    Accurate dimensions
    Using Duet Controllers
    • donpedroundefined
      donpedro
      My delta printer does not print in the accurate dimensions, they differ on x and y and are different if the part has different lengths
      How can I correct?
      GuruSMIundefined 1 Reply Last reply Reply Quote 0
      • GuruSMIundefined
        GuruSMI @donpedro
        @donpedro
        https://duet3d.dozuki.com/Wiki/Calibrating_a_delta_printer#Section_Correcting_for_small_X_and_Y_scaling_errors
        donpedroundefined 1 Reply Last reply Reply Quote 0
        • donpedroundefined
          donpedro @GuruSMI
          I don't think it helps me because this difference is not constant, I could adjust it from the slicer if it was like that, but it doesn't work
          I have for example the following values on one axis, as the others differ
          24.68
          19.78
          14.82
          9.95
          5.06
          print_measure (3).stl
            jay_s_uk
            @donpedro are your arm measurements accurate?
            • donpedroundefined
              donpedro @jay_s_uk
              there are 3 pairs of arms with different values and they are also in config g
                dc42 administrators @donpedro
                @donpedro said in Accurate dimensions:
                24.68
                19.78
                14.82
                9.95
                5.06
                It looks to me that you have a scaling error of -2% plus an excess extrusion width of 0.75mm on each side. That would give actual sizes of 24.65, 19.75, 14.85, 9.95 and 5.05 which are very close to what you measured.
