Set Extruder Postion with G92 E
I have a question. Why is it not possible to set the extruder position with G92 E???
Again and again we have the issue that after a purge and a long retract we are not given any filament at the start of printing. We would like to reset the position manually, but I have the impression that the command G92 E is not setting the extruder axis for both RRF 2.05.1 and RRF 3.3.
It works perfectly with the XYZ axes.
Is there a reason for this?
@cr3d do you have a tool selected when you're trying to use it?
edit, just tried with a tool selected in both M82 and M83 mode and the drive position for E doesn't change for me either
@phaedrux could be. I did try it on an SBC based printer running 3.3.0. I'll try on a standalone
I think it's just a display issue rather than it not resetting the actual position. Otherwise absolute extrusion wouldn't work. Check the actual extruder position with M114
@phaedrux It displays the extruder location correctly during a print.
What is more odd is the output of M114m114 X:121.263 Y:143.324 Z:0.300 E:0.000 E0:896.7 Count 10462 12499 120 Machine 121.263 143.324 0.300 Bed comp 0.000
I only have 1 extruder configured....
