Carriage Adapter Suggestion for Rostock Max
So Dimensions are as follows,
Holes are 22mm centre to centre
Spigot is 6.32mm
The screw holding it is a 3mm self tapping screw with 8mm washer on -
So we should add two 6.32mm holes spaced 22mm apart horizontally. Can someone else confirm these dimensions? We'd like to get a good fit so that the carriage adaptor is horizontal automatically.
I downloaded the Model file that PlasticMetal linked to and confirmed the dimensions:
24.125mm center-to-center, and 6.35mm inner diameter
I'm not sure if these are all the same spacing, but the ball cup axle fits on two screws mounted to the carriage.
First two photos are the version 3 Rostock (the trick laser carriage as well) and the last is perhaps the v2 that didn't use ball cup joints.
https://imgur.com/8iOzxYZ.jpg
https://imgur.com/WE6CjT0.jpg
https://imgur.com/KZxVUOv.jpgJust a correction as the later V2 came with the upgraded ball cup arms.
