    Fine tunning thermistor
    • peirofundefined
      peirof
      i have notice, that the temperature measured by Duet of nozzle, its not the same measured with a termometer
      Supposing the temperature with termometer, its ok.... what i have change in M303
      Duet measured temperature 180º, measured with termometer (supossed real) 193º.
      I think remember that its dificult, and there is a graph curves....
      There is some method for adjust thermistors
      Thx
      • SIamundefined
        SIam
        You can calibrate your thermistor with this documentation:
        https://duet3d.dozuki.com/Wiki/Calibrating_thermistor_and_PT1000_readings
        Hypercube-Evolution-Hybrid, Piezo Orion, Orbiter
        Duet WiFi 1.02 or later + DueX5
        RepRapFirmware for Duet 2 WiFi/Ethernet 3.4.0beta4 (2021-09-27 11:30:36)
        Duet WiFi Server: 1.26
        Duet Web Control 3.4.0beta4 (2021-09-27)
        peirofundefined 1 Reply Last reply Reply Quote 0
        • peirofundefined
          peirof @SIam
          @siam
          eee...., Houston we have a problem...
          some time ago, I bought replacement temperature sensors.
          I remember buying Thermistors and PT1000.
          The problem that now I do not remember which is which.
          Is there any method to know if it is a Thermistor or a PT1000?
            jay_s_uk @peirof
            @peirof a PT1000 measures as 1000 ohm at 0 degrees. A thermistor typically measures 100000 ohm at 0 degrees
