    How to connect PanelDue to Mini5P?
    196
    • zaptaundefined
      zapta
      I would like to connect a paneldue (5i, 4 wires cable) to a Mini5P but am not sure how.
      Is there a 4 pin kk connector to do so (this is the cable termination I have from the Duet2 WiFi)?
      If not, do I need to connect the 10 pin PanelDue connector (see below)? What kind of a connector is a good fit there for a 4 wires cable there (Preferably a crimp connector rather than IDC)?
      Thanks.
      Nurgelrotundefined 1 Reply Last reply Reply Quote 0
        Use IO_0
        https://duet3d.dozuki.com/Wiki/Duet_3_Mini_5plus_Hardware_overview#Section_Connecting_a_PanelDue
        zaptaundefined 2 Replies Last reply Reply Quote 0
        • Nurgelrotundefined
          Nurgelrot @zapta
          @zapta The 4 wire serial cable for a PanelDue goes to IO.0 on a mini5 please see the duet3 section @ https://duet3d.dozuki.com/Wiki/Connecting_an_LCD_control_panel#Section_Duet_Num_3
          Nurgelrotundefined 1 Reply Last reply Reply Quote 1
            Nurgelrot @Nurgelrot
            This post is deleted!
            • zaptaundefined
              zapta @Phaedrux
              @phaedrux, @Nurgelrot, thanks. That's what I was looking for. It's a kk crimp connector so should be easy to connect.
              BTW, may be helpful to add the word 'PanelDue' near that connector in the wiring diagram.
              https://duet3d.dozuki.com/Wiki/Duet_3_Mini_5plus_Wiring
              • zaptaundefined
                zapta @Phaedrux
                @phaedrux, I can't get the paneldue to connect to the Mini5p. It turns on as expected, saying 'connecting', I can see with an oscilloscope that it sends every few seconds some data, probably trying to connect, but there is no response from the Mini5P.
                My config.g is very simple and I can connect from DWC.
                M552 S1   ; Enable network
                M575 P1 S1 B9600                              ; enable support for PanelDue
                PanelDue baud rate is set to 9600, firmware 1.24, connected to IO_1.
                I tested the pin IO_1/io1.out with the paneldue disconnected and it seems to act as an input, rather than an output as it should (?). A 3.3k pullup resistor to 3.3v brings its voltage to 3.3V and a 3.3K pulldown resistor to ground brings it voltage to 0v.
                Any suggestions?
                  You must use io_0
                  zaptaundefined 1 Reply Last reply Reply Quote 0
                  • zaptaundefined
                    zapta @Phaedrux
                    Thanks @phaedrux. IO0 does work. I guess I should have read the previous posts here more carefully.
