    [Solved][Duet2Wifi] WiFi SPI Timeout after removing SBC Mod
    781
    • keyz182undefined
      keyz182
      I have a pair of Duet Wifi 2 boards (1.02 and 1.03) that were modded with this SBC mod. I'm aware it's almost certainly voided the warranty (which would have run out anyway), so just looking for advice/pointers.
      I've upgraded to Duet 3 Minis, so was going to sell these two boards. In preparation, I removed the mod board and got everything reset to factory. I reflashed the firmware with BOSSA, loaded up a new SD card, and ran M997 S1 to flash the Wifi firmware.
      Unfortunately on both boards I just get SPI timeouts when trying to do anything with the WiFi. I thought I might have somehow borked the ESP boards so I replaced them (with ESP-07S, as Farnell sent out those instead of the 12S), reflashed with M997 S1 but still the same SPI timeout.
      Can't see any solder bridges, or any other components that may have shifted/desoldered.
      I've tried the latest 3.2 and 3.3 firmwares to no avail. Any ideas what to check, or what may be the cause?
      RepRapFirmware for Duet 2 WiFi/Ethernet version 3.3
      Printer is now online.
      >>>M122
      SENDING:M122
      RepRapFirmware for Duet 2 WiFi/Ethernet version 3.3 (2021-06-15 21:44:54) running on Duet WiFi 1.02 or later
      Board ID: 08DGM-956GU-DJMSN-6J9FL-3SD6S-TTRHH
      Used output buffers: 1 of 24 (1 max)
      Static ram: 23876
      Dynamic ram: 73544 of which 12 recycled
      Never used RAM 16984, free system stack 193 words
      Tasks: NETWORK(ready,1.9%,517) HEAT(delaying,0.0%,391) Move(notifyWait,0.1%,364) MAIN(running,66.1%,639) IDLE(ready,31.9%,29), total 100.0%
      Owned mutexes: USB(MAIN)
      Last reset 00:00:12 ago, cause: reset button or watchdog
      Last software reset at 2021-09-09 14:06, reason: User, GCodes spinning, available RAM 15512, slot 0
      Software reset code 0x0003 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x00400000 BFAR 0xe000ed38 SP 0x00000000 Task MAIN Freestk 0 n/a
      Error status: 0x00
      [ERROR] Error status: 0x00
      Step timer max interval 0
      MCU temperature: min 36.9, current 37.1, max 37.3
      Supply voltage: min 1.7, current 1.7, max 1.7, under voltage events: 0, over voltage events: 0, power good: no
      Driver 0: position 0, ok, SG min/max not available
      Driver 1: position 0, ok, SG min/max not available
      Driver 2: position 0, ok, SG min/max not available
      Driver 3: position 0, ok, SG min/max not available
      Driver 4: position 0, ok, SG min/max not available
      Driver 5: position 0
      Driver 6: position 0
      Driver 7: position 0
      Driver 8: position 0
      Driver 9: position 0
      Driver 10: position 0
      Driver 11: position 0
      Cache data hit count 716504001
      Slowest loop: 0.22ms; fastest: 0.13ms
      === Storage ===
      Free file entries: 10
      SD card 0 detected, interface speed: 12.0MBytes/sec
      === MainDDARing ===
      === AuxDDARing ===
      Bed heaters = -1 -1 -1 -1, chamberHeaters = -1 -1 -1 -1
      Segments left: 0
      Movement lock held by null
      HTTP is idle in state(s) 0
      Telnet is idle in state(s) 0
      File is idle in state(s) 0
      USB is ready with "M122" in state(s) 0
      Aux is idle in state(s) 0
      Trigger is idle in state(s) 0
      Queue is idle in state(s) 0
      LCD is idle in state(s) 0
      Daemon is idle in state(s) 0
      Code queue is empty.
      === Network ===
      Slowest loop: 0.18ms; fastest: 0.00ms
      HTTP sessions: 0 of 8
      - WiFi -
      Network state is disabled
      WiFi module is disabled
      Failed messages: pending 2779096485, notready 2779096485, noresp 2779096485
      >>>M552 S1
      SENDING:M552 S1
      WiFi module started
      WiFi reported error: no known networks found
      WiFi module is idle
      >>>M587 S"IoT_2G" P"********"
      SENDING:M587 S"IoT_2G" P"********"
      Error: M587: Failed to add SSID to remembered list: SPI timeout
      [ERROR] Error: M587: Failed to add SSID to remembered list: SPI timeout
      Error retrieving WiFi status message: SPI timeout
      [ERROR] Error retrieving WiFi status message: SPI timeout
      WiFi module is idle
      Failed to change WiFi mode: SPI timeout
      >>>M552 S1
      SENDING:M552 S1
      WiFi module started
      >>>M122
      SENDING:M122
      Static ram: 23876
      Tasks: NETWORK(ready,3.9%,461) HEAT(delaying,0.0%,391) Move(notifyWait,0.1%,364) MAIN(running,73.4%,639) IDLE(ready,22.6%,29), total 100.0%
      Last reset 00:00:17 ago, cause: reset button or watchdog
      Error status: 0x00
      MCU temperature: min 36.5, current 38.1, max 38.3
      Cache data hit count 920185181
      Slowest loop: 99.74ms; fastest: 0.12ms
      === Storage ===
      === MainDDARing ===
      === AuxDDARing ===
      Segments left: 0
      === Network ===
      Slowest loop: 1.28ms; fastest: 0.00ms
      - WiFi -
      Network state is changingMode
      WiFi module is idle
      Failed to get WiFi status
      WiFi module is idle
      Front
      Back
      Closeup
      • T3P3Tonyundefined
        T3P3Tony administrators @keyz182
        @keyz182 did the firmware flash sucessfully?
        www.duet3d.com
        keyz182undefined 1 Reply Last reply Reply Quote 0
        • keyz182undefined
          keyz182 @T3P3Tony
          @t3p3tony
          Connecting...
          >>>M997 S1
          SENDING:M997 S1
          Trying to connect at 230400 baud:
           success
          Erasing 4096 bytes...
          Erasing 196608 bytes...
          Uploading file...
          5% complete
          10% complete
          15% complete
          20% complete
          25% complete
          30% complete
          35% complete
          40% complete
          45% complete
          50% complete
          55% complete
          60% complete
          65% complete
          70% complete
          75% complete
          80% complete
          85% complete
          90% complete
          95% complete
          Upload successful
          And for good measure I did an M997 S0 too which correctly reports 3.3 after a restart and M122.
          • T3P3Tonyundefined
            @keyz182 ok to the UART comms to the module is working. Have a look at the schematic here
            https://github.com/Duet3D/Duet-2-Hardware/blob/master/Duet2/Old versions/DuetWifiv1.02/DuetWifi_Schematic_v1.02.pdf
            you can test the continuity for the SPI pins
            www.duet3d.com
            keyz182undefined 2 Replies Last reply Reply Quote 0
            • keyz182undefined
              keyz182 @T3P3Tony
              @t3p3tony Continuity to the MCU for MOSI, MISO and SPCK, any other pins I should check?
              • keyz182undefined
                keyz182 @T3P3Tony
                @t3p3tony There's continuity on all three.
                • T3P3Tonyundefined
                  @keyz182 also the ESP_DATA_RDY and NPCS0
                  www.duet3d.com
                  keyz182undefined albertshaoundefined 2 Replies Last reply Reply Quote 0
                    dc42 administrators @keyz182
                    @keyz182 is the SPI timeout message consistent? That message is sometimes produced spuriously, especially when sending a M587 command for the first time after re-flashing the WiFi firmware.
                    • keyz182undefined
                      keyz182 @T3P3Tony
                      @t3p3tony Continuity (through 2.2KOhm) on both which seems to tally up with the schematic.
                      @dc42 It's consistent. Right after a flash, leaving it a while, rebooting, etc, all the same as soon as I try M587 or M122.
                      Connecting...
                      >>>M552 S1
                      SENDING:M552 S1
                      WiFi module started
                      WiFi module is idle
                      WiFi module is idle
                      WiFi module is idle
                      WiFi module is idle
                      WiFi module is idle
                      WiFi module is idle
                      WiFi module is idle
                      WiFi module is idle
                      WiFi module is idle
                      >>>M552 S-1
                      SENDING:M552 S-1
                      >>>M552 S0
                      SENDING:M552 S0
                      WiFi module started
                      >>>M552 S1
                      SENDING:M552 S1
                      WiFi module is idle
                      WiFi module is idle
                      WiFi module is idle
                        jay_s_uk @keyz182
                        @keyz182 can you try sending M552 S0 before trying M587?
                        I find its sometimes not happy sending the wifi details when in S1
                        keyz182undefined 1 Reply Last reply Reply Quote 1
                        • keyz182undefined
                          keyz182 @jay_s_uk
                          @jay_s_uk OK, that worked. Is that documented behavior that I've just misread? I swear I've always done M552 S1 before any M587 commands.
                            jay_s_uk @keyz182
                            @keyz182 the step by step guide does say to put it in S0 mode first.
                            Its also they way I've documented it on all the STM32/LPC port support pages.
                            • albertshaoundefined
                              albertshao @T3P3Tony
                              @t3p3tony what do ESP_DATA_RDY and NPCS0 for? can this to pin connect to GND or 3.3V pull up, thanks for reply
