    Duet 2 wifi configuration for Cartesian
    • muhac80undefined
      muhac80
      Hello all
      Do you know any youtuber shows how to configure Duet2 wifi for Cartesian 3d Printer. Cartesian only please. I am new and first time building DIY 3d printer. Very confused by the following videos;
      https://www.youtube.com/watch?v=6nqddfxHla0 (this not Cartesian anyways)
      https://www.youtube.com/watch?v=TxfEbUuKDyo
      https://www.youtube.com/watch?v=HxEk7-6RriQ&t=360s
      Please give me a video that is self explanatory and it doesn't assume that the viewer has some sort of background. I am with 0 background and stuck configuring the board.
        What specifically are you looking for regarding a cartesian setup?
        The online config tool should get your a pretty good starting point.
        https://configtool.reprapfirmware.org/Start
        And then there is this cartesian setup page that goes into more detail.
        https://duet3d.dozuki.com/Wiki/ConfiguringRepRapFirmwareCartesianPrinter
        And then there is this walk through guide for a cartesian. It's not a video, but it go over a lot of things.
        https://duet3d.dozuki.com/Search?query=ender
        muhac80undefined 1 Reply Last reply Reply Quote 0
        • muhac80undefined
          muhac80 @Phaedrux
          @phaedrux Thank you.
          Other than the 3th link I looked at both links. I need detailed instruction on how to go through and fill the Configuration Tool; https://configtool.reprapfirmware.org/Start
          For instance: I know my heated bed's dimensions but I don't know what should I enter in 'Homing Speed' section or 'Axes' section (microstepping, steps per mm, MAx change speed, etc., I don't want to enter all the details but I am not sure how and where to extract these values from).
          Again, my 3D is DIY cartesian. Thank you.
            Well the defaults in the config tool are safe. Some things you may not know exactly at first, but you'll be able to get it straightened out during commissioning.
            See this section: https://duet3d.dozuki.com/Guide/Ender+3+Pro+and+Duet+Mini+5++Guide+Part+2:+Configuration/88
            • muhac80undefined
              muhac80 @Phaedrux
              @phaedrux said in Duet 2 wifi configuration for Cartesian:
              Excellent link. Thank you. I will post if I have any questions.
