Setting up Accelerometer and wiring
@bot
I didn't mean that the heatsink/hotend add to the equation, but the long lever of the heatsink amplifies the amplitude which makes it easier to separate resonance from noise.
And it would be easier to design a universal bracket, since most heatblocks share more or less the same dimensions. While brackets for carriers are often one_of_a_kind. -
@dc42 said in Setting up Accelerometer and wiring:
You can also try using the TWC0 and TWD0 pins instead of EXP0 and EXP1.
I re-wired the whole thing with the shortest CAT6 cable I can manage. I kept the 1k resistor inline with SDO... same error.
I moved CS and INT as follows:
CS > TWD0
INT > TWCK0M955 P0 C"exp.pa3+exp.pa4"
...same error. Accelerometer not found. Green light is lit on the accelerometer.
What else can I do to troubleshoot?
@ccs86 have you already tried the SPI Pins on the Temp Board? The SPI Pins on the EXP are bufferd
@pcr said in Setting up Accelerometer and wiring:
I can try that. Can't seem to find the correct pin names for those, though. I have tried:
M955 P0 C"spi.PB2+spi.PC18"
M955 P0 C"PB2+PC18"
M955 P0 C"spi0_cs1+spi0_cs2"
M955 P0 C"spi0.cs1+spi0.cs2"
M955 P0 C"spi.cs1+spi.cs2"
M955 P0 C"spi.cs3+spi.cs4"
M955 P0 C"exp.cs1+exp.cs2"
M955 P0 C"exp.cs3+exp.cs4"This page seems incomplete for pin names: https://duet3d.dozuki.com/Wiki/Duet_2_Maestro_Wiring_Diagram
And I'm not sure this is applicable: https://duet3d.dozuki.com/Wiki/Duet_2_Pinout_table
@ccs86 yes that page is missing the SPI CS pin names. They are "spi.cs1" and "spi.cs2".
Are these pins used by the daughterboard itself? I get the following error:
M955 P0 C"spi.cs1+spi.cs2" Error: M955: Pin 'spi.cs1' is not free
Any other ideas?
@ccs86 yes you are already using those pins for the daughter board.
Any ideas on what to try next?
@ccs86 I'll try hooking up an accelerometer to a Maestro when I get a chance.
