    Duet 2: Config 1x X, 4x Y and 2x Z motor
    Config Tool
    286
    • Space96undefined
      Space96
      Hello together,
      I am currently building a 3D printer (Corexz). However, I need help to adjust the config file to the number of axis motors so that the 4x Y-motors and the two Z-motors run in parallel. Can one of you help me? Many thanks smiling smiley
      Hardware:
      • Duet 2 Ethernet
      • Duex5
      Assignment:
      Duet 2:
      Z: Z1
      Y: Y1
      X: X1
      E0: E0
      E1: E1
      Duex5:
      E6: Z2
      E7: Y2
      E8: Y3
      E9: Y4
      Config:
      M569 P4 S1 ; physical drive 4 goes forwards
      M569 P7 S1 ; physical drive 7 goes forwards
      M569 P6 S1 ; physical drive 6 goes forwards
      M584 X0 Y1 Z2 E3:4:7:6:6:6 ; set drive mapping
      M350 X16 Y16 Z16 E16:16:16:16:16:16 I1 ; configure microstepping with interpolation
      M92 X160.00 Y160.00 Z533.33 E873.08:873.08:533.33:160.00:160.00:160.00 ; set steps per mm
      M566 X900.00 Y900.00 Z60.00 E120.00:120.00:60.00:900.00:900.00:900.00 ; set maximum instantaneous speed changes (mm/min)
      M203 X6000.00 Y6000.00 Z180.00 E1200.00:1200.00:180.00:6000.00:6000.00:6000.00 ; set maximum speeds (mm/min)
      M201 X500.00 Y500.00 Z20.00 E250.00:250.00:20.00:500.00:500.00:500.00 ; set accelerations (mm/s^2)
      M906 X1680 Y1680 Z1680 E1680:1680:1680:1680:1680:1680 I30 ; set motor currents (mA) and motor idle factor in per cent
      M84 S30 ; Set idle timeout
      o_lampeundefined fcwiltundefined dc42undefined 3 Replies Last reply Reply Quote 0
      • o_lampeundefined
        o_lampe @Space96
        @space96
        IMHO drive mapping would look like that
        M584 X0 Y1:7:8:9 Z2:6 E4:5
        You won't have to repeat the settings for all xyz motors, only extruders need seperate values
        • fcwiltundefined
          fcwilt @Space96
          @space96
          Just out of curiosity how are you using four Y steppers?
          The CoreXY printers I have seen only have one X and one Y.
          Thanks.
          Nurgelrotundefined 1 Reply Last reply Reply Quote 0
            dc42 administrators @Space96
            @space96 the drivers on the DueX are labelled E2 to E6, which are driver numbers 5 thru 9 respectively. If it's driver 5 (aka E2) that has no motor connected then you need:
            M584 X0 Y1:7:8:9 Z2:6 E3:4
            • Nurgelrotundefined
              Nurgelrot @fcwilt
              @fcwilt A CoreXZ not Y
              fcwiltundefined 2 Replies Last reply Reply Quote 0
              • fcwiltundefined
                fcwilt @Nurgelrot
                @nurgelrot said in Duet 2: Config 1x X, 4x Y and 2x Z motor:
                Thanks - I missed that - have to look up what a CoreXZ is.
                • fcwiltundefined
                  fcwilt @Nurgelrot
                  I looked up CoreXZ and it shows the Y axis is the moving bed.
                  So why would that need four steppers?
                  Thanks.
                    Nurgelrot @fcwilt
                    @fcwilt Ha I admit I breezed right over what you were really asking... Yeah I can't think of a reason for that many Y's either... World's heaviest print bed?
                    • fcwiltundefined
                      fcwilt @Nurgelrot
                      Maybe the OP just likes the sound of lots of steppers.
                      Thanks.
