    G92 command no longer works
    • luckyflyerundefined
      luckyflyer
      My slicer ending script uses G92 commands in the ending script. Recently I've noticed that Y does not move to its commanded position. When I enter any G92 command from the console (example G92 Y300) nothing happens. What do I do to fix this?
      jay_s_ukundefined gloomyandyundefined 2 Replies Last reply Reply Quote 0
        jay_s_uk @luckyflyer
        @luckyflyer G92 isn't a movement command
        https://duet3d.dozuki.com/Wiki/Gcode#Section_G92_Set_Position
        • gloomyandyundefined
          gloomyandy @luckyflyer
          @luckyflyer Are you sure that your interpretation of G92 is correct. Looking at the gcode definition: https://duet3d.dozuki.com/Wiki/Gcode#Section_G92_Set_Position The command simply allows you to specify that the axis is currently at a particular position. In particular it states "No physical motion will occur". So I would not expect any motion from that command.
            luckyflyer
            Ok, don't know what's going on here, seems like it did move Y to 300. Clearly you are correct regarding that command.
