    Heater config not working, why?
    Using Duet Controllers
    319
    • Chrissundefined
      Chriss
      Hi *,
      I have a problem with my new setup. (The config is still a bit "wild", do not be shocked, you have been warned. (Mini 5+ FW 3.3)
      Thing is: The bed heater does not work:
      ; Bed
      M308 S0 P"0.temp0" Y"thermistor" T100000 B4138	; configure sensor 0 as thermistor on pin temp0
      M950 H0 C"out5" T0								; create bed heater output on out0 and map it to sensor 0
      M307 H0 B0 S1.00                                 ; disable bang-bang mode for the bed heater and set PWM limit
      M140 H0                                          ; map heated bed to heater 0
      M143 H0 S120                                     ; set temperature limit for heater 0 to 120C
      I tried "out5" and "out6", with and without "1." in front. The outputs should drive a SSR. I do not measure any voltage change when I turn on the heater via the DWC. I had a close look the the MosFets next to the output, they look good. I do not measure anythings at the pins, not VIN against GND and not GND when I measure against the power supply.
      What else to test? (Jumper is still in factory default)
      Full Config:
      ; Default config.g template for DuetPi
      ; Replace this with a proper configuration file (e.g from https://configtool.reprapfirmware.org)
      ; Display initial welcome message
      ;M291 P"Please go to <a href=""https://www.duet3d.com/StartHere"" target=""_blank"">this</a> page for further instructions on how to set it up." R"Welcome to your new Duet 3!" S1 T0
      ; Hardware: Duet Mini 5+
      ; Stepper XY = LDO 0,9° 2Amax  LDO-42STH40-2004MAC
      ; Stepper Z = LDO 1,8°  2Amax  LDO-42STH48-2004AC
      ; Stepper E = LDO 1,8   1Amax  LDO-42STH20-1004ASH
      ; Enable network
      if {network.interfaces[0].type = "ethernet"}
          M552 P0.0.0.0 S1
      else
          M552 S1
      M586 P1 S1                                         ; enable FTP
      M586 P2 S1                                         ; enable Telnet
      G90                                         ; send absolute coordinates...
      M83                                         ; ...but relative extruder moves
      M550 P"v2"                                  ; set printer name
      M669 K1										; 1=select CoreXY mode   0=Cadasian
      ;; Toolboards
      ; M115 B121  ; Show board 121
      ; M997 B121  ; Update tool 121
      ; M122 B121  ; Detailed status of toolboard
      G4 S1        ; wait for expansion boards to start
      ;;; Drives
      ;X
      M569 P0.2 S1
      M584 X0.2
      ;Y
      M569 P0.1 S0
      M584 Y0.1
      ;; Z
      ; - front left
      M569 P0.5 S1									; physical drive 0.6 goes forward/backward -
      ; - front right
      M569 P0.6 S0									; physical drive 0.5 goes forward/backward -
      ; - back left
      M569 P0.0 S1									; physical drive 0.0 goes forward/backward -
      ; - back right
      M569 P0.4 S0									; physical drive 0.4 goes forward/backward -
      M584 Z0.4:0.0:0.5:0.6
      ;; E
      M569 P121.0 S0
      M584 E121.0
      ;M584 X0.2 Y0.0 Z0.3:0.4:0.5 E121.0				; set drive mapping
      M350 X16 Y16 Z16 E16 I1						; configure microstepping with interpolation
      M92 X160 Y160 Z400 E560						; set steps per mm   M92 X80.00 Y80.00 Z400.00 E420.00
      M566 X200.00 Y200.00 Z12.00 E120.00			; set maximum instantaneous speed changes (mm/min)
      M203 X6000.00 Y6000.00 Z480.00 E1200.00		; set maximum speeds (mm/min) Z180
      M201 X400.00 Y400.00 Z20.00 E250.00			; set accelerations (mm/s^2)
      M906 X1400 Y1400 Z1400 E700 I30				; set motor currents (mA) and motor idle factor in per cent
      M84 S30                                     ; Set idle timeout
      M84 S120									; Idle timeout
      M208 X0 Y0 Z0 S1                                ; set axis minima
      M208 X230 Y250 Z275 S0                          ; set axis maxima
      ;; Endstops -- Display status with: M119
      M574 Y2 S1 P"0.io5.in"	; Y
      M574 X2 S1 P"!0.io6.in"	; X
      M574 Z0 P"nil"			; No Z endstop, we have a probe
      ; Z probe
      ; Vinda: Black = Signal - Brown = +5v - Blue = GND
      M574 Z1 S2								; Configure Z-probe endstop for low end on Z
      M558 P8 C"^121.io0.in" H5 F120 T6000	; set Z probe type to bltouch and the dive height + speeds
      G31 P500 X0.1 Y-0.1						; set Z probe offset
      G31 Z0.05								; set Z probe  and trigger height
      M557 X0:270 Y0:290 S15					; define mesh grid
      ; Z-level settings
      M671 X-65:-65:365:365 Y-20:380:380:-20 S20      ; Define Z belts locations (Front_Left, Back_Left, Back_Right, Front_Right)
      M557 X25:275 Y25:275 S25                        ; Define bed mesh grid (inductive probe, positions include the Z offset!)
      ;; Heaters :: Tune with: M303 H0 S115
      ; Bed
      ; Hotend
      ; Tune in with:  M303 H1 S270       (270=Temp) (M500 to save)
      ; Show current settings M307 H1
      M308 S1 P"121.temp0" Y"thermistor" T500000 B4702 C1.171057e-7   ; configure sensor 1 as thermistor on pin temp1
      M950 H1 C"121.out0" T1										; create nozzle heater output on 0.out3 and map it to sensor 1
      M143 H1 S400												; set temperature limit for heater 1 to 320C
      ;; Fans
      ; Fan for the printed part:
      M950 F0 C"121.out1" Q500		; create fan 0 on pin 0.out9 and set its frequency
      M106 P0 S0 H-1 C"Part"			; set fan 0 value. Thermostatic control is turned off
      ; Fan for the Hotend:
      M950 F1 C"121.out2" Q500		; create fan 1 on pin 0.out9 and set its frequency
      M106 P1 S1 H1 T45 C"Hotend"		; P="set fan 1" S="value" H="Thermostatic control Heater No." T=" is turned on at 45°C"
      ;; Tool
      M563 P0 S"Tool" D0 H1 F0	; define tool
      G10 P0 X0 Y0 Z0				; set tool 0 axis offsets
      G10 P0 R0 S0				; set initial tool 0 active and standby temperatures to 0C
      ;;;;;;;;;;;; Setup Only
      ;M564 S0 H0 			; Allow movement over the endstops
      M302 P1 ; allow cold extrusion
      ;M302 S1 ; deny cold extrusion
      ;;;;;;;;;;;; Setup Only END
      M501						; Load config-override.g
      ; Serial interface
      M575 P1 B115200 S1
      ; Mini 12864
      M918 P2
      ;M918 P2 E4 R3 C100
      ;M150 X2 R255 U255 B255 S3		; set all 3 LEDs to white
      M150 X2 R0 U255 B0 S3			; set all 3 LEDs to red
      T0						; Select the tool 0 as default
      Cheers, Chriss
      • deckingmanundefined
        deckingman @Chriss
        @chriss At a guess, I'd say that it might be because the PWM frequency might be too high for your SSR. I believe that if you don't specify a value, then frequency will default to 250 for heaters. But SSRs usually need much lower values - typically 10 Hz. So try adding Q10 to you M950 command for the bed heater.
        i.e. try this: M950 H0 C"out5" T0 Q10.
        Note also that the Mosfet switches the negative side, so you won't see any change on the voltage input side of the heater connector.
        Chrissundefined 1 Reply Last reply Reply Quote 0
        • Chrissundefined
          Chriss @deckingman
          @deckingman said in Heater config not working, why?:
          I tried it, without success.
          Well, what I measure is 24V between "V_OUTLC2+" out out 5 and GND. Clear because we switch GND here. What I do not see is a change on the GND pin.
          The SSR works when I trigger it with a wire from GND of the power supply to the SSR.
          Cheers, Chriss
          • Chrissundefined
            Chriss @Chriss
            @chriss Update: I pushed two pins in the connector (the same typo of connectors as on the boad) and powered the pins. That triggered the SSR. So I do not expect any problems with the crimping or the wires.
            Cheers, Chriss
            • Chrissundefined
              Chriss @Chriss
              @chriss I tested now with out0, same result. I do not get the SSR working, I see no GND on the ground pin.
              I thing that I should see the LED next to the connector blinking (out0), shouldn't I? (The LED remains off)
              Cheers, Chriss
              • Chrissundefined
                Chriss @Chriss
                @chriss
                This here works funnily:
                M950 F3 C"0.out0" Q10   ; LED on out6 ground on top pin, plus on 3rd pin from top (V_OUTLC1)
                M106 P3 C"LED" S0
                So something is wrong with my heater here....
                • Chrissundefined
                  Chriss @Chriss
                  @chriss
                  The config.g looks now like that:
                  ; Enable network
                      M552 P0.0.0.0 S1
                  else
                      M552 S1
                  ; Bed
                  ;M308 S0 P"0.temp0" Y"thermistor" T100000 B4138	; configure sensor 0 as thermistor on pin temp0
                  ;M950 H0 C"out6" T0 Q10							; create bed heater output on out0 and map it to sensor 0
                  ;M307 H0 B0 S1.00                                 ; disable bang-bang mode for the bed heater and set PWM limit
                  ;M140 H0                                          ; map heated bed to heater 0
                  ;M143 H0 S120                                     ; set temperature limit for heater 0 to 120C
                  ; Bed
                  M308 S0 P"temp0" Y"thermistor" T100000 B4138     ; configure sensor 0 as thermistor on pin temp0
                  M950 H0 C"out0" T0                               ; create bed heater output on out0 and map it to sensor 0
                  M143 H0 S120
                  All other .g files where removed. And I still do not see the LED next to out0 blinking.
                  I have two more of the Mini 5+ and use exactly the same code on them and it works there. :?
                  Cheers, Chriss
                  • Chrissundefined
                    Chriss @Chriss
                    @chriss
                    I upgraded to "3.4.0beta3 (2021-08-24)" now and you guys know what? The heater works now. Why? I have no idea..... :? Maybe a bit more "reset" than with a normal reboot? I have no idea at all.
                    Anyway, it works now...
                    Cheers, Chriss
                      Very strange. Please keep us posted.
                      • Chrissundefined
                        Chriss @Phaedrux
                        @phaedrux
                        I will keep you guys up to date when I have that again.
                        Cheers, Chriss
