    Brushless Servo using 1XD
    driver expansion 1xd servomotor wiring
    • verminsupundefined
      verminsup
      I'm converting a Stratasys printer for work and my boss want to use the original motors.
      For this I got handed these drives and duet 1XD boards
      https://www.faulhaber.com/nl/producten/serie/sc-1801-s/
      My question is how to correctly wire it, when I know how to wire it I should be able to figure out how to do the config.
      Right now my boss has wired it like this:
      5v - up
      V+ - Umot
      Gnd - V-
      Unsoll - D0_step(+)
      Dir - D0_steo (+)
        dc42 administrators @verminsup
        @verminsup unfortunately that driver doesn't appear to provide the facility to move to a specific position, only to set speed and direction.
        verminsupundefined 1 Reply Last reply Reply Quote 0
          verminsup @dc42
          @dc42 but hom am I supposed to set speed an direction? That might already be enough
          alankilianundefined 1 Reply Last reply Reply Quote 0
          • alankilianundefined
            alankilian @verminsup
            @verminsup First, are you SURE those are BLDC motors?
            I see a ribbon cable coming out of the encoder, and a two-wire connector coming out of the back of the motor, so I think they are DC motors with an incremental encoder.
            Let's start there and see what you need for a motor-position controller after determining what kind of motor you have.
            If you can post:
            • What Stratasys machine you are trying to convert
            • Links to any documents for that printer
            • Close-up photographs of the motor connections
            • Names, numbers or other markings on the motors you are trying to control
            It would help a LOT.
