    Accelerometer vs. racking?
    354
    • o_lampeundefined
      o_lampe
      Hi gents,
      would it be possible to show any racking issues with the LIS3D(S)H boards?
      I think of a cantilevered axis, where I'd put the sensor to both sides at a time.
      Background is the #-printer I'm currently building and how to proof the functionality of the dual roller constraint. (dialing in the fishing line tension)
      THX for reading
      dc42undefined zaptaundefined 2 Replies Last reply Reply Quote 0
        dc42 administrators @o_lampe
        @o_lampe you cold collect data during a long move, then in the raw acceleration data look for sudden changes in the acceleration along that axis.
        • o_lampeundefined
          o_lampe @dc42
          Thanks, that was my plan too
          I wish we could overlay different .cvg files in the new DWC-plugin...
            @o_lampe said in Accelerometer vs. racking?:
            That's coming.
            • zaptaundefined
              zapta @o_lampe
              Can you explain what you would like to measure? My understanding is that 'racking' error is a non parallelism or non 'perpendicularism' between lines or planes but I don't know for sure.
              DIY-O-Sphereundefined 1 Reply Last reply Reply Quote 0
              • DIY-O-Sphereundefined
                DIY-O-Sphere @zapta
                @zapta
                I think this is can done via acceleration.
                If the axes are not rectangular, on a acceleration along a single orientation you will also get values in more than this orientation.
                (UTC+1)
                zaptaundefined 1 Reply Last reply Reply Quote 0
                • zaptaundefined
                  zapta @DIY-O-Sphere
                  @diy-o-sphere, I see, you want to measure absolute or relative direction of movements within the sensor XY(Z) coordinate system.
                  What kind of angular accuracy is expected from a sensor such as the LIS3D?
                  I guess that the accuracy can be improved by aggregating multiple measurements.
                  Edit: found this one which claims 0.05 deg accuracy which I think is impressive, if true. https://www.amazon.com/WT901BLECL-Accelerometer-Acceleration-Low-Consumption-Compatible/dp/B07T2C97WN
                  • o_lampeundefined
                    o_lampe
                    @DIY-O-Sphere @zapta
                    Maybe racking is the wrong term, but what we definitely see is bouncing of the far end on a unsupported cantilevered axis.
