SD card not detected by Paneldue, until I detect via DWC
PanelDue
  • undefined
    jbergene
    hey
    running latest versions of beta 3.4
    latest version paneldue and latest DWC
    When I plug in the SD into the Paneldue, I have to detect it first via the DWC by pressing SD card #1
    If i dont do that it never shows up on the SD card list on panel due.
    • undefined
      mfs12
      Hey @jbergene to access a second sd card you need to open the files dialog and press on top left the 'Files on card X' button.
      Did you do that?
      • undefined
        mfs12
        This post is deleted!
        • undefined
          mfs12
          @jbergene thanks for reporting this issue.
          I created an issue at github. Any further progress will be done there.
          https://github.com/Duet3D/PanelDueFirmware/issues/207
          mfs12 created this issue 23 Sept 2021, 07:35 in Duet3D/PanelDueFirmware
          closed Wrong number for available sd card slots is use #207
          • undefined
            mfs12
            Will be part of next release.
            undefined 1 Reply Last reply 26 Sept 2021, 06:44 Reply Quote 1
            • undefined
              RomanVin
              I registered the M21 P1 config.g in the initial lines and the card slot started working. A little crooked solution but working. Condition - the card must be in the slot. Or, after installing the card, reset the controller.
              • undefined
                jbergene @mfs12
                @mfs12 thank you
                2 out of 7
