    InputShaping-Plugin-0.1.0-rc6 released
    Plugins for DWC and DSF
    11
    35
    2.8k
    • mfs12undefined
      mfs12
      EXPERIMENTAL!!!
      Hey, this is a very experimental release for all who don't have a project yet for the weekend... 😉
      It brings basic session handling. It allows to compare graphs with each other. This should allow quicker and easier evaluation of inputshaping algorithms.
      Session handling is still work in progress!!! So don't be to strict and leave a comment or any other feedback about it.
      Enjoy your weekend!
      Release Notes inputshaping-plugin-0.1.0-rc6
      Features
      • setting parameters for recording accelerometer profile
      • start recording accelerometer profile
      • automated download and analysis of the recorder profile
      • preset of ringing frequency with the maximum amplitude
      • setting of input shaping parameters
      • added german translation
      • improved setting of initial record profile parameters
      • changed order of profile commands
      • added support to show multiple profile graphs in one chart
      Bugs
      • fixed list of available input shaping algorithm
      • fixed order of profile commands
      Downloads
      Downloads can be found at https://github.com/mfs12/DuetWebControl/releases/tag/inputshaping-plugin-0.1.0-rc6
      Visit me on github at https://github.com/mfs12/
      SIamundefined Heartleander81undefined CaiJonasundefined CadetCundefined GeneRisiundefined 5 Replies Last reply Reply Quote 2
      • SIamundefined
        SIam @mfs12
        @mfs12 first the good news, 😉 the support to show multiple profile graphs in one chart seems to work so far but setting of input shaping configuration here is the frequency always 0Hz
        Hypercube-Evolution-Hybrid, Piezo Orion, Orbiter
        Duet WiFi 1.02 or later + DueX5
        RepRapFirmware for Duet 2 WiFi/Ethernet 3.4.0beta4 (2021-09-27 11:30:36)
        Duet WiFi Server: 1.26
        Duet Web Control 3.4.0beta4 (2021-09-27)
        • Heartleander81undefined
          Heartleander81 @mfs12
          @mfs12
          Is there a guide on how to install plugins in DWC?
          Have never done that before
          SIamundefined 1 Reply Last reply Reply Quote 0
          • SIamundefined
            SIam @Heartleander81
            @heartleander81 it's the same way when you update the board click on the button upload system files and select the plugin archive.
            Then go to settings -> Machine Specific -> External Plugins and Activate the Plugin
            Heartleander81undefined 1 Reply Last reply Reply Quote 0
              Heartleander81 @SIam
              @siam ok thank you. I test it
              [Edit]
              Ok thank you again.
              Unfortunately, it is not. I have Beta 3.4.0 Beta2 when installing it tells me DWC 3.3.0 is the prerequisite. It is installed but there will be a change due to the beta
              • SIamundefined
                @heartleander81 You need the 3.4.b2 because this is the first version with Input shaping types
                • CaiJonasundefined
                  CaiJonas @mfs12
                  @mfs12
                  thanks alot for your work.
                  Unfortunatelly I'm getting this message:
                  how can I solve this?
                  Best Regards
                  jay_s_ukundefined mfs12undefined 2 Replies Last reply Reply Quote 0
                    jay_s_uk @CaiJonas
                    @caijonas I get that too. I don't get than message if using the accelerometer plugin
                      @siam
                      I had done the SBC update but DWC 3.3.0 is still displayed. The board has firmware 3.4.0 Beta2 +. Wait until the next beta comes out. Thank you.
                      • SIamundefined
                        @heartleander81 have you installed DuetWebControl-SD.zip from the Release 3.4.0 beta 2 ?
                          jay_s_uk @SIam
                          @siam don't install that. it'll break DWC on an SBC build
                          • mfs12undefined
                            mfs12 @CaiJonas
                            @caijonas you get the error message "session does not match record's numer of samples" when you try to load different "records" with different numbers of samples.
                            Ususally you try to compare graphs from different recordings sessions where you were using different paramters. They are not comparable. At least so far.
                              jay_s_uk @mfs12
                              @mfs12 i get that message when loading different graphs recorded using the same parameters
                              mfs12undefined 1 Reply Last reply Reply Quote 0
                              • mfs12undefined
                                mfs12 @jay_s_uk
                                @jay_s_uk did one graph have overflows?
                                jay_s_ukundefined 2 Replies Last reply Reply Quote 0
                                  jay_s_uk @mfs12
                                  @mfs12 how do I verify that?
                                    jay_s_uk @mfs12
                                    @mfs12 just looked at the files and all 3 have no overflows
                                    input-shaping-0-Z-none.csv
                                    input-shaping-0-Y-none.csv
                                    input-shaping-0-X-none.csv
                                    • mfs12undefined
                                      mfs12
                                      @jay_s_uk if there were overflows you usually get asked. At least if it's the first record to load.
                                      Or download the files and count the lines 😉 on Linux/MacOS you can use "wc -l" for that.
                                      $ cat RECORDED_FILE.csv | wc -l
                                      Here's the check that is failing...
                                      https://github.com/mfs12/DuetWebControl/blob/ef667f55bcc6043a48eb72e2769726a9a9d5a8d4/src/plugins/InputShaping/InputShapingSession.js#L185
                                      • mfs12undefined
                                        mfs12
                                        just checked. the line counts are ok.
                                        • mfs12undefined
                                          mfs12
                                          @jay_s_uk but they are not exactly the same. you should get an sample rate error and not a sample number error.
                                          The files use different sample rates.
                                          ==> 1629703252758-input-shaping-0-z-none.csv <==
                                          Rate 1286, overflows 0
                                          ==> 1629703255890-input-shaping-0-y-none.csv <==
                                          Rate 1284, overflows 0
                                          ==> 1629703258730-input-shaping-0-x-none.csv <==
                                            jay_s_uk @mfs12
                                            @mfs12 so how so I adjust that? they were all recorded using the input shaper plugin
