    Mimic 5 point bed levelling in DWC
    Duet Web Control
    • TimsWorkshopundefined
      TimsWorkshop
      Hi All... I can't get my BTT TFT to work, on neither of the screens and while i wait for some PanelDue screens to arrive, is there a way I can simulate the 5 point bed levelling function from the menu in DWC?
      Is there an exisitng macro or DWC plugin I can use?
      Ender 5 Plus - E3D Hemera Hotend - Duet 2 Wifi
      engikeneerundefined 1 Reply Last reply Reply Quote 0
        I'm not sure what you mean by 5 point leveling. Things like that are controlled by bed.g and G32. Also, defined point plane compensation isn't recommended anymore. Instead we recommend you use G29 and mesh compensation. If you want a simple plane, just use a minimum of points like 4 or 9 to get an approximation of the old style.
        https://duet3d.dozuki.com/Wiki/Using_mesh_bed_compensation
        • engikeneerundefined
          engikeneer @TimsWorkshop
          @infidelprops for the bed levelling, do you mean probing the bed and the printer telling you how much to adjust each of the bed adjustment screws?
          This would be using the manual bed levelling assistant with G32 & bed.g like @Phaedrux mentioned:
          https://duet3d.dozuki.com/Wiki/Using_the_manual_bed_levelling_assistant
          i3 clone with a bunch of mods
          TimsWorkshopundefined 1 Reply Last reply Reply Quote 1
            TimsWorkshop @engikeneer
            @engikeneer & @Phaedrux - thanks and yes... a way to manual adjust my screws while I wait for my TFTs to arrive because currently I turn them the printer off and adjust as required.. a bit more work, but doable.
            Just read the article and that looks like the ticket, thanks. I'll read through that and adjust as neccessary.
