    Using external driver expansion board with duet 2 wifi
    311
    • baird1faundefined
      baird1fa
      Hello. I’m planning to use the duet 2 wifi with the external driver expansion board and I just noticed that I need more digital inputs than than the available x,y,z,e0,e1 that are on the board. There are more inputs on the expansion header but they are not included on the external driver board.
      Any suggestion on how to use them or tie into them easily?
      fcwiltundefined o_lampeundefined 2 Replies Last reply Reply Quote 0
      • fcwiltundefined
        fcwilt @baird1fa
        @baird1fa
        Any particular reason you want to use a previous generation board?
        baird1faundefined 1 Reply Last reply Reply Quote 0
        • baird1faundefined
          baird1fa @fcwilt
          @fcwilt
          Cost. The duet 2 wifi is far less expensive than the duet 3 and it has a less expensive expansion board to run external drivers. The CAN boards for a single external stepper in addition to the duet 3 makes for a very expensive CNC board.
          fcwiltundefined dc42undefined 2 Replies Last reply Reply Quote 1
          • o_lampeundefined
            o_lampe @baird1fa
            @baird1fa said in Using external driver expansion board with duet 2 wifi:
            If there was an (male2female) 50pin extension cable, you could cut out the extra pins you require and solder wires to them.
            Or solder wires to the backside of the extension board.
            • fcwiltundefined
              fcwilt @baird1fa
              @fcwilt
              How many external steppers do you need?
              Will you be using the on-board stepper drivers?
              Thanks.
                dc42 administrators @baird1fa
                @baird1fa is Duet 3 Mini not suitable for your project?
                • baird1faundefined
                  baird1fa @fcwilt
                  @fcwilt
                  I’m using 4 external drivers to run 48 V to my Nema 34 steppers. I’m not using any of the on board steppers.
                  • baird1faundefined
                    baird1fa
                    @o_lampe
                    I’ve been scouring Amazon for such a thing but can only find a 40pin Version for the Rpi.
                    Do you know of such a beast?
                    • baird1faundefined
                      baird1fa @o_lampe
                      @o_lampe
                      I ended up ordering a long ribbon cable and just split some of the wires out. I don’t know how to post a photo or I would. Show what I did.
