    One nozzle and two extruders working at the same time
    1.2k
    • _santiserranoundefined
      _santiserrano
      Hi!
      I am new in the world of 3d printers. I am attempting to build a machine with superior speeds than usual. So I decided to use two extruders (E3D titan) with the E3D cyclops (two imputs, one output). But I am not interested in using two filament colors. I am interested in using the same color through both extruders but using the larger nozzle diameter it could be possible. I've bought the duet wifi with the duex5 add-on, because I will be using 7 heater cartridges (6 volcano heater block and 1 cyclops heater block).
      Now I have presented my idea, I want to ask you if it is possible to feed the unique nozzle with both extruders working at the same time, for being able to print as much ABS as possible at the same time.
      Thank you,
      Santiago Serrano from Argentina!
      • fmaundefined
        fma
        If I am correct, you can assign multiples drivers to the same axis, with the M584 command… They should be driven at the same time.
        Nice project, btw!
        Frédéric
        • fmaundefined
          fma
          Another simple solution is to wire both motors in series, like it is done for Z axis…
          Frédéric
            Either connect the two motors in series as fma suggests, or configure it as a mixing extruder with a 0.5:0.5 mix ratio.
            • fmaundefined
              fma
              Ah, the mixer solution is probably better, as it is then possible to adjust both extruders if they are not perfectly identical…
              BTW, is the M584 solution possible? Is it possible to have 2 outputs driven in //?
              Frédéric
              • briangilbertundefined
                briangilbert
                Any insight on how to configure our slicer when using mixing?
                I use S3D, but am willing to play with others if it makes life easier..
                Co-creator of the Zesty Nimble direct drive extruder
                • T3P3Tonyundefined
                  T3P3Tony administrators
                  Brian
                  Currently slic3r don't deal with mixing directly (at least as far as I know). To get round this you assign a different tool to the different parts of the model that you want in a different colour/material mix. You can then create a different tool for that colour/material mix in the firmware.
                  Ian Pegg (deckingman on the forums) has a number of blog posts on this from the perspective of using a 3 or 5 input diamond hotend that go into detail on the process and certian refinements:
                  https://somei3deas.wordpress.com
                  RepRapFirmware does allow you to change the mixing ratios on the fly so a future slicer will hopefully support this.
                  www.duet3d.com
                    @fma:
                    Yes for axes, no for extruders.
                    • fmaundefined
                      fma
                      I see.
                      Frédéric
                        _santiserrano
                        Thank you all!
