfect condition (changed it after the probe digged into it)
      What I checked so far :
      Electrical loop from the connector out of the board is fully closed when the nozzle toutches the bed. Got 0.5ohms
      Thanks for your help!
        @b3nitro said in Z-Probe dig into bed:
        What port are you using on the board?
        Can you post the results of M122 and M98 P"config.g" as well as the contents of your config.g and homing macros just for a sanity check?
        It would seem to me to be a wiring/continuity issue.
        b3nitroundefined 1 Reply Last reply Reply Quote 0
        • b3nitroundefined
          b3nitro @Phaedrux
          @phaedrux thank you I will check that on monday
          Just so you know I also tested the following, continuity at the connector when unplugged fron the board and probe toutching the bed: all good
          With power on, probe in the air grnd to nozzle a have 3.3v
          There are resistor in the connector on the board, they read 4.7 and 10k if I remember right
          I'll get result of what you asked early next week, thank you for your help!
          • b3nitroundefined
            b3nitro @b3nitro
            @Phaedrux
            Here is the config.g and output commands as file
            Thank you!
            M98 P"config.g"
            Macro file "config.g" not found.
            config.g.txt
            m122.cmd.txt
            ; Fusion3 F410 Firmware configuration file
            ; For FusionWare 1.18.1
            ; Revision 2018.08.22
            ; For Serial Number 5465
            M111 S0                             	; Debug off
            M550 PFusion3 F410		        		; Machine name MUST HAVE A "P" IN FRONT OF IT(can be anything you like)
            M551 Pfusion3                       	; Machine password MUST HAVE A "P" IN FRONT OF IT
            M540 P0xBE:0xEF:0xDE:0xAD:0x54:0x65 	; MAC Address (replace last 2 blocks with 4 digit s/n)
            ;=== Adjust the following 3 lines to suit your network ===
            M552 P0.0.0.0 S1						; IP address (0 = use DHCP)
            M554 P192.168.1.1                   	; Gateway
            M553 P255.255.255.0                 	; Netmask
            M555 P2                             	; Set output to look like Marlin
            M575 P1 B57600 S1						; comms params for paneldue
            ; Machine configuration
            M569 P0 S1							; Drive 0 goes forwards
            M569 P1 S0							; Drive 1 goes backwards
            M569 P2 S0							; Drive 2 goes backwards
            M569 P3 S0							; Drive 3 goes backwards
            M569 P4 S0							; Drive 4 goes backwards
            M574 X1 Y1 Z2 S1					; set endstop configuration
            M667 S1								; set CoreXY mode
            M92 X43.70 Y43.70 Z426.67 E190.0	; set axis steps/mm
            M906 X1300 Y1300 Z1400 E1400 I100   ; Set motor currents (mA)
            M201 X2000 Y2000 Z300 E4000	        ; Accelerations (mm/s^2)
            M203 X33000 Y33000 Z2500 E10000     ; Maximum speeds (mm/min)
            M566 X600 Y600 Z40 E950	     		; Maximum jerk speeds mm/minute
            M208 X355 Y355 Z315					; set axis maxima
            M208 X0 Y0 Z0 S1					; set axis minima
            G21									; work in mm
            G90									; absolute coords
            M83									; relative extruder movements
            ; Z probe
            M558 P5 X0 Y0 Z0 H7 F100            ; Set probe type and if it's used for axis homing (no in our case)
            G31 Z0.10 P600                      ; Set the probe height and threshold (smaller number = further away from bed)
            ; Thermistors and heaters
            M305 P0 T100000 B4036 R4700
            M305 P1 T100000 B4725 C7.06e-8 R4700
            M305 P2 T100000 B4725 C7.06e-8 R4700
            M307 H0 A153.5 C534.2 D6.7 B0			; Configure H0 (bed) heater model
            M307 H1 A483.4 C190.2 D6.6 B0			; Configure H1 (print head) heater model
            M143 S320								; Set max print head temperature
            M143 H0 S140							; Set max heat bed temperature
            M570 H1 P10 T15							; Configure heater safety timeouts
            ; Tool definition
            M563 P0 D0 H1                       ; Define tool 0
            G10 P0 S0 R0		                ; Set tool 0 operating and standby temperatures
            M563 P2 H0							; define heat bed tool
            G10 P2 S0 R0						; define heat bed tool op and standby temps
            ;M572 D0 S0.20
            ; Configure filament monitor
            M581 T2 E0 S0 C1
            ; Reset filament monitor when the board is rebooted
            M42 P63 S0
            G4 P50
            G4 P50
            M42 P63 S1
            T0									; select first hot end
            M122
            Used output buffers: 2 of 32 (22 max)
            Static ram used: 24996
            Dynamic ram used: 89780
            Recycled dynamic ram: 4008
            Stack ram used: 1104 current, 3876 maximum
            Never used ram: 8412
            Last reset 00:03:37 ago, cause: power up
            Last software reset code 0x0003, HFSR 0x00000000, CFSR 0x00000000, ICSR 0x00400000, BFAR 0xe000ed38, SP 0xffffffff
            Spinning module during software reset: GCodes, available RAM 8408 bytes (slot 2)
            Error status: 0
            Free file entries: 10
            MCU temperature: min 19.7, current 28.3, max 29.3
            Supply voltage: min 23.4, current 23.4, max 23.5, under voltage events: 0, over voltage events: 0
            Driver 0: standstill
            Driver 1: standstill
            Driver 2: standstill
            Driver 3: standstill
            Driver 4: standstill
            Date/time: 2021-06-28 08:56:12
            Slowest main loop (seconds): 0.607727; fastest: 0.000039
            MaxReps: 0, StepErrors: 0, MaxWait: 0ms, Underruns: 0, 0
            Scheduled moves: 0, completed moves: 0
            Bed compensation in use: none
            Probe change coordinates:
            Bed heater = 0, chamber heater = -1
            Heater 1 is on, I-accum = 0.0
            Segments left: 0
            Movement lock held by null
            http is idle in state(s) 0
            telnet is idle in state(s) 0
            file is idle in state(s) 0
            serial is idle in state(s) 0
            aux is idle in state(s) 0
            daemon is idle in state(s) 0
            queue is idle in state(s) 0
            Code queue is empty.
            === Network ===
            State: 4
            === Webserver ===
            HTTP sessions: 1 of 8
            FTP connections: 0, state 0
            Telnet connections: 0, state 0
            • b3nitroundefined
              b3nitro @b3nitro
              Forgot the homing scripts
              homez.g homey.g homex.g
              ; === Fusion3 F410 ===
              ; X axis homing file
              ; Revision 3-22-16
              G91
              G1 Z0.5 F400
              G1 X-500 F3000 S1
              G1 X4 F600
              G1 X-10 S1
              G1 Z-0.5 F400
              G90
              ; Y axis homing file
              ; Revision 3-22-16
              G91
              G1 Z0.5 F400
              G1 Y-500 F3000 S1
              G1 Y4 F600
              G1 Y-10 S1
              G1 Z-0.5 F400
              G90
              ; Z axis homing file
              ; Revision 3-22-16
              G91
              G1 Z400 F500 S1
              G1 Z-4 F200
              G1 Z10 S1
              G90
                Can you also send M115 to report the firmware version? It appears you're using a quite old version.
                • b3nitroundefined
                  b3nitro @Phaedrux
                  @phaedrux
                  Here it is
                  M115
                  FIRMWARE_NAME: RepRapFirmware for Duet Ethernet FIRMWARE_VERSION: Fusionware 1.18.1 RC2 ELECTRONICS: Duet Ethernet 1.0 FIRMWARE_DATE: 2017-05-15
                    Yes that's quite ancient. However, I don't think that's the issue at hand.
                    There must be an electrical issue. Do you happen to have a normal endstop switch you could connect to the same port to test with?
                    As I'm not at all familiar with the Fusion printers am at a bit of a loss. Do they have support options as well?
                    • b3nitroundefined
                      b3nitro @Phaedrux
                      @phaedrux
                      There is no normal endstop, the bed stop about 1cm before the nozzle, slow down until it toutches to calculate z-height
                      I'm on support with them, they say its the wiring harness or the pull up resistor BUT the wiring harness loop got conductivity and the pullup resistors are giving me 10k and 2.2k so I doubt its the issue.. I feel its the board 😕
                        Which connector on the board are you using?
                        • b3nitroundefined
                          b3nitro @Phaedrux
                          @phaedrux
                          The one labelled "probe"
                          • b3nitroundefined
                            b3nitro @b3nitro
                            @Phaedrux
                            Got a little of success here, if I bypass the whole loop with a jumper wire while probing, the board get the connection and is going to the next step
                            That means the issue is in the wiring between 3.3v out of the board "probe" port after the pullup resistor AND before board probe input
                            Must be something with heat or vibration as the loop was "good" with ohmeter
                            Thanks for your help, I'll keep you posted
                            b3nitroundefined 1 Reply Last reply Reply Quote 1
                            • b3nitroundefined
                              b3nitro @b3nitro
                              @Phaedrux
                              Looks like the thermistor is the culprit even while its still working
                              Noticed I had 3.003v at the board but 3.297 at nozzle to bed, figured out I must have voltage leakout somewhere, unplugged heater didnt change, unplugged thermistor triggered heater fault but voltage dropped to 3.003v as the board output
                              Ran a bed leveling without thermistor and its working!
                              Need to find out what type of sensor they use to change it!
                              • b3nitroundefined
                                b3nitro @b3nitro
                                Done deal, swapped the thermistor and everything works flawlessly now!
