    Large Format Dowell to Duet conversion
    362
    34.6k
    • Charles Fraserundefined
      Charles Fraser @T3P3Tony
      @t3p3tony
      I removed the 3D touch. Still Only the lily hotend shows now. No bed, no temps. WTF!!
      • T3P3Tonyundefined
        T3P3Tony administrators @Charles Fraser
        @charles-fraser said in Large Format Dowell to Duet conversion:
        The print cooling fan is not working even if I turn the 'TOOL FAN' slider up to 100 and switch polarity of the wires. Maybe it needs to actually be printing for that to come on?
        no it does not need to be printing. try connecting the fan directly to +24V and ground to test it works (assuming its a 24V fan).
        Is it possible to do a PID tuning while extruding because this extruder pushes out so much material it will need a different heating tuning I recon to make it work best.
        no - but we do plan to add extrusion look ahead in future versions of the firmware.
        Also which line is the steps per mm of extruded material please? The Extruder has a 20:1 gear NEMA17 that needs to spin jolly fast to get that screw moving around.
        the E value in this:
        M92 X80.00 Y1280.00 Z1926.00 E420.00          ; set steps per mm
        PS: is there no way to wire the 3D touch to the 3HC? Cables just don’t reach the 6HC
        you should connect it to the same board as the Z motors are on for now:
        https://duet3d.dozuki.com/Wiki/Duet_3_firmware_configuration_limitations
        Due to CAN latency the motors connected to expansion boards may slightly overshoot the position at which the endstop or Z probe was triggered. This would not usually matter for an endstop switch, but it does mean that if the Z motor(s) is/are connected to an expansion board then repeated probing with a Z probe (e.g. for mesh bed compensation) is not advisable. This will be fixed in a future release
        when you lose communication with the 3HC then you will lose communication with everything on that board.
        Try undoing the changes you made to config.g and then reset everything (without the 3d touch installed). Unless that damaged the board it should all come back up.
        www.duet3d.com
        Charles Fraserundefined 1 Reply Last reply Reply Quote 0
          @t3p3tony
          I undid the changes and unplugged the 3D touch and it still does not work. How can even wiring up one io wrong fry the whole board?
          I noticed, before all this crashed, the print cooling fan was spinning but hardly getting going then stopping again.
          • T3P3Tonyundefined
            unplug this as well - the power cycle the power to both the 6HC and the 3HC. Run M98 P"0:sys/config.g" to verify the changes are undone.
            www.duet3d.com
              @t3p3tony
              Nothing is happening when I do any commands anymore. It just spins around and around. All things added are disconnected now. The 3HC doesnt blink anymore 😕
              • T3P3Tonyundefined
                @charles-fraser can you still access the network interface? in that case send M122
                www.duet3d.com
                  @t3p3tony
                  m122
                  RepRapFirmware for Duet 3 MB6HC version 3.4.0beta5 (2021-10-12 13:53:56) running on Duet 3 MB6HC v1.01 or later (SBC mode)
                  Board ID: 08DJM-9P63L-DJ3S0-7J1D6-3SD6S-1UJV8
                  Used output buffers: 1 of 40 (12 max)
                  Static ram: 151104
                  Dynamic ram: 65108 of which 0 recycled
                  Never used RAM 134460, free system stack 219 words
                  Tasks: SBC(ready,0.4%,518) HEAT(notifyWait,0.1%,361) Move(notifyWait,0.0%,351) CanReceiv(notifyWait,0.0%,944) CanSender(notifyWait,0.0%,374) CanClock(delaying,0.0%,333) TMC(notifyWait,7.1%,92) MAIN(running,41.2%,1241) IDLE(ready,51.2%,30), total 100.0%
                  Owned mutexes: HTTP(MAIN)
                  Last reset 00:00:30 ago, cause: power up
                  Last software reset details not available
                  Error status: 0x00
                  Step timer max interval 132
                  MCU temperature: min 12.4, current 21.8, max 21.8
                  Supply voltage: min 24.1, current 24.2, max 24.2, under voltage events: 0, over voltage events: 0, power good: yes
                  12V rail voltage: min 12.1, current 12.2, max 12.2, under voltage events: 0
                  Driver 0: pos 0, standstill, SG min/max 0/0, reads 41983, writes 14 timeouts 0
                  Driver 1: pos 0, standstill, SG min/max 0/0, reads 41983, writes 14 timeouts 0
                  Driver 2: pos 0, standstill, SG min/max 0/0, reads 41983, writes 14 timeouts 0
                  Driver 3: pos 0, standstill, SG min/max 0/0, reads 41983, writes 14 timeouts 0
                  Driver 4: pos 0, standstill, SG min/max 0/0, reads 41983, writes 14 timeouts 0
                  Driver 5: pos 0, standstill, SG min/max 0/0, reads 41983, writes 14 timeouts 0
                  Date/time: 2021-11-03 20:39:44
                  Slowest loop: 0.97ms; fastest: 0.05ms
                  === Storage ===
                  Free file entries: 10
                  DMs created 125, segments created 0, maxWait 0ms, bed compensation in use: none, comp offset 0.000
                  === MainDDARing ===
                  === AuxDDARing ===
                  Segments left: 0
                  Movement lock held by null
                  Telnet is idle in state(s) 0
                  File is idle in state(s) 0
                  USB is idle in state(s) 0
                  Aux is idle in state(s) 0
                  Queue is idle in state(s) 0
                  LCD is idle in state(s) 0
                  SBC is idle in state(s) 0
                  Daemon is idle in state(s) 0
                  Aux2 is idle in state(s) 0
                  Code queue is empty
                  === CAN ===
                  Messages queued 168, received 0, lost 0, longest wait 0ms for reply type 0, peak Tx sync delay 0, free buffers 49 (min 48), ts 154/0/0
                  Tx timeouts 0,0,153,13,0,0 last cancelled message type 30 dest 127
                  === SBC interface ===
                  State: 4, failed transfers: 0, checksum errors: 649
                  Last transfer: 2ms ago
                  RX/TX seq numbers: 16350/750
                  SPI underruns 2, overruns 2
                  Disconnects: 0, timeouts: 0, IAP RAM available 0x2b7dc
                  Buffer RX/TX: 0/0-0
                  === Duet Control Server ===
                  Duet Control Server v3.4-b5
                  Code buffer space: 4096
                  Configured SPI speed: 8000000Hz
                  Full transfers per second: 37.18, max wait times: 2187.4ms/29.1ms
                  Codes per second: 0.01
                  Maximum length of RX/TX data transfers: 2868/560
                  • T3P3Tonyundefined
                    @charles-fraser and after doing the following:
                    Power cycle the 3HC
                    send M98 P"0:sys/config.g"
                    Send M122 B1
                    www.duet3d.com
                      @t3p3tony
                      I’ve done that and nothing. When I send those commands the DWC gets stuck in the spinning wheel of death. There is no blinking light on the 3HC
                      • T3P3Tonyundefined
                        @charles-fraser it sounds like that 3d touch has caused an issues (or resurfaced an issue from the previous heater problems) with the 3HC. I remember you had issues with it right at the beginning - is this a new 3d touch or your original one?
                        We previously reset and reflashed the firmware on the 3HC. I think that's the step to take again now:
                        To force a firmware reload on the 3HC set all the dip switched to 0, power cycle the 3HC, you should see the diag light flash a bit. when its showing steady flashing in sync with the mainboard, switch the dip switch back to 1 as it was then power cycle the 3HC.
                        www.duet3d.com
                        Charles Fraserundefined 3 Replies Last reply Reply Quote 0
                          @t3p3tony
                          I have done that and still no flashing light
                          Also this is the same 3D touch as before. Now I remove it but still the 3HC doesnt flash. Before when I removed it the 3HC started working again. There is nothing on the board and it’s not working
                            @t3p3tony
                            04/11/2021, 10:20:13	Warning: Lost connection to Duet (Timeout while waiting for transfer ready pin)
                            04/11/2021, 10:20:09	Error: M308: Response timeout: CAN addr 1, req type 6031, RID=6
                            04/11/2021, 10:20:06	Error: M558: Response timeout: CAN addr 1, req type 6036, RID=5
                            04/11/2021, 10:20:06	Error: G31: Invalid Z probe index
                            04/11/2021, 10:20:06	Error: Invalid remote handle
                            04/11/2021, 10:20:05	Error: M906: Response timeout: CAN addr 1, req type 6043, RID=4
                            04/11/2021, 10:20:05	Error: M92: Response timeout: CAN addr 1, req type 6042, RID=3
                            04/11/2021, 10:20:04	Error: M350: Response timeout: CAN addr 1, req type 6042, RID=2
                            04/11/2021, 10:20:02	Error: M584: Response timeout: CAN addr 1, req type 6042, RID=1
                            04/11/2021, 10:20:00	Error: M569: Response timeout: CAN addr 1, req type 6018, RID=0
                            04/11/2021, 10:19:59	Connected to duet3
                              @t3p3tony
                              Any help? Is it fried? I can't believe it fries just because of a short that doesn't make sense to me
                              • T3P3Tonyundefined
                                @charles-fraser
                                Is the 3.3v LED lit on the 3HC? (its with the other power LEDS in the top left og the board as you have it oriented.
                                www.duet3d.com
                                • T3P3Tonyundefined
                                  Not sure what is going on here? why were there two sets of wires going into IO2?
                                  www.duet3d.com
                                  Charles Fraserundefined 2 Replies Last reply Reply Quote 0
                                    @t3p3tony said in Large Format Dowell to Duet conversion:
                                    None of this is plugged in any more. I explained this in my post with the description of the wiring of the 3D touch above. Please have a look.
                                      @t3p3tony
                                      Nothing is plugged into the 3HC
                                      These are the lights that are on:
                                        Charles Fraser @Charles Fraser
                                        @T3P3Tony this explains the wiring
                                        @t3p3tony
                                        I’m sorry it’s a bit of a fudge but I have only been able to get the 3D touch wired up (I hope correctly) with the 3HC, IO_2
                                        Here is what the wiring from the touch is supposed to be:
                                        But the 3D touch I have does not have a white wire, it has a blue wire though so I am guessing that’s the only difference.
                                        I have to connect the BL touch to two different cables, each with four wires in them to reach the board at the other end of the printer. In one of the cables, two of the wires are already used by the NTC thermistor so it looks like this:
                                        Then I can only reach IO_2 on the 3H with all that following this diagram:
                                        Which looks like this:
                                        I hope that’s correct! I’ll try to change the code and hope it works!
                                          @t3p3tony
                                          Hi please advise. Do I need to buy a new board or what to keep things moving forwards?
                                          • T3P3Tonyundefined
                                            @charles-fraser It looks like the 3.3V regulator & possibly other ICs on the 3HC was blown by the 3d touch. I suspect given that it caused issues before that it is faulty, I don't know much about the 3d touches but if they are the same as the BL touch internally they should not blow the board by just mis wiring.
                                            Yes you need to replace the 3HC
                                            www.duet3d.com
