    Tevo Little Monster stepper motor move only in one direction
    Using Duet Controllers
    1.5k
    • linus4200undefined
      linus4200
      I just got a brand new TLM which I could not get running with MKS. Therefore rather than to dive deep into MKS I decided to purchase a Original Duet Wifi that arrived yesterday. After following the Tutorial on YOUTUBE " How to Install a DUET board on a Delta Style 3D Printer - The TEVO Little Monster" I was able to reach the DWC 3 and to upload the config and firmware.
      However arriving at the HOME ALL "STEP", I noticed, that I do not have the Home x , y , z button only HOME ALL. After clicking HOME ALL the print head started moving very slowly with a wired noise and got stacked as the z-axis did not move and I switched of before I enter into more problems.
      To find out what is going on, I followed a tutorial to check if the
      different stepper motors even move. So I remove the belt and
      by using G91 and G1 H2 X10 F1OO ...G1 H2 X-10 G1 H2 Y10 ....
      I tried to check if the stepper motors were "moving". Well the result is for me wired noise joining the fact, that beside of a movement in only one direction for X10 and X-10 etc.. it gave
      a sensation of vibration of the pulley.
      I would highly appreciate any hint to come out of the sh...
      If for that one need files, just ask , as I do not know
      what might be needed.
      For any help thank you very much.
      linus
      attached: DWC-TLM DWC-TLM.jpg
        @linus4200 said in Tevo Little Monster stepper motor move only in one direction:
        It sounds like the motors might not be connected properly, or somehow misconfigured.
        Check your motor phases are wired correctly: https://duet3d.dozuki.com/Wiki/Choosing_and_connecting_stepper_motors#Section_Identifying_the_stepper_motor_phases
        Please copy and paste your config.g, homedelta.g, bed.g files.
        Also send M122 and M98 P"config.g" in the gcode console and copy and paste the results here.
        This will give us some more insight into what is actually happening on your printer.
        For setting up a delta you should take a look at these guides as well.
        https://duet3d.dozuki.com/Wiki/ConfiguringRepRapFirmwareDeltaPrinter
        https://duet3d.dozuki.com/Wiki/Calibrating_a_delta_printer
        linus4200undefined Phaedruxundefined 2 Replies Last reply Reply Quote 0
          linus4200 @Phaedrux
          @phaedrux
          Thank you very much for your prompt reply, please find below the
          required information:
          config.g :
          ; generated by RepRapFirmware Configuration Tool v3.3.0 on Sun Aug 08 2021 03:13:57 GMT+0200 (Central European Summer Time)
          M550 P"TLM" ; set printer name
          M665 R155 L397.19 B155 H520 ; Set delta radius, diagonal rod length, printable radius and homed height
          M666 X0 Y0 Z0 ; put your endstop adjustments here, or let auto calibration find them
          M552 S1 ; enable network
          M586 P0 S1 ; enable HTTP
          M586 P1 S1 ; enable FTP
          M586 P2 S1 ; enable Telnet
          M92 X80.00 Y80.00 Z80.00 E663.00 ; set steps per mm
          M566 X1200.00 Y1200.00 Z1200.00 E1200.00 ; set maximum instantaneous speed changes (mm/min)
          M203 X18000.00 Y18000.00 Z18000.00 E1200.00 ; set maximum speeds (mm/min)
          M201 X1000.00 Y1000.00 Z1000.00 E1000.00 ; set accelerations (mm/s^2)
          M906 X1400 Y1400 Z1400 E1400 I30 ; set motor currents (mA) and motor idle factor in per cent
          M84 S30 ; Set idle timeout
          M208 Z0 S1 ; set minimum Z
          M574 Z1 S1 P"zstop" ; configure active-high endstop for low end on Z via pin zstop
          G31 P500 X0 Y0 Z2.5 ; set Z probe trigger value, offset and trigger height
          M557 R150 S45 ; define mesh grid
          M106 P2 S1 H1 T45 ; set fan 2 value. Thermostatic control is turned on
          homedelta.g:
          ; homedelta.g
          G91 ; relative positioning
          ;*** Slow homing has been configured. Change F180 to F1800 below when your configuration is working
          G1 H1 X705 Y705 Z705 F180 ; move all towers to the high end stopping at the endstops (first pass)
          G1 H2 X-5 Y-5 Z-5 F1800 ; go down a few mm
          ;*** Slow homing has been configured. Change F180 to F360 below when your configuration is working
          G1 H1 X10 Y10 Z10 F180 ; move all towers up once more (second pass)
          G1 Z-5 F6000 ; move down a few mm so that the nozzle can be centred
          G90 ; absolute positioning
          G1 X0 Y0 F6000 ; move X+Y to the centre
          bed.g;
          ; bed.g
          ; called to perform automatic delta calibration via G32
          ; Probe the bed at 3 peripheral and 3 halfway points, and perform 6-factor auto compensation
          ; Before running this, you should have set up your Z-probe trigger height to suit your build, in the G31 command in config.g.
          G30 P0 X0 Y84.9 H0 Z-99999
          G30 P1 X73.53 Y-42.45 H0 Z-99999
          G30 P2 X-73.53 Y-42.45 H0 Z-99999
          G30 P3 X0 Y42.4 H0 Z-99999
          G30 P4 X36.72 Y-21.2 H0 Z-99999
          G30 P5 X-36.72 Y-21.2 H0 Z-99999
          G30 P6 X0 Y0 H0 Z-99999 S6
          ; Use S-1 for measurements only, without calculations. Use S4 for endstop heights and Z-height only. Use S6 for full 6 factors
          ; If your Z probe has significantly different trigger heights depending on XY position, adjust the H parameters in the G30 commands accordingly. The value of each H parameter should be (trigger height at that XY position) - (trigger height at centre of bed)
          M122
          RepRapFirmware for Duet 2 WiFi/Ethernet version 3.3 (2021-06-15 21:44:54) running on Duet WiFi 1.02 or later
          Board ID: 0JD0M-9P6B2-NJ4S8-6J1FJ-3S06S-T86UL
          Used output buffers: 3 of 24 (11 max)
          Static ram: 23876
          Dynamic ram: 74496 of which 0 recycled
          Never used RAM 16044, free system stack 184 words
          Tasks: NETWORK(notifyWait,13.6%,246) HEAT(delaying,0.0%,314) Move(notifyWait,0.1%,364) MAIN(running,85.6%,441) IDLE(ready,0.7%,29), total 100.0%
          Owned mutexes: WiFi(NETWORK) HTTP(MAIN)
          Last reset 00:02:28 ago, cause: power up
          Last software reset at 2021-08-07 21:01, reason: User, GCodes spinning, available RAM 16044, slot 0
          Error status: 0x00
          Step timer max interval 0
          MCU temperature: min 17.1, current 23.9, max 24.3
          Supply voltage: min 23.8, current 24.0, max 24.4, under voltage events: 0, over voltage events: 0, power good: yes
          Driver 0: position 70856, standstill, SG min/max not available
          Driver 1: position 70856, standstill, SG min/max not available
          Driver 2: position 70856, standstill, SG min/max not available
          Driver 5: position 0
          Driver 6: position 0
          Driver 7: position 0
          Driver 8: position 0
          Driver 9: position 0
          Driver 10: position 0
          Driver 11: position 0
          Date/time: 2021-08-08 11:58:59
          Slowest loop: 5.35ms; fastest: 0.17ms
          === Storage ===
          Free file entries: 10
          SD card longest read time 4.0ms, write time 0.0ms, max retries 0
          === MainDDARing ===
          === AuxDDARing ===
          Segments left: 0
          Movement lock held by null
          HTTP is ready with "M122 " in state(s) 0
          Telnet is idle in state(s) 0
          File is idle in state(s) 0
          USB is idle in state(s) 0
          Aux is idle in state(s) 0
          Trigger is idle in state(s) 0
          Queue is idle in state(s) 0
          LCD is idle in state(s) 0
          Daemon is idle in state(s) 0
          Code queue is empty.
          === Network ===
          Slowest loop: 80.32ms; fastest: 0.00ms
          HTTP sessions: 1 of 8
          • WiFi -
            Network state is active
            WiFi firmware version 1.26
            WiFi MAC address 24:a1:60:2d:ff:ff
            WiFi Vcc 3.43, reset reason Turned on by main processor
            WiFi flash size 4194304, free heap 23216
            WiFi IP address 192.168.1.33
            WiFi signal strength -65dBm, mode 802.11n, reconnections 0, sleep mode modem
            Clock register 00002002
          M98 P"config.g"
          HTTP is enabled on port 80
          FTP is enabled on port 21
          TELNET is enabled on port 23
          This is with belts not mounted (as I tried if the stepper motor even turn, which they do in one direction only).
          Thanks for the help.
          linus
          P.S. : Might it be a problem of the Stepper Motors ? Only info I have is whats written on them : RB STEP MOTOR 42SHDC6022-Z26B - LOT NO. 190402
            Phaedrux Moderator @linus4200
            Your endstop positions are incorrect for a delta. X1 Y1 Z1 means low end of travel. They should be X2 Y2 Z2 for the high end of the towers.
            Once that is fixed your homing should produce the right results.
              linus4200
              Thank you very much. One issue less. I changed it as per your instruction and pressed the home all button. Result the x+ y
              motor slowly lowering their position while z did not move nothing and consequently by lowering the x and y axis without the z axis results in crashing against the z aluminum profile of the printer and trying to move even further.
              Moreover I manually moved the "print head" into the home position and pushed again home all and a small movement
              and then stopped. Thereafter I used DWC to try if there is any
              movement on x, y and z axis. Indeed it moved but only in one direction using x+ or x- .... . Any idea why?
              With reference to the motors themselves do I have the change the current? to get a "fluid" movement?
              Thanks for your help, without that I would not know what to do.
              linus
              P.S.: Might it be that even being a new printer the stepper motors are broken ? How to check this? Attached a video
              to better understand my problem.
              TLM_HOME_ALL_RESULT_2.mp4
                linus4200
                Dear @PHAEDRUX,
                I thought with reference to eventual wiring mistakes it might come handy to make some photos. Therefore please find the photos attached. I hope it helps. Thank you very much.
                Linus
                13F46F83-3376-4A2B-94A2-AAA441568145.jpeg 7A040EB5-0834-4815-9356-E9E0B0966F9C.jpeg CA228D97-C474-4BBE-AF5E-87BC1220699F.jpeg B18C7045-1C90-4113-8878-E5B0DCA6EAB1.jpeg BA3D6BFD-65B9-4A3B-BC1D-C4CB07754140.jpeg
                  linus4200
                  I forgot
                    Phaedrux Moderator @Phaedrux
                    @phaedrux said in Tevo Little Monster stepper motor move only in one direction:
                    Did you check the motor phase pairs?
                    Now with the endstop corrected if you remove the belts from the motor shafts and try to move the motors, does it spin correctly?
                    To see if you can get them to move without homing first, send G92 X100 Y100 Z100 and then try to issue movement commands for each motor individually by sending
                    G91
                    G1 H2 X10
                    G1 H2 X-10
                    G1 H2 Y10
                    G1 H2 Y-10
                    G1 H2 Z10
                    G1 H2 Z-10
                    linus4200undefined 2 Replies Last reply Reply Quote 0
                      linus4200 @Phaedrux
                      @phaedrux
                      Thanks for the reply. Following your advise I and lowering the current from 1000mA to 800mA and up to 1500mA by executing G92 X100 Y100 Z100 and then G91 H2 X10 I got a movement on down (attached files) and by using G91 H2 X-10 the exact same result and the same direction.
                      As far as I understand I should have had a movement in two directions up&down. How can it be that in my case all three motors move down x10 and x-10, y10 and y-10 and z10 and z-10 for both commands? Any hint ?Thanks
                      linus
                      P.S. : Attached Motor Info
                      [0_1628509204934_DUET TLM.zip](Uploading 100%)
                        linus4200 @Phaedrux
                        @phaedrux stepper motor tech sheet.jpg stepper motor.jpg IMG_1272.mp4 IMG_1271.mp4 IMG_1270.mp4 IMG_1270.mp4 IMG_1269.mp4 IMG_1268.mp4 IMG_1266.mp4 IMG_1265.mp4 IMG_1264.mp4 IMG_1263.mp4 IMG_1262.mp4
                        engikeneerundefined 1 Reply Last reply Reply Quote 0
                        • engikeneerundefined
                          engikeneer @linus4200
                          @linus4200 did you check your motor phases like @Phaedrux asked?
                          Most likely you've got one of them switched. You need to use a multimeter to check them (as shown in the guide).
                          i3 clone with a bunch of mods
                          linus4200undefined 1 Reply Last reply Reply Quote 0
                            linus4200 @engikeneer
                            @engikeneer
                            Thank you very much to both of you, as without your help, I would never ever have expected, that, purchasing a new printer, they deliver it, without wiring correctly the stepper motor and as consequence only one phase is working.
                            With reference to the Home All Button. Does the procedure HOME ALL has to be successfully be executed for the Home X,Y & Z Button to appear on the Dashboard? Once again, thank you for your assistance. I did not expected to get proven the proverb " someone is to poor to buy cheap" so soon. Thanks.
                            linus
                              @linus4200 I've seen the phases paired wrongly before but not that! Glad you fixed it though 🙂
                              For a delta, you only ever do homeall to home all towers at once. If you home one tower on its own while the others were at the bottom you'd rip your effector in two! Separate homex, homey, homez are for cartesian/corexy printers
                                linus4200
                                @engikeneer
                                By using the home all button x and y move towards the end-stop while z does not move, which could break the rods, if I do not switch off before. Is this still related to my former problem or
                                do I miss something?
                                linus
                                  @linus4200 well that means you have another issue...
                                  First, follow @Phaedrux's previous advice and check if all three of your motors spin at all:
                                  G91
                                  G1 H2 X10
                                  G1 H2 X-10
                                  G1 H2 Y10
                                  G1 H2 Y-10
                                  G1 H2 Z10
                                  G1 H2 Z-10
                                  From this you should see if they all move, and double-check they are spinning in the correct direction.
                                  After you have done that, you can check if your endstops are working correctly. With the carriages away from the endstops (i.e. so the endstops aren't pressed), send M119 via the console in DWC. You should get a response like this, showing that the endstops are not pressed:
                                  Now press & hold each of the endstop switches in turn and see if they react by sending M119 again. You should get something like this for each saying it's at the 'max stop' (in this one I'm pressing the Z endstop switch)
                                  Do both of those sets of tests and let us know the results andwe can help you from there 🙂
                                  linus4200undefined 1 Reply Last reply Reply Quote 1
                                    @engikeneer said in Tevo Little Monster stepper motor move only in one direction:
                                    G91
                                    G1 H2 X10
                                    G1 H2 X-10
                                    G1 H2 Y10
                                    G1 H2 Y-10
                                    G1 H2 Z10
                                    G1 H2 Z-10
                                    Dear @engikeneer please find attached the result of what I should try.
                                    Moreover you find what happens clicking home all. I think the video
                                    explains it better than I could do in writing. Thanks
                                    linus
                                    DWC_M119_01.jpg DWC_M119_02.jpg G91_G1 H2 X10.....mp4 HOME_ALL.mp4
                                      I see your photos and video, but I don't have any context for them. What's happening exactly?
                                      The video looks like you've got movement working in both directions now?
                                      In your photos, it looks like you've tested the endstops.. And they respond appropriately to being triggered? Do they also match the towers as expected? See here: https://duet3d.dozuki.com/Wiki/ConfiguringRepRapFirmwareDeltaPrinter#Section_Testing_the_motors_and_endstops_individually
                                      The big red error message in your photos. When does that pop up?
                                        @linus4200 in both pictures, it says Z at max stop. If you weren't pressing the Z endstop in the first picture, that means you have a problem with the z endstop.
                                        Check the wiring and repeat that test until you see the z endstop working properly. There's some more details in the guide page that @Phaedrux has posted
                                          linus4200 @Phaedrux
                                          Dear @Phaedrux
                                          The Fotos and Video correspond to the previous post of @engikeneer to check result
                                          Of m119 and to execute G1H2 X10, G1 H2 C-10 then the same for Y&Z to check motor movement and the “home all” video shows what happened clicking the home all button, as you can see there, x and y carriage move up to the endstop while the z carriage does not move. I hope I checked correctly. Thank you very much
                                          Linus
                                          Phaedruxundefined giostarkundefined 2 Replies Last reply Reply Quote 0
                                            This would be explained by the endstop status always reading as triggered as @engikeneer mentioned. So check your endstops wiring for Z.
