    Does RRF have maintenance counters/timers?
    23
    1.6k
    • OwenDundefined
      OwenD @zapta
      @zapta
      It's all done in the macro myUpTime.g
      Whenever you create the new file using M28 it processes this line.
      set global.CumulativeTime = {global.CumulativeTime + state.UpTime}
      What would actually appear in the file would be something like
      set global.CumulativeTime = 547436446 ; in seconds
      Because everything in the {} would be converted to a number.
      You're probably better off converting to hours as the number may exceed the maximum relatively quickly if left in seconds
      So maybe
      set global.CumulativeTime = {global.CumulativeTime + (state.UpTime/60/60)}; in hours
      zaptaundefined NeueKlasseundefined 2 Replies Last reply Reply Quote 1
      • zaptaundefined
        zapta @OwenD
        @owend, I get it now, thanks. We don't write data but we write a script that when executed later sets the in-memory variable to the desired value.
        That's clever.
        Going back to my original question, the answer is yes but not very user friendly (e.g. no UI support, having to managing the counter's persistence, etc).
        I will set one such counter up and see how it works. Another alternative is to install something like this https://www.amazon.com/AC100-250V-Electromechanical-Hour-Meter-Counter/dp/B008MM0CV0
          deckingman @zapta
          @zapta Something like this might be better https://www.amazon.co.uk/Jayron-Maintenance-Accumulated-Waterproof-Generator/dp/B08H1H9S9X/ref=sr_1_3?dchild=1&keywords=5V+DC+hour+meter&qid=1630489831&sr=8-3
          It's claimed to be suitable for 5 to 60 volts so one could connect it to a spare io pin and use M42 in one's start gcode (or elsewhere) to keep a count of print time, rather than "on time". Or one could use M571 to keep track of hours spent extruding.
          zaptaundefined 1 Reply Last reply Reply Quote 2
          • zaptaundefined
            zapta @deckingman
            Thanks @deckingman, it definitely looks nicer.
            I thought about using the heatsink fan signal ('nozzle is hot') to enable counting but will it show the count when the printer is idle?
            Also, finding one that doesn't need a battery would be nice.
            • NeueKlasseundefined
              NeueKlasse @OwenD
              @owend i Wrote Following File:
              Config.g
              ; Variables
              global ZAxisPos = 0
              M98 P"0:/macros/VariableBuffer.g" ; Update Axis Value from Z
              that's the main macro: Possibly called every 5 Seconds from daemon.g
              ;WritePosition.g
              set global.ZAxisPos = {move.axes[2].userPosition}
              M28 "0:/macros/VariableBuffer.g"
              G92 Z{global.ZAxisPos}
              M29
              in the VariableBuffer.g it's:
              You Mentioned everything in the {} will be converted into Numbers but not in my Case?
              what have i done wrong?
              Prusa Mini, Chiron @ BMG X2
              Metal SLS Printer Development
              cosmowaveundefined 1 Reply Last reply Reply Quote 0
              • cosmowaveundefined
                cosmowave @NeueKlasse
                @neueklasse said in Does RRF have maintenance counters/timers?:
                Perhaps it helps to make some math? e.g.
                G92 Z{global.ZAxisPos + 0}
                Mankati FSXT+, DeltaTowerV2, E3D MS/TC
                NeueKlasseundefined 1 Reply Last reply Reply Quote 0
                • Aussiephilundefined
                  Aussiephil
                  I find it bizarre that in 2021 RRF still doesn't have basic statistically information available in a log file for uptime, print time, filament usage....
                  I read that when filament types were first provided that filament usage would be logged "in the future" seems the future is still waiting.
                  I know this sounds like a rant and you know what maybe it is..... I'd be happy with any of this to end up in a log file and i'll bet the people pleading for counters would be happy with the caveat that on a power interruption/loss that x minutes of data would not be available.
                  Cheers
                  Phil
                    NeueKlasse @cosmowave
                    @cosmowave Sorry it doesn't work either... 😕
                    M28 Writes the exact code into my VariableBuffer, but no the Value!..
                      NeueKlasse @NeueKlasse
                      @dc42 Thank you for the Post in the Thread "M28 + object models"
                      finally i Managed it to get it working how it should.
                      echo >"0:/macros/VariableBuffer.g" "G92 Z"^{global.ZAxisPos}^" "
                      M28/M29 doesn't work (at least in my Case..)
                      with the echo command i finally have a Variable buffer that's persistent!
                      • CNCModellerundefined
                        CNCModeller
                        Hi All,
                        Along a similar vein I'd like to track how many times the y axis stepper has rotated, as a proxy for y axis drive belt life. I think I can use this method but I don't know if there is a related variable I could interrogate.
                        Given it's a polar machine perhaps cumulative bed rotation might do it.
                        My printer tends to break belts, but insidiously such that the belt reinforcement breaks but the rubber holds and stretches causing print artefacts.
                        I'd like to track usage to define a preventative maintenance schedule.
                        I'm also fitting a heavier duty blet during this next round of upgrades 🙂
                        Any constructive thoughts would be much appreciated.
                        Cheers
                        Barry M
                        Polar Duet3 Mini + 1HCL
                        https://youtube.com/playlist?list=PLWjZVEdMv1BY82izahK45qKh-hp3NFkix
                        Wanhao D4S: Duet2
                        https://forum.duet3d.com/post/296755
                        K40 Laser, Duet2
                        https://forum.duet3d.com/post/312082
                        Wanhao D5S
                        https://www.youtube.com/CNCModellerUK
                        • o_lampeundefined
                          o_lampe @CNCModeller
                          @cncmodeller Maybe you can sum up the absolute value of the current y-position. You'd have to poll it every 0.n seconds to get a semi-accurate value, but for wear-prognose it'll do.
                          CNCModellerundefined 1 Reply Last reply Reply Quote 0
                          • o_lampeundefined
                            o_lampe @NeueKlasse
                            Just wondering if there's a way not to overwrite the file, but append new values at the file-end?
                            //edit It's simple! Using echo>><filename> <expression>, <expression>, ... does the trick.
                              CNCModeller @o_lampe
                              @o_lampe said in Does RRF have maintenance counters/timers?:
                              That might work, I'll have to think it over...
                              Wanhao D4S: Duet2
                              K40 Laser, Duet2
                              Wanhao D5S
                              • Tricep terryundefined Tricep terry referenced this topic
