    Toolboard 1.1 IO pins voltage tolerance
    toolboard voltage
    • jMaddrellundefined
      jMaddrell
      Can somebody confirm what voltage the io0.in pins will tolerate on the toolboard 1.1? For the mb6hc the wiki says io0-io8 will take 30v but I can't see anything on the toolboards documentation.
      I'm planning on using a 24v inductive probe connected to the same power supply as the toolboard and the probes output to io0.in if it's safe.
      Thanks!
        Yes they are 30v tolerant, except for IO1_IN, which is limited to 15V.
        jMaddrellundefined 1 Reply Last reply Reply Quote 1
          jMaddrell @Phaedrux
          @phaedrux thanks much appreciated
