Does RRF have maintenance counters/timers?
@cncmodeller Maybe you can sum up the absolute value of the current y-position. You'd have to poll it every 0.n seconds to get a semi-accurate value, but for wear-prognose it'll do.
@neueklasse said in Does RRF have maintenance counters/timers?:
@dc42 Thank you for the Post in the Thread "M28 + object models"
finally i Managed it to get it working how it should.
echo >"0:/macros/VariableBuffer.g" "G92 Z"^{global.ZAxisPos}^" "
M28/M29 doesn't work (at least in my Case..)
with the echo command i finally have a Variable buffer that's persistent!
Just wondering if there's a way not to overwrite the file, but append new values at the file-end?
//edit It's simple! Using echo>><filename> <expression>, <expression>, ... does the trick.
@o_lampe said in Does RRF have maintenance counters/timers?:
That might work, I'll have to think it over...
undefined Tricep terry referenced this topic
