    RRF 3.4b3 - bed heater fault
    Beta Firmware
    475
    • CadetC
      CadetC last edited by
      after installing 3.4b3 i have problem with table heating - of course pid tuning done. Previously there were no such problems. If I set the temperature of the table at 110C (temperature at which I print) in order to heat up the table first and run ABL, I have to delete the fault twice before the table reaches the temperature and maintains it - after reaching the set temperature it is stable.
      27.08.2021, 12:58:22	Error: Heater 0 fault: temperature rising much more slowly than the expected 0.6°C/sec
      my M307 after pid tuned
      M307 H0 B0 R0.858 C275.9 D4.18 S1.00 V24.0
      SIam 1 Reply Last reply Reply Quote 0
      • SIam
        SIam @CadetC last edited by
        @cadetc Welcome in the club 😉 https://forum.duet3d.com/topic/24809/3-4-0-beta-3-heater-0-fault/2
        Hypercube-Evolution-Hybrid, Piezo Orion, Orbiter
        Duet WiFi 1.02 or later + DueX5
        RepRapFirmware for Duet 2 WiFi/Ethernet 3.4.0beta4 (2021-09-27 11:30:36)
        Duet WiFi Server: 1.26
        Duet Web Control 3.4.0beta4 (2021-09-27)
          Can you give us some details about the bed and heater?
          CadetC 1 Reply Last reply Reply Quote 0
          • CadetC
            CadetC @Phaedrux last edited by
            @phaedrux said in RRF 3.4b3 - bed heater fault:
            Bed is made out of 8 mm aluminum plate with dimensions 340X340
            Heating element - 300X300 - 220V, 750W Kenovo connected via SSR
            Starting with RRF 3.2 I had all versions installed, including betas - it was only with RRF3.4b3 that this problem occurred
            my bed config from config.g
            M308 S0 P"temp0" Y"thermistor" T100000 B4138 A"Bed"      ; configure sensor 0 as thermistor on pin temp0
            M950 H0 C"out0" T0                                   ; create bed heater output on out0 and map it to sensor 0
            M307 H0 B0 S1.00                                     ; disable bang-bang mode for the bed heater and set PWM limit
            M140 H0                                              ; map heated bed to heater 0
            M143 H0 S130                                         ; set temperature limit for heater 0 to 130C
            dc42 1 Reply Last reply Reply Quote 1
              dc42 administrators @CadetC last edited by
              @cadetc @SIam in order to help ne work on a solution, please can each of you do the following:
              1. Heat the bed to the same temperature that you tuned it at (resetting heater faults as necessary);
              2. When the temperature is stable, use command M573 P0 (assuming it is heater 0) to monitor the heater PWM;
              3. When the value reported by M573 is stable, report in this thread:
              • The M573 result
              • The ambient temperature at the time
              • The bed temperature that you tuned at and set
              • The heater tuning results, or the resulting M307 command.
              • SIam
                SIam @dc42 last edited by
                @dc42 Here we go, The first thing is M573 is never stable, the heat bed is on Temp since 3 hours
                28.8.2021, 13:27:28	M573 P0
                Average heater 0 PWM: 0.238
                28.8.2021, 13:27:27	M573 P0
                Average heater 0 PWM: 0.247
                28.8.2021, 13:27:26	M573 P0
                Average heater 0 PWM: 0.177
                28.8.2021, 13:27:24	M573 P0
                Average heater 0 PWM: 0.215
                28.8.2021, 13:27:23	M573 P0
                Average heater 0 PWM: 0.267
                28.8.2021, 13:27:22	M573 P0
                Average heater 0 PWM: 0.262
                28.8.2021, 13:27:20	M573 P0
                Average heater 0 PWM: 0.216
                28.8.2021, 13:27:19	M573 P0
                Average heater 0 PWM: 0.228
                28.8.2021, 13:27:18	M573 P0
                Average heater 0 PWM: 0.214
                28.8.2021, 13:27:16	M573 P0
                Average heater 0 PWM: 0.184
                28.8.2021, 13:27:14	M573 P0
                28.8.2021, 13:27:11	M573 P0
                Average heater 0 PWM: 0.199
                28.8.2021, 13:27:09	M573 P0
                28.8.2021, 13:27:07	M573 P0
                Average heater 0 PWM: 0.289
                28.8.2021, 13:27:06	M573 P0
                Average heater 0 PWM: 0.185
                28.8.2021, 13:27:03	M573 P0
                Average heater 0 PWM: 0.278
                28.8.2021, 13:27:02	M573 P0
                Average heater 0 PWM: 0.236
                28.8.2021, 13:27:00	M573 P0
                Average heater 0 PWM: 0.209
                28.8.2021, 13:26:58	M573 P0
                Average heater 0 PWM: 0.244
                28.8.2021, 13:26:56	M573 P0
                Average heater 0 PWM: 0.147
                The ambient temperature is 17 C°
                The Bed temperature that i have Tuned was 100C° and set to 75C°
                and at last the tuning result is
                M307 H0 R0.466 C285.252:285.252 D0.89 S1.00 V24.3 B0 I0
                if you need more tests, let me know
                  dc42 administrators @SIam last edited by
                  @siam thanks. If the M573 reading is not stable, is the temperature oscillating a little? If so, increase the M307 D parameter until it is stable. You can do this while the heater is hot.
                  CadetC SIam 2 Replies Last reply Reply Quote 0
                  • CadetC
                    CadetC @dc42 last edited by CadetC
                    @dc42 said in RRF 3.4b3 - bed heater fault:
                    the temperature after reaching the desired 110 degrees is a little unstable, it fluctuates within +0.3, -0.3 degrees
                    I tried to change parameter D, but I don't know by what values I can change it - I changed it by 0.1 to the value 4.80 with no visible improvement.
                    Here are the readings taken about an hour after setting the bed temperature
                    M573 results
                    .08.2021, 16:03:22	m573 P0
                    Average heater 0 PWM: 0.196
                    28.08.2021, 16:03:16	m573 P0
                    Average heater 0 PWM: 0.165
                    28.08.2021, 16:03:15	m573 P0
                    Average heater 0 PWM: 0.163
                    28.08.2021, 16:03:14	m573 P0
                    Average heater 0 PWM: 0.178
                    28.08.2021, 16:03:12	m573 P0
                    Average heater 0 PWM: 0.213
                    28.08.2021, 16:02:57	m573 P0
                    Average heater 0 PWM: 0.256
                    Ambient temperature 20C
                    Bed temperature 110C
                    M307 H0
                    8.08.2021, 16:00:46	M307 H0
                    Heater 0 model: heating rate 0.858, cooling time constant 275.9, dead time 4.18, max PWM 1.00, calibration voltage 24.0, mode PID
                    Computed PID parameters:
                     setpoint change: P49.8, I1.466, D145.6, load change: P49.8, I3.664, D145.6
                    • SIam
                      @dc42 The temperature is a bit unstable 69.8 C° - 70.2C° I have increased the d Value by 0.1 up to 6 without any improvement
                        @siam @CadetC you can double or treble the D parameter if necessary, although that will only help if you are getting regular temperature oscillations.
                        SIam CadetC 2 Replies Last reply Reply Quote 0
                        • SIam
                          @dc42 I can do what I want, the PWM Value is always unstable, the only change I can see is that the temperature fluctuations get bigger when I increase the D value. I have now the D value increased by 0.5 until D=25
                          • SIam
                            SIam @SIam last edited by SIam
                            I have now written a quick and dirty macro to get the values and share the results
                            var D_Value = 1
                            var D_Value_max = 10
                            var D_value_incr = 0.5
                            var get_pwm_repeat = 10
                            var count_pwm = 0
                            echo >"PWM.log" " " ; write new file to sys:
                            while var.D_Value < var.D_Value_max
                            	echo >>"PWM.log" " "
                            	echo "D_Value " ^ var.D_Value
                            	echo >>"PWM.log" "D_Value " ^ var.D_Value
                            	M307 H0 R0.466 C285.252:285.252 D{ var.D_Value } S1.00 V24.3 B0 I0  ; change that line to fit to your heater settings
                            	echo "M307 H0 R0.466 C285.252:285.252 D" ^ var.D_Value ^ " S1.00 V24.3 B0 I0" ; change that line to fit to your heater settings
                            	echo >>"PWM.log" "M307 H0 R0.466 C285.252:285.252 D" ^ var.D_Value ^ " S1.00 V24.3 B0 I0" ; change that line to fit to your heater settings
                            	set var.D_Value = var.D_Value + var.D_value_incr
                            	G4 S2
                            	while var.count_pwm < var.get_pwm_repeat
                            		M573 P0
                            		echo "PWM: " ^ heat.heaters[0].avgPwm
                            		echo >>"PWM.log" "PWM: " ^ heat.heaters[0].avgPwm
                            		G4 S1
                            		set var.count_pwm = var.count_pwm +1
                            	set var.count_pwm = 0
                            The result
                            D_Value 1
                            M307 H0 R0.466 C285.252:285.252 D1 S1.00 V24.3 B0 I0
                            PWM: 0.196
                            PWM: 0.235
                            PWM: 0.239
                            PWM: 0.199
                            PWM: 0.179
                            PWM: 0.201
                            PWM: 0.220
                            PWM: 0.186
                            PWM: 0.156
                            PWM: 0.154
                            D_Value 1.5
                            M307 H0 R0.466 C285.252:285.252 D1.5 S1.00 V24.3 B0 I0
                            PWM: 0.224
                            PWM: 0.215
                            PWM: 0.257
                            PWM: 0.303
                            PWM: 0.278
                            PWM: 0.215
                            PWM: 0.181
                            PWM: 0.195
                            PWM: 0.243
                            PWM: 0.282
                            D_Value 2.0
                            M307 H0 R0.466 C285.252:285.252 D2.0 S1.00 V24.3 B0 I0
                            PWM: 0.206
                            PWM: 0.225
                            PWM: 0.268
                            PWM: 0.285
                            PWM: 0.264
                            PWM: 0.263
                            PWM: 0.302
                            PWM: 0.342
                            PWM: 0.336
                            PWM: 0.321
                            D_Value 2.5
                            M307 H0 R0.466 C285.252:285.252 D2.5 S1.00 V24.3 B0 I0
                            PWM: 0.246
                            PWM: 0.203
                            PWM: 0.198
                            PWM: 0.200
                            PWM: 0.167
                            PWM: 0.138
                            PWM: 0.141
                            PWM: 0.172
                            PWM: 0.185
                            PWM: 0.159
                            D_Value 3.0
                            M307 H0 R0.466 C285.252:285.252 D3.0 S1.00 V24.3 B0 I0
                            PWM: 0.206
                            PWM: 0.255
                            PWM: 0.264
                            PWM: 0.228
                            PWM: 0.191
                            PWM: 0.195
                            PWM: 0.234
                            PWM: 0.257
                            PWM: 0.255
                            PWM: 0.255
                            D_Value 3.5
                            M307 H0 R0.466 C285.252:285.252 D3.5 S1.00 V24.3 B0 I0
                            PWM: 0.199
                            PWM: 0.218
                            PWM: 0.219
                            PWM: 0.204
                            PWM: 0.206
                            PWM: 0.235
                            PWM: 0.259
                            PWM: 0.247
                            PWM: 0.233
                            PWM: 0.251
                            D_Value 4.0
                            M307 H0 R0.466 C285.252:285.252 D4.0 S1.00 V24.3 B0 I0
                            PWM: 0.296
                            PWM: 0.299
                            PWM: 0.336
                            PWM: 0.361
                            PWM: 0.329
                            PWM: 0.269
                            PWM: 0.233
                            PWM: 0.241
                            PWM: 0.239
                            PWM: 0.197
                            D_Value 4.5
                            M307 H0 R0.466 C285.252:285.252 D4.5 S1.00 V24.3 B0 I0
                            PWM: 0.191
                            PWM: 0.170
                            PWM: 0.140
                            PWM: 0.130
                            PWM: 0.151
                            PWM: 0.149
                            PWM: 0.123
                            PWM: 0.100
                            PWM: 0.095
                            PWM: 0.117
                            D_Value 5.0
                            M307 H0 R0.466 C285.252:285.252 D5.0 S1.00 V24.3 B0 I0
                            PWM: 0.218
                            PWM: 0.209
                            PWM: 0.194
                            PWM: 0.207
                            PWM: 0.223
                            PWM: 0.201
                            PWM: 0.165
                            PWM: 0.152
                            PWM: 0.169
                            PWM: 0.204
                            D_Value 5.5
                            M307 H0 R0.466 C285.252:285.252 D5.5 S1.00 V24.3 B0 I0
                            PWM: 0.175
                            PWM: 0.165
                            PWM: 0.155
                            PWM: 0.131
                            PWM: 0.107
                            PWM: 0.101
                            PWM: 0.126
                            PWM: 0.165
                            PWM: 0.205
                            PWM: 0.242
                            D_Value 6.0
                            M307 H0 R0.466 C285.252:285.252 D6.0 S1.00 V24.3 B0 I0
                            PWM: 0.299
                            PWM: 0.304
                            PWM: 0.327
                            PWM: 0.317
                            PWM: 0.284
                            PWM: 0.246
                            PWM: 0.218
                            PWM: 0.216
                            PWM: 0.226
                            PWM: 0.215
                            D_Value 6.5
                            M307 H0 R0.466 C285.252:285.252 D6.5 S1.00 V24.3 B0 I0
                            PWM: 0.233
                            PWM: 0.248
                            PWM: 0.233
                            PWM: 0.222
                            PWM: 0.242
                            PWM: 0.269
                            PWM: 0.266
                            PWM: 0.248
                            PWM: 0.251
                            PWM: 0.275
                            D_Value 7.0
                            M307 H0 R0.466 C285.252:285.252 D7.0 S1.00 V24.3 B0 I0
                            PWM: 0.240
                            PWM: 0.253
                            PWM: 0.258
                            PWM: 0.235
                            PWM: 0.207
                            PWM: 0.190
                            PWM: 0.169
                            PWM: 0.149
                            PWM: 0.161
                            PWM: 0.194
                            D_Value 7.5
                            M307 H0 R0.466 C285.252:285.252 D7.5 S1.00 V24.3 B0 I0
                            PWM: 0.174
                            PWM: 0.145
                            PWM: 0.144
                            PWM: 0.170
                            PWM: 0.191
                            PWM: 0.178
                            PWM: 0.154
                            PWM: 0.155
                            PWM: 0.177
                            PWM: 0.190
                            D_Value 8.0
                            M307 H0 R0.466 C285.252:285.252 D8.0 S1.00 V24.3 B0 I0
                            PWM: 0.194
                            PWM: 0.214
                            PWM: 0.201
                            PWM: 0.167
                            PWM: 0.141
                            PWM: 0.147
                            PWM: 0.177
                            PWM: 0.211
                            PWM: 0.223
                            PWM: 0.207
                            D_Value 8.5
                            M307 H0 R0.466 C285.252:285.252 D8.5 S1.00 V24.3 B0 I0
                            PWM: 0.217
                            PWM: 0.201
                            PWM: 0.168
                            PWM: 0.148
                            PWM: 0.152
                            PWM: 0.146
                            PWM: 0.121
                            PWM: 0.101
                            PWM: 0.112
                            PWM: 0.116
                            D_Value 9.0
                            M307 H0 R0.466 C285.252:285.252 D9.0 S1.00 V24.3 B0 I0
                            PWM: 0.112
                            PWM: 0.132
                            PWM: 0.125
                            PWM: 0.118
                            PWM: 0.135
                            PWM: 0.159
                            PWM: 0.162
                            PWM: 0.141
                            PWM: 0.134
                            PWM: 0.155
                            D_Value 9.5
                            M307 H0 R0.466 C285.252:285.252 D9.5 S1.00 V24.3 B0 I0
                            PWM: 0.150
                            PWM: 0.167
                            PWM: 0.193
                            PWM: 0.196
                            PWM: 0.180
                            PWM: 0.186
                            PWM: 0.215
                            PWM: 0.248
                            PWM: 0.276
                            PWM: 0.291
                            • CadetC
                              Today I checked again how this issue looks like - when heating up to 110C I had to delete fault once, then everything was OK.
                              After about 30 minutes temperature quite stable, small fluctuations +0.1, -0.1 degrees .
                              After the temperature of the table stabilized (with small deviations as above) the result of M573 varied from 0.226 to 0.242 - I checked it for about 15 minutes
                              30.08.2021, 17:18:38	M307 H0
                              Computed PID parameters: setpoint change: P49.8, I1.466, D145.6, load change: P49.8, I3.664, D145.6
                              30.08.2021, 17:17:49	M573 p0undefined
                              • hestiahuang
                                hestiahuang last edited by
                                @cadetc said in RRF 3.4b3 - bed heater fault:
                                Refer to https://forum.duet3d.com/topic/24809/3-4-0-beta-3-heater-0-fault/12
                                • Referenced by  hestiahuang hestiahuang
