    Induced bed temp Noise while Printing
    182
    • cianforstuff
      cianforstuff last edited by
      Hi guys
      Ive built my self a voron V0.1 based arround a Duet 3 mini5+.
      I have started cranking up the speeds and I started to knoticed an induced noise in the bed Temp, to a point wher the thermal run away kicked in and haults the print (see fig 1).
      Figure 1
      Has anyone come accross this issure before? Power supply voltage seems to hovver betwween 24.2V-24.3V ( Witch seems Normal, but tell me otherwise). Could it Be an EMI/ EMC issue to do with the frequency of the stepper motors, as it only occures while printing ?
      I still need to do some more work to figure it out, Like read the thermistor values with a discreet meter and such. OR maybe do a frequency anslsys of the noise ( On an asside, is there any logging tools for heater temps so i can do this? ), but i woud love to hear if anyone has encountered this?
      Thanks in advance
      Cian
      Config file showen below
      G90                                     ; send absolute coordinates...
      M83                                     ; ...but relative extruder moves
      M550 P"Demhán"                      ; set printer name
      M669 K1                                 ; select CoreXY mode
      M551 P"********"                         ; set password
      M552 S1                                 ; enable network
      M586 P0 S1                              ; enable HTTP
      M586 P1 S0                              ; disable FTP
      M586 P2 S0                              ; disable Telnet
                                 ; physical drive 0.0 goes forwards
      M569 P0.1 S0                            ; physical drive 0.1 goes forwards
      M569 P0.2 S1                            ; physical drive 0.2 goes forwards
      M569 P0.3 S1  							; physical drive 0.3 goes backwards
      M596 P04 s1								; physical drive 0.4 goes forwards
      M584 X0.4 Y0.3 Z0.2 E0.1                ; set drive mapping
      M350 X32 Y32 Z16 E16 I1                      ; configure microstepping with interpolation
      M566 X800.00 Y800.00 Z60.00 E400.00          ; set maximum instantaneous speed changes (mm/min)
      M203 X15000.00 Y15000.00 Z900.00 E3000.00    ; set maximum speeds (mm/min)
      M201 X6000.00 Y6000.00 Z1200.00 E4000.00     ; set accelerations (mm/s^2)
      M906 X1500 Y1500 Z400 E600 I30                 ; set motor currents (mA) and motor idle factor in per cent
      M84 S30                                      ; Set idle timeout
      M92 X160.00 Y160.00 Z400.00 ;E420.00          ; set steps per mm
      M92 E1413.91
      M208 X0 Y0 Z0 S1                        ; set axis minima
      M208 X120 Y120 Z120 S0                  ; set axis maxima
      M574 X2 S1 P"!io0.in"                   ; configure active-high endstop for high end on X via pin !io0.in
      M574 Y2 S1 P"!io1.in"                   ; configure active-high endstop for high end on Y via pin !io1.in
      M574 Z1 S1 P"!io2.in"                   ; configure active-high endstop for high end on Z via pin !io2.in
      M558 P0 H5 F120 T6000                   ; disable Z probe but set dive height, probe speed and travel speed
      M557 X15:120 Y15:120 S20                ; define mesh grid
      M308 S0 P"temp0" Y"thermistor" R2200        ; configure sensor 0 as PT1000 on pin temp0
      M950 H0 C"out0" T0                      ; create bed heater output on out0 and map it to sensor 0
      M307 H0 B1 S1.00                        ; enable bang-bang mode for the bed heater and set PWM limit
      M140 H0                                 ; map heated bed to heater 0
      M143 H0 S120                            ; set temperature limit for heater 0 to 120C
      M308 S1 P"temp1" Y"thermistor" R2200        ; configure sensor 1 as PT1000 on pin temp1
      M950 H1 C"out1" T1                      ; create nozzle heater output on out1 and map it to sensor 1
      M307 H1 B0 S1.00                        ; disable bang-bang mode for heater  and set PWM limit
      M143 H1 S280                            ; set temperature limit for heater 1 to 280C
      M950 F0 C"out6" Q100                  ; create fan 0 on pin out6 and set its frequency
      M106 P0 C"Cold end Fan" S0.8 H1 T45     ; set fan 0 name and value. Thermostatic control is turned on
      M950 F1 C"out5" Q250                   ; create fan 1 on pin out5 and set its frequency
      M106 P1 C"Part Fan" S1 H-1              ; set fan 1 name and value. Thermostatic control is turned off
      M563 P0 D0 H1 F0:1                      ; define tool 0
      G10 P0 X0 Y0 Z0                         ; set tool 0 axis offsets
      G10 P0 R0 S0                            ; set initial tool 0 active and standby temperatures to 0C
      T0
      M501                                    ; load saved parameters from non-volatile memory
      tecno fcwilt Phaedrux jens55 4 Replies Last reply Reply Quote 0
      • tecno
        tecno @cianforstuff last edited by
        @cianforstuff
        Read in on M303 to calibrate your heaters.
        cianforstuff 1 Reply Last reply Reply Quote 0
        • cianforstuff
          cianforstuff @tecno last edited by
          @tecno the bed Has been tuned, and its quite the termal mass so its hard to beleve that there is temp swings of approx 20c
          tecno 1 Reply Last reply Reply Quote 0
          • tecno
            @cianforstuff
            Try to run PID instead of BitBang
            This is how it looks on my massive 400x400 bed
            M308 S0 P"temp0" Y"thermistor" T100000 B4138 ; configure sensor 0 as thermistor on pin temp0
            M950 H0 C"out1" T0 ; create bed heater output on out1 and map it to sensor 0
            M307 H0 R0.211 C620.5 D1.28 S1.00 V24.1 ; disable bang-bang mode for the bed heater and set PWM limit
            M143 H0 S120
            • cianforstuff
              @tecno Via the overridde Condig file i have PID set and tuned and it has been working
              ; config-override.g file generated in response to M500 at 2021-08-20 13:36
              ; Heater model parameters
              M307 H0 R0.485 C172.485:172.485 D2.94 S1.00 V24.2 B0 I0
              M307 H1 R2.429 C140.000:140.000 D5.50 S1.00 V0.0 B0 I0
              Only when i started Increesing speed is when i started noticing the issue, hence why Im thinking it might be somthing a bit more indepth
              • cianforstuff
                Noise apparent when Homing and subsises when no motion
                • tecno
                  @cianforstuff
                  Bad connections maybe?
                  • fcwilt
                    fcwilt @cianforstuff last edited by
                    @cianforstuff
                    I would guess the temp sensor wiring is picking up noise from the steppers or stepper wiring.
                      Phaedrux Moderator @cianforstuff last edited by Phaedrux
                      @cianforstuff said in Induced bed temp Noise while Printing:
                      Do you have a thermistor, or PT1000?
                      If it's a thermistor, you're missing a B and T value. If it's a PT1000 you need to specify it is instead on of a thermistor.
                      M308 S0 P"temp0" Y"pt1000" R2200        ; configure sensor 0 as PT1000 on pin temp0
                      M308 S1 P"temp1" Y"pt1000" R2200        ; configure sensor 1 as PT1000 on pin temp1
                      • jens55
                        jens55 @cianforstuff last edited by
                        Yes, it's a defective temperature sensor. Tape a new thermistor to the bed with capton tape and use it for the controlling sensor. You can leave the other sensor as a secondary (non controlling) sensor if you like.
