Duet 3 wifi on Caribou
Can you post your config.g?
Can you send M122 and M98 P"config.g" in the Gcode console in DWC and post the results?
What axis do you have connected to driver 3? -
@phaedrux
Thx for your response
I don‘t no wich is driver 3 on the Board?
Sry its duet 2 wifi…… -
@revolution I had this happen to me. One of my driver connector pins were not pushed all the way into the connector plug. Check all of your electrical connections from the stepper motors to the driver connectors.
@tinken
Hi, you have it on an caribou too? -
There must be a space between M98 and the P"config.g"
Also please copy and paste the text if possible rather than screen shots in future.
And the contents of config.g please so we can see which driver is bound to which axis.
@phaedrux
27.6.2021, 12:51:42 M98 P"config.g"
HTTP is enabled on port 80
FTP is enabled on port 21
TELNET is disabled
Warning: Heater 0 appears to be over-powered. If left on at full power, its temperature is predicted to reach 365Cconfig.g:
; Configuration file for Duet WiFi (firmware version 3.2)
; for 0.9° motors on xye
; for Caribou220- E3d Thermistor - PINDA2
; CariboDuetConfiguration Release : "1.2.0"
; Build : 80
; Copyright Caribou Research & Development 2021. Licensed under GPL3.
; Source code and release notes are available on github: https://github.com/Caribou3d/CaribouDuet-Configuration-and-Macros
; Network settings
M550 P"Caribou220-EP" ; set printer name
M552 S1 ; enable network
M586 P0 S1 ; enable HTTP
M586 P1 S1 ; enable FTP
M586 P2 S0 ; disable Telnet
M575 P1 S1 B57600 ; Enable support for PanelDue
M569 P0 S0 F11 ; physical drive 0 goes backwards - x-axis
M569 P1 S0 F8 Y3:2 ; physical drive 1 goes backwards - y-axis
M569 P2 S0 F10 ; physical drive 2 goes backwards - z - left
M569 P3 S1 F14 ; physical drive 3 goes forwards - Extruder
M569 P4 S0 F10 ; physical drive 4 goes backwards - z right
; Motor Configuration
M584 X0 Y1 Z2:4 E3 ; set drive mapping
M671 X-36.5:293.5 Y0:0 S0.35 ; leadscrews at left (connected to Z) and right (connected to E1) of X axis
; set Microsteps and steps / mm
M92 X200.00 Y200.00 Z400.00 E830.00 ; set steps per mm
; set motor currents
M906 X800 Y850 Z450 E550 I40 ; set motor currents (mA) and motor idle factor in per cent
M84 S60 ; Set idle timeout
; set speeds
M201 X500.00 Y500.00 Z100.00 E500.00 ; set accelerations (mm/s^2)
M203 X9000.00 Y9000.00 Z1000.00 E3600.00 ; set maximum speeds (mm/min)
M204 P500.0 T500.0 ; set print and travel accelerations (mm(s^2)
M566 X480.00 Y480.00 Z48.00 E300.00 ; set maximum instantaneous speed changes (mm/min)
M564 H0 ; Allow unhomed movement
M208 X-2 Y-7.5 Z0 S1 ; set axis minima
M208 X256.9 Y214 Z216.50 S0 ; set axis maxima
M574 X1 S3 ; configure sensorless endstop for low end on X
M574 Y1 S3 ; configure sensorless endstop for low end on Y
M574 Z1 S2 ; configure Z-probe endstop for low end on Z
M574 Z2 S3 ; configure sensorless endstop for high end on Z
M591 D0 P2 C"e0_stop" S1 ; configure extruder endtstop (filament sensor)
; PINDA2
M558 P5 C"zprobe.in" H1.5 F1000 T12000 A3 ; set Z probe to PINDA2
M308 S2 P"e1temp" A"Pinda V2" Y"thermistor" T100000 B3950 ; temperature of PINDA2
M557 X23:235 Y5:186 S30.25:30 ; define mesh grid
; Stallguard Sensitivy
M915 X S2 F0 H400 R0 ; Set X axis Sensitivity
M915 Y S1 F0 H400 R0 ; Set Y axis Sensitivity
M915 Z S0 F0 H200 R0 ; Set Z axis Sensitivity
; Heater & Fans
; heated bed
M308 S0 P"bedtemp" Y"thermistor" T100000 B4138 R4700 A"Bed" ; configure sensor 0 as thermistor on pin bedtemp
M950 H0 C"bedheat" Q50 T0 ; create bed heater output on bedheat and map it to sensor 0
M143 H0 S110 ; set temperature limit for heater 0 to 110C
; extruder
; Hotend (Mosquito or Mosquito Magnum with E3d Thermistor)
M308 S1 P"e0temp" Y"thermistor" T100000 B4725 C7.060000e-8 R4700 A"Nozzle E1" ; E3d configure sensor 0 as thermistor on pin e0temp
M950 H1 C"e0heat" T1 ; create nozzle heater output on e0heat and map it to sensor 2
M308 S4 P"mcu-temp" Y"mcu-temp" A"MCU" ; set virtual heater for MCU
M308 S5 P"drivers" Y"drivers" A"Driver" ; set virtual heater for stepper drivers
; extruder fan (temerature controlled)
M950 F1 C"fan1" Q500 ; create fan 1 on pin fan0 and set its frequency
M106 P1 H1 T45
; radial fan
M950 F0 C"fan0" Q160 ; create fan 0 on pin fan1 and set its frequency
M302 S190 R190 ; allow extrusion starting from 190°C and retractions already from 190°C
; other settings
M18 XYE ; release / unlock X, Y, and E axis
M501 ; use config-override (for Thermistor Parameters and other settings)
M83 ; ... but relative extruder moves
; Offsets - place off-sets for x and y here. z-offsets are handled in the print sheet macros
G31 P1000 X23 Y5
@phaedrux
Hi, the extruder is now working
I have made the first layer calibration- came out very good
But when i will start a print came this message:28.6.2021, 17:04:24 Warning: M73: Command is not supported
Maximum jerk rates (mm/sec): X: 8.0, Y: 8.0, Z: 0.4, E: 1.5
FIRMWARE_NAME: RepRapFirmware for Duet 2 WiFi/Ethernet FIRMWARE_VERSION: 3.2 ELECTRONICS: Duet WiFi 1.02 or later FIRMWARE_DATE: 2021-01-05 -
@revolution, either ignore that warning; or configure your slicer not to generate M73 commands; or upgrade to firmware 3.3.
Hi, now i have upgraded to 3.3
When i will print something i get this message28.6.2021, 18:06:15 Cancelled printing file 0:/gcodes/gearr_0.2mm_PLA_MK3S_18m.gcode, print time was 0h 2m
Emergency Stop! Reset the controller to continue.
Error: Homing failed
Can i Post videos? -
Yes you can post videos.
When do you get that error?
Please post your homing macros as well as your slicer start gcode so we can see what is going on when you start a print.
@phaedrux
Looks like this
https://vimeo.com/568524469Start.g:
; Executed before each print - BEFORE ANY SLICER CODE IS RAN
; This also loads the heightmap
M122 ; Clear diagnostic data to cleanly capture print evolution statistics.
T0 ; Ensure the tool is selected
M572 D0 S0.0 ; Clear pressure advance.
M220 S100 ; Set speed factor back to 100% in case it was changed
M221 S100 ; Set extrusion factor back to 100% in case it was changed
M290 R0 S0 ; Clear any baby-stepping
M106 S0 ; Turn part cooling blower off if it is on
M703 ; Execute loaded filament's config.g
G32 ; execute bed.g (level gantry)
G29 S1 ; Load bed mesh for the system's set filament type
M400 ; Finish all moves, clear the buffer
G90 ; Absolute Positioning
M83 ; Extruder relative mode
M98 P"0:/sys/current-sense-normal.g" ; Ensure that motor currents and sense are set for printing
; Slicer generated gcode takes it away from here ....
@revolution said in Duet 3 wifi on Caribou:
What do you have in bed.g and homeall.g?
Can you please also post the slicer start gcode section?
Can you describe what I'm seeing in that video?
@phaedrux
; bed.g
G28 W ; home
G30 P0 X25 Y100 Z-99999 ; probe near a leadscrew, half way along Y axis
G30 P1 X235 Y100 Z-99999 S2 ; probe near a leadscrew and calibrate 2 motors
G90 ; back to absolute mode
G1 H2 Z8 F2600 ; raise head 4mm to ensure it is above the Z probe trigger height
G1 X104 Y100 F6000 ; put head over the centre of the bed, or wherever you want to probe
G30 ; lower head, stop when probe triggered and set Z to trigger height
; Home XYZ Axis
M98 P"homez.g" ; homeall is the same as homez
In the Video you see starting a Print, the leveling and Then the Print should starting but then the extruder goes only on the Home of x and nothing happens
I Hope you know what i mean? -
Ok, what's in homez.g then?
It looks like you get through the leveling portion. Then the print should be starting, but it moves very slowly to the left. If that is from the sliced gcode section please share either the slicer start gcode section or share the first 50 lines or so of a sliced gcode file.
Everything the printer is doing is just gcode commands. So being able to see what those commands are is important for understanding what's actually happening.
@phaedrux
homez.g:=========================================================================================================
; Home XYZ Axis
G91 ; relative positioning
M98 P"current-sense-homing.g" ; Ensure the current and sensitivity is set for homing routines.
G1 H2 X0.5 Y-0.5 F10000 ; energise motors to ensure they are not stalled
M400 ; wait for current moves to finish
M913 X40 Y40 ; drop motor current to 40%/40%
G4 P200 ; wait 200ms
; Home X Axis
G1 H1 X5 F1000 ; move slowly away
G1 H1 X-260 F3000 ; move quickly to X axis endstop and stop there (first pass)
G1 H2 X5 F1000 ; go back a few mm
G1 H1 X-10 F3000 ; move slowly to X axis endstop once more (second pass)
; Home Y Axis
G1 H1 Y5 F1000 ; move slowly away
G1 H1 Y-260 F3000 ; move quickly to X axis endstop and stop there (first pass)
G1 H2 Y5 F1000 ; go back a few mm
G1 H1 Y-10 F3000 ; move slowly to X axis endstop once more (second pass)
M913 X100 Y100 ; return X & Y motor
G90 ; absolute positioning
; Home Z Axis
G1 X11.5 Y4.5 F6000 ; go to first probe point
G1 Z0.15 F100 ; move Z to origin
G1 Z1 F100 ; lift Z relative to current position
M400 ; Wait for current moves to finish
M98 P"current-sense-normal.g" ; Ensure the current and sensitivity is set for homing routines.
; =========================================================================================================Start G-code/ Prusaslicer from the object in the Video:
M115 U3.9.3 ; tell printer latest fw version
G90 ; use absolute coordinates
M83 ; extruder relative mode
M104 S[first_layer_temperature] ; set extruder temp
M140 S[first_layer_bed_temperature] ; set bed temp
M190 S[first_layer_bed_temperature] ; wait for bed temp
M109 S[first_layer_temperature] ; wait for extruder temp
G28 W ; home all without mesh bed level
G80 ; mesh bed leveling
G1 Y-3.0 F1000.0 ; go outside print area
G92 E0.0
G1 X60.0 E9.0 F1000.0 ; intro line
G1 X100.0 E12.5 F1000.0 ; intro line
G92 E0.0
M221 S{if layer_height<0.075}100{else}95{endif} -
Would you say that the slow movement occurs here? F1000 is about 16mm/s so quite slow. F6000 would be more appropriate for a travel move.
There are a few things in your slicer start gcode that aren't compatible with reprapfirmware. What gcode flavor do you have set for PrusaSlicer?
M115 for instance just reports the current firmware version.
G28 W would likely just run homeall.g with no changes.
G80 isn't a supported gcode at all. To do mesh compensation in RRF you use G29.@revolution said in Duet 3 wifi on Caribou:
M98 P"current-sense-normal.g" ; Ensure the current and sensitivity is set for homing routines.Can you post those two macros as well for full disclosure?
Also, at what point in your video are you getting the short to ground error on driver 3? Driver 3 appears to be your extruder.
Are you able to extrude into free air by heating the hotend and commanding extrusion from DWC or paneldue?
@phaedrux
Now i have solve the problem:
i have changed in Prusaslicer the Firmware G-Code Typ to "RepRap/Sprinter"
Then i add this customised Start G-code;
; start script for PrusaSlicer for CaribouDuet
G0 X60 Y-3 Z80 ; move extruder above bed, keep extruder in front for cleaning and checking
M104 S160 T0 ; pre-heat extruder to 160°C
M140 S[first_layer_bed_temperature] ; this will take the layer 1 temperature for bed 0
G29 ; mesh bed leveling using defined mesh grid
G0 X0 Y-3 Z0.6 ; go outside print area
M104 S[first_layer_temperature] ; set extruder temperature
M98 P"0:/sys/primeLine.g" ; execute primeline macro
G92 E0.0 ; set extruder position
M572 D0 S0.07 ; set pressure advance
Now it works!
