Duet 2 Wifi + Bltouch
Hi I have a problem with Bltouchen I can not get it to work!
Uses heater 3
Has an Ender 5 Plus with Micro swiss direct drive and bltouch X-50 Y-11.02 Z0
Anyone that can help me ?min Confi fil
; generated by RepRapFirmware Configuration Tool v3.2.2 on Wed Feb 03 2021 12:12:49 GMT-0500 (Eastern Standard Time); General preferences
M550 P"Ender 5 Plus" ; set printer name; Network
M552 S1 ; enable network
M586 P0 S1 ; enable HTTP
M586 P1 S0 ; disable FTP
M569 P3 S0 ; physical drive 3 goes backwards
M92 X80.00 Y80.00 Z800.00 E156.47 ; set steps per mm
M566 X900.00 Y900.00 Z80.00 E120.00 ; set maximum instantaneous speed changes (mm/min)
M203 X6000.00 Y6000.00 Z300.00 E1200.00 ; set maximum speeds (mm/min)
M201 X500.00 Y500.00 Z30.00 E250.00 ; set accelerations (mm/s^2)
M906 X800 Y800 Z800 E800 I30 ; set motor currents (mA) and motor idle factor in per cent
M208 X350 Y350 Z400 S0 ; set axis maxima; Endstops
M574 X1 Y1 S1 ; X home to min. Y home to max. NC microswitches.
M574 Z1 S2 ; Define Z to use Probe. Home to Min.
M558 P9 C"^zprobe.in" H5 F100 T2000G31 X0 Y0 Z 0 P25
M307 H3 A-1 C-1 D-1
M558 P9 C"^zprobe.in" H5 F120 T7200
G31 P500 X35 Y4 Z2.1
M950 S0 C"duex.pwm1" ; disable Z probe but set dive height, probe speed and travel speed
M557 X15:215 Y15:195 S20 ; define mesh grid
G31 X0 Y0 Z0 P25
M307 H7 A-1 C-1 D-1 ; Disable the 7th Heater to free up PWM channel 5 on the Duex board.
M143 H1 S280 ; set temperature limit for heater 1 to 280C; Fans
M106 P1 S1 H1 T45 ; set fan 1 value. Thermostatic control is turned on; Tools
M911 S10 R11 P"M913 X0 Y0 G91 M83 G1 Z3 E-5 F1000" ; set voltage thresholds and actions to run on power loss -
@btj Try something like this:
config.g
; Z-Probe M950 S0 C"duex.pwm1" ; create servo pin 0 for BLTouch M558 P9 C"^zprobe.in" H5 F120 T12000 ; set Z probe type to bltouch and the dive height + speeds G31 P500 X-50 Y-11.02 ; set Z probe trigger value, offset and trigger height M557 X15:215 Y15:195 S20 ; define mesh grid
deployprobe.g
M280 P0 S10 ; deploy BLTouch
retractprobe.g
M280 P0 S90 ; retract BLTouch
If anything else isn't right, please explain what does not work.
@chrishamm
Gets this Wrong message
M280 P0 S10
Error: M280: Invalid servo index 0 in M280 command -
@btj What do you get when you run M950 S0 C"duex.pwm1"?
@chrishamm said in Duet 2 Wifi + Bltouch:
M950 S0 C"duex.pwm1
M950 S0 C"duex.pwm1
Warning: M950 command is not supported -
@btj It sounds like you are still using RRF2, so it may be a good idea to upgrade to RRF3. If you don't want to upgrade, see https://duet3d.dozuki.com/Wiki/Connecting_a_Z_probe#Section_Software_setup_Duet_2_WiFi_Ethernet_running_RepRapFirmware_Num_2 for further instructions.
@btj Your config.g is a mix of commands for RepRapFirmware 2 and RepRapFirmware 3. Please send M115 and post response, so we can see what firmware version you are running. Then we can best advise you on the correct commands.
@droftarts
M115
FIRMWARE_NAME: RepRapFirmware for Duet 2 WiFi/Ethernet FIRMWARE_VERSION: 2.05.1 ELECTRONICS: Duet WiFi 1.02 or later FIRMWARE_DATE: 2020-02-09b1 -
@btj said in Duet 2 Wifi + Bltouch:
If you're not planning on updating the firmware to the current version (v3.3, but see update instructions here: https://duet3d.dozuki.com/Wiki/Installing_and_Updating_Firmware#Section_Updating_from_RRF_2_x_to_3_x ), then it will be easiest to regenerate your configuration files using the Configuration tool https://configtool.reprapfirmware.org/Start
This is because you have generated a configuration for RRF 3, see first line of your config.g:; Configuration file for Duet WiFi (firmware version 3)
I expect currently none of your temperature responses will be correct, fans won't work, and there will be no tool, as well as the probe not working. All the lines in config.g that have C or P parameter with "[something in quotes]" will need to change, so it's easier to regenerate the files with the correct firmware version selected. On the https://configtool.reprapfirmware.org/General page, under "Firmware version:" make sure you select "2.03 to 2.05".
If you want to update to RRF v3.3, your existing config should work, but you need to tidy up your Z-probe configuration. See @chrishamm's post earlier.
@droftarts
M115
FIRMWARE_NAME: RepRapFirmware for Duet 2 WiFi/Ethernet FIRMWARE_VERSION: 3.0 ELECTRONICS: Duet WiFi 1.02 or later FIRMWARE_DATE: 2020-01-03b3 -
Now update to RRF v3.3. https://github.com/Duet3D/RepRapFirmware/releases/tag/3.3
@droftarts
M115
FIRMWARE_NAME: RepRapFirmware for Duet 2 WiFi/Ethernet FIRMWARE_VERSION: 3.3 ELECTRONICS: Duet WiFi 1.02 or later FIRMWARE_DATE: 2021-06-15 21:45:03 -
@btj Have you made any changes to your config.g? If so, please post your current config.g.
From your earlier config.g, you will need to change your Endstop and Z-Probe sections. They should look something like this:; Endstops M574 X1 S1 P"xstop" ; configure active-high endstop for low end on X via pin xstop M574 Y1 S1 P"ystop" ; configure active-high endstop for low end on Y via pin ystop ; Z-Probe M950 S0 C"exp.heater3" ; create servo pin 0 for BLTouch M558 P9 C"^zprobe.in" H5 F120 T6000 ; set Z probe type to bltouch and the dive height + speeds G31 P500 X0 Y0 Z2.5 ; set Z probe trigger value, offset and trigger height
Remove these lines:
M574 Z[anything]
M307 H3 A-1 C-1 D-1
Any other M950, M558 and G31 linesThen post your config.g so we can check it.
@droftarts
M574 X1 S1 P"xstop" ; X min active high endstop switch
M574 Y1 S1 P"ystop" ; Y min active high endstop switch
M574 Z1 S1 P"zstop" ; Z min active high endstop switch
M574 U2 S1 P"e0stop" ; U max active high endstop switch
Z-Probe
M307 H3 A-1 C-1 D-1
G31 X-50 Y-11.02 Z 0 P25
G31 X0 Y0 Z 0 P25
Z-Probe
M307 H3 A-1 C-1 D-1
M140 H0 ; map heated bed to heater 0Remove:
G31 X0 Y0 Z 0 P25
M307 H3 A-1 C-1 D-1
M307 H7 A-1 C-1 D-1 ; Disable the 7th Heater to free up PWM channel 5 on the Duex board.Ian
