    What would you build if you were starting again now?
    99
    11.7k
    • MikeSundefined
      MikeS @fcwilt
      @fcwilt not perfectu but used this to assemble
      I always used the .4 nozzle with that delta. I have a nozzle fun pack, but only used with the Voron for testing them.
      You can look it there: https://a360.co/2USEGD9
      an these are the real parts printed with the V2 (consider all belts and carriage are 6 years old and should be replaced probably)
      zaptaundefined 1 Reply Last reply Reply Quote 1
      • zaptaundefined
        zapta @MikeS
        I found this Knipex to work very will with my nozzle exchanges. The jaws are smooth and parallel and it has leverage that allow to easily apply sufficient force.
        MikeSundefined 1 Reply Last reply Reply Quote 0
        • MikeSundefined
          MikeS @zapta
          @zapta now i have a dragon hotend so no more problem with spinning heater block! E3D served me well in the years, but it's time for them to update their design.
          mrehorstdmdundefined zaptaundefined 3 Replies Last reply Reply Quote 1
          • mrehorstdmdundefined
            mrehorstdmd @MikeS
            @mikes I gave up on the V6 a few years ago after the heat break kept loosening in the heatsink during prints. I've been using a cheapo Chinese hot-end for a few years that cost $15 when I bought it, plus replacing the supplied crappy fan with a Sunon mag-lev type for another $7. It has set screws to hold the heatbreak in the heatsink, and a metal bracket that is screwed to the heatsink to hold the fan. No more rotating heater blocks or melting, rotating fan mounts. It came with a 50W heater and cartridge type thermistor.
            fcwiltundefined 1 Reply Last reply Reply Quote 1
            • zaptaundefined
              zapta @MikeS
              @mikes said in What would you build if you were starting again now?:
              I also have a dragon but with a E3D round grove interface. 😉
              Once I will have my voron up and running will see how I can convert it to the two-screws type mounting.
              • fcwiltundefined
                fcwilt @mrehorstdmd
                @mrehorstdmd
                I've got a couple of "no name" units something like these.
                The design is like the right image but with the plated copper block of the left image.
                The fan mounts to the heat sink via the four threaded through holes - for those that like push/pull fans.
                It doesn't use grub screws to hold the heater/thermistor cartridges which is too bad.
                The V6 mount removes leaving two threaded holes.
                I bought two of them to see if I liked them (I do) but now I cannot find them again. The inventory of vendors on AE seem to change with the winds.
                • zaptaundefined
                  zapta @MikeS
                  @mikes, after reading your post I looked again at my grove mounted Dragon and realized that if I remove the groove adapter, it has 4 screw holes that I can use with the Voron Dragon variant. Thanks for your post I will have a proper Dragon with a single hand nozzle replacement 😉
                  (The documentation of the Voron leaves so many details out to a point that many steps require extensive research in the Fusion 360 model, youtube, and discord).
                  • MikeSundefined
                    MikeS @zapta
                    @zapta that's exactly how i mounted it. However you should always use 2 hands for nozzle swapping... twisting force on the x carriage will be a lot less and prevents damage
                    zaptaundefined 1 Reply Last reply Reply Quote 0
                    • zaptaundefined
                      zapta @MikeS
                      Yes, I think I will do that. Also, need to make sure just to resist with the pliers and not actually turn them since this also can damage the hotend.
                      • printernoodleundefined
                        printernoodle
                        Tiny-m - It's like a voron v.0.1 but 2020 extrusions and a bit bigger!
                        Very fast and precise...shown here in dual material configuration.
                        • zaptaundefined
                          zapta @printernoodle
                          @printernoodle said in What would you build if you were starting again now?:
                          Good choice. Large printers are overrated IMO.
                          cosmowaveundefined 1 Reply Last reply Reply Quote 0
                          • cosmowaveundefined
                            cosmowave @zapta
                            @zapta Nice 👍
                            Mankati FSXT+, DeltaTowerV2, E3D MS/TC
