    mid print stall RRF 3.4B2
    Beta Firmware
    576
    • Nuramoriundefined
      Nuramori
      I started a print before I headed to bed, only to wake up to a stalled print. This time it didn't say I had to restart, thereby not allowing me to pull a M122. This time I was able to get info. I hope this helps in getting to the root of the problem.
      8/23/2021, 9:44:05 AM	M122
      RepRapFirmware for Duet 3 MB6HC version 3.4.0beta2 (2021-08-03 12:42:33) running on Duet 3 MB6HC v0.6 or 1.0 (SBC mode)
      Board ID: 08DJM-956L2-G43S4-6J1F2-3SJ6T-1A6QH
      Used output buffers: 1 of 40 (11 max)
      Static ram: 151128
      Dynamic ram: 62432 of which 44 recycled
      Never used RAM 116716, free system stack 116 words
      Tasks: SBC(ready,8.2%,328) HEAT(delaying,0.2%,326) Move(notifyWait,14.4%,248) CanReceiv(notifyWait,0.1%,773) CanSender(notifyWait,0.2%,361) CanClock(delaying,0.1%,340) TMC(notifyWait,6.7%,59) MAIN(running,69.9%,922) IDLE(ready,0.2%,29), total 100.0%
      Owned mutexes: HTTP(MAIN)
      Last reset 17:29:49 ago, cause: power up
      Last software reset at 2021-08-21 08:17, reason: User, GCodes spinning, available RAM 117556, slot 0
      Software reset code 0x0003 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x00400000 BFAR 0x00000000 SP 0x00000000 Task SBC Freestk 0 n/a
      Error status: 0x00
      Aux0 errors 0,0,0
      Step timer max interval 201
      MCU temperature: min 20.5, current 43.9, max 45.1
      Supply voltage: min 0.1, current 23.3, max 23.9, under voltage events: 0, over voltage events: 0, power good: yes
      12V rail voltage: min 0.1, current 12.0, max 12.5, under voltage events: 0
      Heap OK, handles allocated/used 99/1, heap memory allocated/used/recyclable 2048/42/16, gc cycles 0
      Driver 0: position 88843, standstill, reads 590, writes 17 timeouts 0, SG min/max 0/1023
      Driver 1: position 5159, standstill, reads 590, writes 17 timeouts 0, SG min/max 0/1023
      Driver 2: position 13758, standstill, reads 587, writes 21 timeouts 0, SG min/max 0/1023
      Driver 3: position 0, standstill, reads 587, writes 21 timeouts 0, SG min/max 0/1023
      Driver 4: position 0, standstill, reads 591, writes 17 timeouts 0, SG min/max 0/1023
      Driver 5: position 0, standstill, reads 597, writes 11 timeouts 0, SG min/max 0/0
      Date/time: 2021-08-23 14:51:18
      Slowest loop: 83.40ms; fastest: 0.03ms
      === Storage ===
      Free file entries: 10
      DMs created 125, segments created 49, maxWait 66889ms, bed compensation in use: mesh, comp offset 0.000
      === MainDDARing ===
      Scheduled moves 886756, completed moves 886756, hiccups 0, stepErrors 0, LaErrors 0, Underruns [0, 0, 1], CDDA state -1
      === AuxDDARing ===
      Heater 0 is on, I-accum = 0.0
      Heater 1 is on, I-accum = 0.0
      Segments left: 1
      Movement lock held by null
      Telnet is idle in state(s) 0
      File* is doing "G1 X234.931000 Y209.278000 E2009.484741" in state(s) 0
      USB is idle in state(s) 0
      Aux is idle in state(s) 0
      Queue* is idle in state(s) 0
      LCD is idle in state(s) 0
      SBC is idle in state(s) 0
      Daemon is idle in state(s) 0
      Aux2 is idle in state(s) 0
      Code queue is empty
      === CAN ===
      Messages queued 2015045, received 756430, lost 0, longest wait 2ms for reply type 6049, peak Tx sync delay 60980, free buffers 49 (min 32), ts 314948/314943/0
      Tx timeouts 0,0,4,0,0,0 last cancelled message type 30 dest 127
      === SBC interface ===
      State: 4, failed transfers: 1, checksum errors: 0
      Last transfer: 2ms ago
      RX/TX seq numbers: 7163/7163
      SPI underruns 0, overruns 0
      Disconnects: 0, timeouts: 0, IAP RAM available 0x2c690
      Buffer RX/TX: 2016/3488-0
      === Duet Control Server ===
      Duet Control Server v3.4-b2
      File:
      Buffered code: G1 X234.931 Y209.278 E2009.48478
      Buffered code: G1 X234.581 Y209.323 E2009.49816
      Buffered code: G1 X181.713 Y156.455 E2012.33305
      Buffered code: G1 X181.729 Y156.618 E2012.33926
      Buffered code: G1 X181.729 Y156.635 E2012.33991
      Buffered code: G1 X181.741 Y156.877 E2012.3491
      Buffered code: G1 X181.744 Y157.024 E2012.35467
      Buffered code: G1 X234.11 Y209.389 E2015.16262
      Buffered code: G1 X233.662 Y209.479 E2015.17995
      Buffered code: G1 X181.742 Y157.559 E2017.96401
      Buffered code: G1 X181.706 Y157.966 E2017.9795
      Buffered code: G1 X181.696 Y158.05 E2017.9827
      Buffered code: G1 X233.214 Y209.568 E2020.74521
      Buffered code: G1 X232.849 Y209.642 E2020.75933
      Buffered code: G1 X232.849 Y209.544 E2020.76305
      Buffered code: G1 X232.674 Y209.566 E2020.76973
      Buffered code: G1 X181.626 Y158.518 E2023.50703
      Buffered code: G1 X181.581 Y158.757 E2023.51626
      Buffered code: G1 X181.581 Y158.763 E2023.51648
      Buffered code: G1 X181.534 Y158.963 E2023.52427
      Buffered code: G1 X232.197 Y209.626 E2026.24093
      Buffered code: G1 X231.721 Y209.687 E2026.25913
      Buffered code: G1 X181.42 Y159.386 E2028.95637
      Buffered code: G1 X181.403 Y159.443 E2028.95863
      Buffered code: G1 X181.379 Y159.521 E2028.96172
      Buffered code: G1 X181.288 Y159.787 E2028.97238
      Buffered code: G0 F7200 X181.287 Y159.791
      Buffered code: G1 F1620 X231.238 Y209.742 E2031.65086
      Buffered code: G1 X230.745 Y209.787 E2031.66963
      Buffered code: G1 X181.136 Y160.178 E2034.32977
      Buffered code: G1 X181.09 Y160.289 E2034.33432
      ==> 1496 bytes
      Pending code: G1 X180.991 Y160.503 E2034.34326
      Code buffer space: 1792
      Configured SPI speed: 8000000Hz
      Full transfers per second: 15.16, max wait times: 135.0ms/13.8ms
      Codes per second: 9.18
      Maximum length of RX/TX data transfers: 3196/1664
      File /opt/dsf/sd/gcodes/BLVMGNC300_Spool Holder Frame.gcode is selected, processing
      • Nuramoriundefined
        Nuramori
        After retrying to print, it happened again, this time very early in the print, at a completely different place. Here's the results of a M122 for both the toolboard and the main board.
        Main board, M122------
        8/23/2021, 3:39:02 PM	M122
        Static ram: 151128
        Dynamic ram: 62380 of which 44 recycled
        Never used RAM 116768, free system stack 138 words
        Tasks: SBC(resourceWait:,2.1%,326) HEAT(delaying,0.1%,326) Move(notifyWait,0.3%,250) CanReceiv(notifyWait,0.0%,773) CanSender(notifyWait,0.0%,365) CanClock(delaying,0.0%,340) TMC(notifyWait,31.3%,59) MAIN(running,65.7%,922) IDLE(ready,0.4%,29), total 100.0%
        Last reset 04:29:15 ago, cause: software
        Last software reset at 2021-08-23 16:17, reason: User, none spinning, available RAM 120220, slot 1
        Software reset code 0x0012 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x00400000 BFAR 0x00000000 SP 0x00000000 Task SBC Freestk 0 n/a
        Error status: 0x00
        Aux0 errors 0,0,0
        Step timer max interval 157
        MCU temperature: min 37.6, current 44.9, max 45.1
        Supply voltage: min 23.1, current 23.3, max 23.4, under voltage events: 0, over voltage events: 0, power good: yes
        12V rail voltage: min 12.0, current 12.0, max 12.1, under voltage events: 0
        Heap OK, handles allocated/used 99/1, heap memory allocated/used/recyclable 2048/26/0, gc cycles 0
        Driver 0: position 89208, standstill, reads 36346, writes 17 timeouts 0, SG min/max 0/1023
        Driver 1: position 22120, standstill, reads 36347, writes 17 timeouts 0, SG min/max 0/1023
        Driver 2: position 504, standstill, reads 36347, writes 17 timeouts 0, SG min/max 0/1007
        Driver 3: position 0, standstill, reads 36347, writes 17 timeouts 0, SG min/max 0/1023
        Driver 4: position 0, standstill, reads 36347, writes 17 timeouts 0, SG min/max 0/1023
        Driver 5: position 0, standstill, reads 36353, writes 11 timeouts 0, SG min/max 0/0
        Date/time: 2021-08-23 20:46:16
        Slowest loop: 82.42ms; fastest: 0.03ms
        === Storage ===
        DMs created 125, segments created 49, maxWait 23148ms, bed compensation in use: mesh, comp offset 0.000
        === MainDDARing ===
        Scheduled moves 8823, completed moves 8823, hiccups 0, stepErrors 0, LaErrors 0, Underruns [0, 0, 3], CDDA state -1
        === AuxDDARing ===
        Segments left: 1
        File* is doing "G1 X236.921005 Y209.658997 E2507.777100" in state(s) 0
        Code queue is empty
        === CAN ===
        Messages queued 154786, received 195093, lost 0, longest wait 2ms for reply type 6031, peak Tx sync delay 261, free buffers 49 (min 40), ts 80780/80779/0
        Tx timeouts 0,0,0,0,0,0
        State: 4, failed transfers: 0, checksum errors: 0
        RX/TX seq numbers: 36692/36692
        Buffer RX/TX: 2256/3728-0
        File:
        Buffered code: G1 X236.921 Y209.659 E2507.77701
        Buffered code: G1 X237.609 Y209.508 E2507.80371
        Buffered code: G1 X278.035 Y169.082 E2509.97144
        Buffered code: G1 X278.028 Y169.113 E2509.97264
        Buffered code: G1 X277.859 Y169.795 E2509.99929
        Buffered code: G1 X238.308 Y209.346 E2512.12009
        Buffered code: G1 X239.031 Y209.161 E2512.14839
        Buffered code: G1 X277.682 Y170.509 E2514.22097
        Buffered code: G1 X277.548 Y171.054 E2514.24225
        Buffered code: G1 X277.496 Y171.232 E2514.24928
        Buffered code: G1 X239.753 Y208.976 E2516.27316
        Buffered code: G1 X239.9 Y208.938 E2516.27892
        Buffered code: G1 X240.506 Y208.76 E2516.30287
        Buffered code: G1 X277.282 Y171.985 E2518.27485
        Buffered code: G1 X277.067 Y172.734 E2518.30439
        Buffered code: G0 F7200 X277.066 Y172.738
        Buffered code: G1 F1620 X241.266 Y208.537 E2520.22404
        Buffered code: G1 X241.629 Y208.431 E2520.23838
        Buffered code: G1 X241.71 Y208.405 E2520.2416
        Buffered code: G1 X242.049 Y208.293 E2520.25514
        Buffered code: G1 X276.811 Y173.531 E2522.11915
        Buffered code: G1 X276.555 Y174.323 E2522.15071
        Buffered code: G1 X242.853 Y208.025 E2523.95788
        Buffered code: G1 X243.514 Y207.805 E2523.9843
        Buffered code: G1 X243.666 Y207.75 E2523.99043
        Buffered code: G1 X276.263 Y175.153 E2525.73835
        Buffered code: G1 X275.956 Y175.997 E2525.7724
        Buffered code: G1 X244.52 Y207.434 E2527.45809
        Buffered code: G1 X245.238 Y207.168 E2527.48712
        Buffered code: G1 X245.382 Y207.109 E2527.49302
        Buffered code: G1 X275.613 Y176.878 E2529.11407
        ==> 1496 bytes
        Pending code: G1 X275.252 Y177.776 E2529.15077
        Code buffer space: 2088
        Full transfers per second: 38.78, max wait times: 62.6ms/16.8ms
        Codes per second: 0.68
        Maximum length of RX/TX data transfers: 3244/1640
        And the results of a M122 B20 for the toolboard -----
        8/23/2021, 3:39:43 PM	M122 B20
        Diagnostics for board 20:
        Duet TOOL1LC firmware version 3.4.0beta2 (2021-08-03 10:00:09)
        Bootloader ID: SAMC21 bootloader version 2.3 (2021-01-26b1)
        Never used RAM 2680, free system stack 2745 words
        Tasks: Move(notifyWait,0.1%,99) HEAT(delaying,0.8%,101) CanAsync(notifyWait,0.0%,57) CanRecv(notifyWait,0.1%,74) CanClock(notifyWait,0.1%,65) ACCEL(notifyWait,0.0%,61) TMC(notifyWait,9.2%,57) MAIN(running,73.8%,350) IDLE(ready,0.0%,27) AIN(delaying,16.0%,142), total 100.0%
        Last reset 04:35:49 ago, cause: power up
        Last software reset at 2021-08-23 15:12, reason: WatchdogTimeout, available RAM 2680, slot 0
        Software reset code 0x00a0 ICSR 0x14413011 SP 0x20007f28 Task MAIN Freestk 5938 ok
        Stack: 00000000 41000000 00000015 00000000 41000000 0000a78d 00016a4c 01000013 a5a5a5a5 00000000 20003324 20003360 20003364 fffffffd a29e9d69 00000000 00000002 00000000 00000002 00019477 00000000 2000213c 200020e0 20002088 00022640 200020e0 2000213c
        Driver 0: position 3285835, 1299.0 steps/mm, standstill, SG min/max 0/112, read errors 2, write errors 0, ifcnt 16, reads 15462, writes 16, timeouts 0, DMA errors 0, steps req 3403427 done 3403427
        Moves scheduled 8410, completed 8410, in progress 0, hiccups 0, step errors 0, maxPrep 715, maxOverdue 0, maxInc 0, mcErrs 0, gcmErrs 0
        Peak sync jitter 5/10, peak Rx sync delay 621, resyncs 0/1, no step interrupt scheduled
        VIN: 23.5V
        MCU temperature: min 27.9C, current 57.0C, max 61.3C
        Ticks since heat task active 84, ADC conversions started 16541384, completed 16541381, timed out 2, errs 0
        Last sensors broadcast 0x00000002 found 1 89 ticks ago, loop time 0
        CAN messages queued 199893, send timeouts 0, received 158561, lost 0, free buffers 37, min 35, error reg 110000
        dup 0, oos 0/0/0/0, bm 0, wbm 0, rxMotionDelay 648, adv 35218/74656
        Accelerometer detected: yes, status: 00
        I2C bus errors 0, naks 3, other errors 0
          Can you post the gcode file in question as well as your config.g?
          Nuramoriundefined 2 Replies Last reply Reply Quote 0
          • Nuramoriundefined
            Nuramori @Phaedrux
            @phaedrux
            Here's the config.g
            ; Configuration file for Duet3 (firmware version 3.4 Beta2)
            ; --------------- Pin/connection Mapping Legend -------------------
            ; 0.out0      - Bed heater
            ; 0.out1
            ; 0.out2
            ; 0.out3
            ; 0.out4      - Radiator cooling fan - WC heatsink
            ; 0.out5
            ; 0.out6
            ; 0.out7
            ; 0.out8
            ; 0.out9      - Duet board cooling fan
            ; 0.out4.tach - Radiator cooling fan rpm wire - WC heatsink
            ; 0.out5.tach
            ; 0.out6.tach
            ; 0.io0.in
            ; 0.io1.in    - Emergency stop switch
            ; 0.io2.in    - Y max active low endstop switch
            ; 0.io3.in
            ; 0.io4.in
            ; 0.io5.in
            ; 0.io6.in
            ; 0.io7.in
            ; 0.io8.in
            ; 0.io0.out
            ; 0.io1.out
            ; 0.io2.out
            ; 0.io3.out
            ; 0.io4.out
            ; 0.io5.out
            ; 0.io6.out
            ; 0.io7.out
            ; 0.io8.out
            ; 0.servo, out10 (only on v0.5, not on v0.6)
            ; 0.pson
            ; 0.spi.cs0
            ; 0.spi.cs1
            ; 0.spi.cs2
            ; 0.spi.cs3
            ; 0.temp0      - Bed Thermistor
            ; 0.temp1
            ; 0.temp2
            ; 0.temp3      - Coolant Temp Sensor
            ; 0.mcu-temp   - MCU sensor
            ;----------Toolboard 1 (CAN ID#20)
            ; 20.0         - Accelerometer
            ; 20.out0      - Hotend Heater
            ; 20.out1      -
            ; 20.out2      - Parts cooler on printhead
            ; 20.out1.tach -
            ; 20.out2.tach -
            ; 20.io0.in    - Z probe type to bltouch current - Piezo future
            ; 20.io1.in    - X min active low endstop switch
            ; 20.io2.in    -
            ; 20.io3.in    -
            ; 20.io0.out   - GPIO port 0 on toolboard io0, servo mode - BLTouch Z-Probe
            ; 20.temp0     - Extruder Thermistor
            ; 20.temp1     -
            ; 20.button0   -
            ; 20.button1   -
            M81                               ; Turn on the Power (inverted for Meanwell)
            G4 P2000                          ; Hold your Horses.
            G90                               ; send absolute coordinates...
            M83                               ; ...but relative extruder moves
            G21                               ; Set units to Millimeters
            M550 P"DUET3"                     ; set printer name
            M575 P1 S1 B57600                 ; Set things up for the PanelDue
            G4 S6                             ; Wait for toolboard to start
            M584 X0.3 Y0.2 Z0.0:0.1:0.4 E20.0 ; set drive mapping to each axis
            M669 K1                           ; Select CoreXY mode - New format
            ; M552 S1                         ; enable network
            ; M586 P0 S1                      ; enable HTTP
            ; M586 P1 S0                      ; disable FTP
            ; M586 P2 S0                      ; disable Telnet
            M569 P0.0 S0                    ; physical drive 0 goes backwards - Z Axis Left (1)
            M569 P0.1 S0                    ; physical drive 1 goes backwards - Z Axis Right Back (2)
            M569 P0.2 S0                    ; physical drive 2 goes backwards - Y Axis, activate Stealthchop
            M569 P0.3 S0                    ; physical drive 3 goes backwards - X Axis, activate Stealthchop
            M569 P0.4 S0                    ; physical drive 4 goes backwards - Z Axis Right Front (3)
            M569 P20.0 S1                   ; physical drive 5 goes forwards - Extruder 1
            ; Set up three Z-axis location
            M671 X-6:362:362 Y186:299:60 S5            ; Pivot Points at 1 - left, 2 - rear right and 3 - front right
            M92 X200 Y200 Z800 E1299                  ; set steps per mm
            M350 X16 Y16 Z16 E16 I1                    ; configure micro-stepping with interpolation
            M566 X600.00 Y600.00 Z100.00 E240.00       ; set maximum instantaneous speed changes (mm/min)
            M203 X16000.00 Y16000.00 Z400.00 E1200.00  ; set maximum speeds (mm/min)
            M201 X4000.00 Y4000.00 Z400.00 E800.00     ; set accelerations (mm/s^2)
            M906 X800 Y800 Z800 E800 I30               ; set motor currents (mA) and motor idle factor in percent*100
            ; Set up Stealthcop Parameters
            ; M569 P0.0 V40 H5
            ; M569 P0.1 V40 H5
            ; M569 P0.2 V40 H5
            ; M569 P0.3 V40 H5
            ; M569 P0.4 V40 H5
            ; M569 P20.0 V40 H5
            ; M915 X Y Z E T1
            M84 S30                                    ; Set idle timeout
            M208 X0 Y0 Z0 S1                           ; set axis minima
            M208 X315 Y315 Z325 S0                     ; set axis maxima
            M574 X1 S1 P"20.io1.in"                    ; X min active high endstop switch
            M574 Y2 S1 P"0.io2.in"                     ; Y max active high endstop switch
            ; Z-Probe - BLTouch - *CURRENT*
            M574 Z1 S2                                 ; set endstops controlled by probe
            M558 P9 C"^20.io0.in" H5 F2000 T12000      ; set Z probe type to bltouch and the dive height + speeds (bltouch NEEDS pullup)
            G31 P100 X0 Y-20 Z3.85                     ; set Z probe trigger value, offset and trigger height - 0.40MM NOZZLE FIXED Kv1
            G30                                        ; Probe Z
            ; Configure Heaters and Sensors
            M308 S0 P"0.temp0" Y"thermistor" A"Bed Heat" T100000 B3950    ; Configure bed temperature sensor
            M950 H0 C"0.out0" T0                                          ; Define heater 0 (bed heater) - bed_heat pin and Temp Sensor 0
            M143 H0 S120 A2                                               ; set temperature limit for heater 0 to 120c
            M140 H0                                                       ; Map heated bed to heater 0
            M308 S1 P"20.temp0" Y"thermistor" A"Mosquito" T500000 B4723 C1.196220e-7  ; Configure extruder 1 temperature sensor - Mosquito
            M950 H1 C"20.out0" T1                                                     ; Define heater 1 (hot-end E0) to use the "20.out0" pin and Temp Sensor 1
            M143 H1 S270 A2                                               ; set temperature limit for heater 1 to 270C
            M308 S2 P"mcu-temp" Y"mcu-temp" A"Duet Board"                 ; Configure MCU sensor
            M308 S3 P"temp3" Y"thermistor" T10000 B3988 A"Coolant"        ; Configure coolant sensor
            ; Configure Fans
            M950 F0 C"20.out2" Q100                 ; Define Fan_0 for use - Parts Cooler on Printhead - 5015 fan
            M950 F1 C"0.out9" Q25000                ; Define Fan_1 for use - Duet board cooling fan
            M950 F2 C"!0.out4+^0.out4.tach" Q25000  ; Define Fan_1 for use - Radiator cooling - WC heatsink. - PWM fan
            M950 S0 C"20.io0.out"                   ; Define GPIO port 0 on IO0, servo mode - BLTouch Z-Probe - *CURRENT*
            M950 J0 C"^!0.io1.in"                   ; Input 0 uses 0.io1.in pin, pullup enabled
            M106 P0 S0                          ; set fan 0. Parts Cooler on Printhead
            M106 P1 T45:50 H2                   ; Set fan 1. Manages Duet board fan.
            M106 P2 T20:40 H3                   ; Set fan 1. Manages Radiator fan for water-cooled loop.
            ;Set PID values
            M307 H0 B0 R0.720 C713.5 D2.13 S1.00               ; disable bang-bang mode for the bed heater and set PWM limit
            M307 H1 B0 R2.487 C249.5:190.7 D5.51 S1.00 V23.1   ; disable bang-bang mode for the extruder heater and set PWM limit
            ; Pressure Advance
            M572 D0 S0.05                             ; Set pressure advance to offset elasticity
            ; Dynamic Acceleration Adjustment and Non-linear
            M592 D0 A0.015 B0.0012 L0.2
            M593 P"ei3" F272 S0.1 L10
            ; Set Movement Queue
            M595 P100
            ; Set up Accelerometer
            M955 P20.0 I12                      ; Accelerometer on toolboard, oriented counter clockwise 90 Enable for RRF 3.3 Stable
            M563 P0 S"Printhead" D0 H1 F0       ; define tool 0. Fan 0 operates with an active hot-end
            G10 L1 P0 X0 Y0 Z0                  ; set tool 0 axis offsets - - - X15 Y18 - Bed 0,0
            G10 P0 R0 S0                        ; set active and standby temperatures to 0C
            ; Emergency Stop
            M574 S1 P"^!0.io1.in"               ; Define Emergency endstop - emergency stop switch condition
            M581 P0 S1 T0                       ; Define action to be taken with activation of emergency stop switch
            T0                                  ; select first tool
            FIle is here....
            Gcode in question
            • Nuramoriundefined
              Nuramori @Phaedrux
              @phaedrux
              I noticed this on the toolboard diagnostic. Is this indicative of anything?
              "Last software reset at 2021-08-23 15:12, reason: WatchdogTimeout, available RAM 2680, slot 0"
                dc42 administrators @Nuramori
                @nuramori in RRF 3.4 beta 3 I fixed an issue that caused prints to stall in beta 2.
                Nuramoriundefined 2 Replies Last reply Reply Quote 1
                • Nuramoriundefined
                  Nuramori @dc42
                  @dc42 thanks, good to know and I’ll install it ASAP. Any idea from what I posted above, if it was similar to the bug you found?
                  • Nuramoriundefined
                    Nuramori @dc42
                    @dc42 unforunately, the issue was not resolved with the latest beta. I just had the same print I listed above, stall again, this time I could not pull any diagnostic, as the window said a reset was needed.
                    CadetCundefined gloomyandyundefined 2 Replies Last reply Reply Quote 0
                    • CadetCundefined
                      CadetC @Nuramori
                      @nuramori
                      What motors do you use for xy, ? I am surprised at the low current you have set for them. Another thing, and here I ask because I can not find any info on M915(stallguard) and T1 parameter - what is it for?
                      Nuramoriundefined 1 Reply Last reply Reply Quote 0
                      • Nuramoriundefined
                        Nuramori @CadetC
                        @cadetc I use Moons 0.9 1.5 amp NEMA17's they work great, looking at the torque curve charts and my setup.
                        The stealthchop stuff that's commented out are from when I was experimenting with it (if that's what you are referring to with the M915 command - it was to set the registers on the driver)
                        • gloomyandyundefined
                          gloomyandy @Nuramori
                          @nuramori What "window" said that a reset was needed? It would be very useful to be able to see the output from M122 after a stall and before a reset. It may help to hook up a USB console and obtain the m122 from that after the stall.
                          • Nuramoriundefined
                            Nuramori @gloomyandy
                            @gloomyandy It was a dialog box stating that the machine had to be reset to continue - I didn't screenshot it, though I mentioned it in a previous post from me, with the exact wording. When that box comes up, there's no action possible, so I can't execute a M122 command to get data, and a restart wipes the ability to get the info related to the stall.
                            The original post contains M122 output from both the main board and the toolboard the one time I could perform a M122 command.
                            If it happens again, I'll try a USB connection to cull out info if possible.
                              @nuramori I've tried to find your post with the details of the stalled dialog in it but failed. If you get chance it would probably help to see exactly what that wording was.
                              • Nuramoriundefined
                                Nuramori
                                Im not sure if this is related, but ever since the following happened, things are now printing well.
                                After the mid print stalls, I had a temp sensor fault. The sensor itself was fine, so I performed an auto tune with the new beta. The result was notably different than the values I had before (which were generated with beta 2). Once I did that, I then was getting temp faults on the bed. I then auto tuned the bed and that too were notably different values.
                                Once I used the new values for the heaters, everything has been running perfectly fine. The same gcode has completed without a stall for multiple prints of the same file.
