    Duet rebooting mid print
    Using Duet Controllers
    675
    • vrghostundefined
      vrghost
      I have hit an odd issue of duet rebooting while printing. This is first three-material print I am attempting on the e3d Toolchanger and all three print attempts I've made so far have failed at the approximately same spot. So I am wondering if the controller is overheating. I believe that I am using the latest and greatest 3.3 firmware build.
      Here is the M112 output:
      10/09/2021, 16:14:52    M122
      RepRapFirmware for Duet 2 WiFi/Ethernet version 3.3 (2021-06-15 21:44:54) running on Duet WiFi 1.02 or later + DueX5
      Board ID: 0JD0M-9P6B2-NJ4S8-6JKD4-3S86K-9A76L
      Used output buffers: 3 of 24 (19 max)
      Static ram: 23876
      Dynamic ram: 78152 of which 12 recycled
      Never used RAM 9520, free system stack 184 words
      Tasks: NETWORK(ready,14.7%,231) HEAT(delaying,0.0%,330) Move(notifyWait,0.1%,319) DUEX(notifyWait,0.0%,24) MAIN(running,85.1%,441) IDLE(ready,0.1%,29), total 100.0%
      Owned mutexes: WiFi(NETWORK) HTTP(MAIN)
      Last reset 00:12:54 ago, cause: software
      Last software reset at 2021-09-10 16:01, reason: OutOfMemory, GCodes spinning, available RAM 660, slot 1
      Software reset code 0x41c3 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x0041f000 BFAR 0xe000ed38 SP 0x200024f0 Task MAIN Freestk 877 ok
      Stack: 2001998c 0040f871 00000063 0040fa4f 00000008 0000031c 2001a70a 0040633f 20019744 00000005 20019744 00406455 20019744 2000259c 20019744 00000005 20002594 004064a3 00000000 2000259c 20019e54 20001488 20002618 20019744 00000000 004064c7 20019744
      Error status: 0x00
      Aux0 errors 0,0,0
      Step timer max interval 0
      MCU temperature: min 38.7, current 39.1, max 45.1
      Supply voltage: min 24.1, current 24.3, max 24.4, under voltage events: 0, over voltage events: 0, power good: yes
      Heap OK, handles allocated/used 99/4, heap memory allocated/used/recyclable 2048/94/0, gc cycles 0
      Driver 0: position 0, standstill, SG min/max not available
      Driver 1: position 0, standstill, SG min/max not available
      Driver 2: position 0, standstill, SG min/max not available
      Driver 5: position 0, standstill, SG min/max not available
      Driver 6: position 0, standstill, SG min/max not available
      Driver 7: position 0, standstill, SG min/max not available
      Driver 8: position 0, standstill, SG min/max not available
      Driver 9: position 0, standstill, SG min/max not available
      Driver 10: position 0
      Driver 11: position 0
      Date/time: 2021-09-10 16:14:50
      Slowest loop: 4.60ms; fastest: 0.17ms
      === Storage ===
      Free file entries: 10
      SD card longest read time 3.4ms, write time 0.0ms, max retries 0
      === MainDDARing ===
      === AuxDDARing ===
      Segments left: 0
      Movement lock held by null
      HTTP is ready with "M122 " in state(s) 0
      Telnet is idle in state(s) 0
      File is idle in state(s) 0
      USB is idle in state(s) 0
      Aux is idle in state(s) 0
      Trigger is idle in state(s) 0
      Queue is idle in state(s) 0
      LCD is idle in state(s) 0
      Daemon is idle in state(s) 0
      Code queue is empty.
      === DueX ===
      Read count 1, 0.08 reads/min
      === Network ===
      Slowest loop: 16.01ms; fastest: 0.00ms
      HTTP sessions: 1 of 8
      - WiFi -
      Network state is active
      WiFi firmware version 1.23
      WiFi MAC address e0:98:06:22:d0:49
      WiFi Vcc 3.36, reset reason Turned on by main processor
      WiFi flash size 4194304, free heap 23856
      WiFi IP address 192.168.242.45
      WiFi signal strength -54dBm, mode none, reconnections 0, sleep mode modem
      Clock register ffffffff
      And the config.g can be found here (amongst any and all other scripts I'm using on the machine).
      I wasn't able to find any "Software reset code" tables or alike. Any suggestions/help are greatly appreciated.
      mrenz999undefined 1 Reply Last reply Reply Quote 0
      • vrghostundefined
        vrghost
        Ugh, I've just noticed the
        @vrghost said in Duet rebooting mid print:
        reason: OutOfMemory
        message.
        I guess I've got little bit too carried away with the scripting. Is there any way I can release a variable or get more RAM? 🤡
          dc42 administrators @vrghost
          @vrghost I am surprised that you are running out of memory. Please share the file that you are trying to print.
          vrghostundefined 1 Reply Last reply Reply Quote 0
          • vrghostundefined
            vrghost @dc42
            Here is the file
            Tool-Changer Cover Long.gcode
            And here is the event log from the last print I've attempted (with the gcode whereabouts)
            eventlog.txt
              Can you also share your config.g and any other macros that get called along the way?
              • mrenz999undefined
                mrenz999 @vrghost
                @vrghost I had a similar issue. Did not reboot just stopped printing twice now. Once 3 mins in the second time 6 mins in. I checked on printer both times to find the heaters off, bed and tool, and it stopped. No errors reported just not printing.
                gloomyandyundefined dc42undefined 2 Replies Last reply Reply Quote 0
                • vrghostundefined
                  vrghost @Phaedrux
                  @phaedrux
                  Of course I can.
                  https://github.com/VRGhost/tc-rrf/blob/main/dist/ilo-tc/sys/config.g
                  All other scripts can be found in that repo too.
                  • gloomyandyundefined
                    gloomyandy @mrenz999
                    @mrenz999 If your board is not resetting it is likely that you have a different problem, so you will probably get better help if you start a new thread and describe exactly what happens along with posting the output from running m122 along with your config.g file.
                    mrenz999undefined 1 Reply Last reply Reply Quote 1
                    • mrenz999undefined
                      mrenz999 @gloomyandy
                      @gloomyandy Will do. My heaters just turned off mid print. So no board reset.
                        dc42 administrators @mrenz999
                        @mrenz999 said in Duet rebooting mid print:
                        Did you run M122 and check the last reset time, to see if it was caused by a power glitch?
                        • vrghostundefined
                          vrghost
                          In my attempts to make a minimal code to replicate the issue, I've stumbled on another bit of unexpected behavior.
                          If one declares a local variable on the top level of a "job" (a file that is put into the "gcodes" directory on the duet), that local variable is NOT released upon completion of the job. So, a second run of the same gcode is aborted with the
                          M32 "0:/gcodes/min_bug.gcode"
                          File 0:/gcodes/min_bug.gcode selected for printing
                          Error: in GCode file line 2 column 16: meta command: variable 'outer_idx' already exists
                          Cancelled printing file 0:/gcodes/min_bug.gcode, print time was 0h 0m
                          message.
                          To replicate just run this gcode file as a print job twice.
                          min_var_bug.gcode
                          • vrghostundefined
                            vrghost
                            Also, is "abort" command preventing GC of local vars?
                            The file below works as expected on the first run, but the execution starts with "outer_idx" set to 3 when running the job second time.
                            min_abort_bug.gcode
                              That one has already been reported, and fixed in 3.4beta3.
                                @vrghost I've run that macro several times, using M98 from DWC, and it produces the same output each time. So I think this one is also fixed already.
                                Did you manage to create a file that causes all the memory to be used up?
