    RRF configuration using object model notation
    Firmware wishlist
    • zapta
      zapta last edited by zapta
      TL;DR, allow RRF configuration using a human friendly object model notation.
      RRF has now a nice object model and format that allows humans to easily read its state
      https://duet3d.dozuki.com/Wiki/Object_Model_of_RepRapFirmware
      However, writing to the object model (e.g. in config.g) is still done with cryptic gcode based setters.
      Being able to also configure with object model notation would make RRF configuration more intuitive and less error prone. Here is one example how this can be done, using the indented block construct currently used for conditions and loops:
      M???
          move.axes [
              "letter": "X",
              "max": 200,
              "min": 0,
              "visible": true
              "letter": "Y",
              "max": 200,
              "min": 0,
              "visible": true
      EDIT: Some ideas may be borrowed from GCL. It's a similar language to construct structured configurations but with more bells and whistles https://gcl.readthedocs.io/en/latest/introduction.html#vision
      fcwilt 1 Reply Last reply Reply Quote 0
      • fcwilt
        fcwilt @zapta last edited by
        @zapta
        Way too much typing.
        If that was an alternate way fine but don't force everyone to generate that much code.
        Just my 2 cents - well given inflation maybe that should be 4 cents.
        zapta 1 Reply Last reply Reply Quote 0
        • zapta
          zapta @fcwilt last edited by
          @fcwilt, think of all the comments it will save.
          fcwilt engikeneer 2 Replies Last reply Reply Quote 1
          • fcwilt
            @zapta said in RRF configuration using object model notation:
            True enough.
            • engikeneer
              engikeneer @zapta last edited by
              Wait, you guys are commenting your gcode? 😛
              i3 clone with a bunch of mods
              fcwilt 1 Reply Last reply Reply Quote 5
              • fcwilt
                fcwilt @engikeneer last edited by
                @engikeneer
                I was a programmer for 30+ years.
                Lots and lots of comments, more comments than code.
                • Referenced by  zapta zapta
