    Crashes during printing - "SPI connection has been reset".
    1.5k
    • jbjhjmundefined
      jbjhjm
      hey there. For a few days now I'm randomly experiencing crashes amid running prints.
      Just happened for the third time now. I'm using a Duet3 6HC + Raspi 4 + Toolboard.
      Also it is important to note that I'm running 3.4beta3 firmware.
      But as far as I can remember, the issue did not start with the firmware change.
      I ran a bunch of successful prints, error started just 2 days ago.
      What I was able to find out:
      DWC was not available through network anymore.
      DWC was available using a touchscreen connected to the Raspi though.
      There, DWC console had a log entry stating "SPI connection has been reset".
      Hitting the Emergency reset GUI button worked, so at least some connection between Duet + Raspi seems to be available.
      So it either could be a hint for a firmware bug, or it might be an issue with my hardware / setup.
      I'm not sure how to proceed. Any advice?
      SIamundefined 1 Reply Last reply Reply Quote 0
      • SIamundefined
        SIam @jbjhjm
        @jbjhjm If this happens, try to get the result of M122 and post it here also print the result of M115 and your config.g file
        Hypercube-Evolution-Hybrid, Piezo Orion, Orbiter
        Duet WiFi 1.02 or later + DueX5
        RepRapFirmware for Duet 2 WiFi/Ethernet 3.4.0beta4 (2021-09-27 11:30:36)
        Duet WiFi Server: 1.26
        Duet Web Control 3.4.0beta4 (2021-09-27)
        jbjhjmundefined 1 Reply Last reply Reply Quote 0
        • jbjhjmundefined
          jbjhjm @SIam
          @siam ok will try to do so the next time it happens! In the meantime, I will need to take a look at the raspi wifi connection. I feel like it is getting worse over time, at start everything is fine, now the video stream runs at < 1 fps and ping varies between 100 and 3000 ms. Truly weird.
          Edit: Ok ignore that, it seems it's not raspberry / duet causing the bad connection. Something's off with my wifi network.
          • jbjhjmundefined
            jbjhjm
            Just half an hour ago it happened again, 3 hours into a perfectly fine print.
            Happens on absolutely random positions and not very often.
            Think this was the third time, so lets say it happens on 1 out of 10 prints, sometimes minutes after starting, sometimes hours into the print. I checked what gcode lines were executing and there's nothing special. It stopped half way through a simple G1 Move/Extrude.
            As DWC / network connection would always crash in this case, I used the touch panel to run M115 and M122 and took photos:
            Then I set up USB/Serial connection to the 6HC using YAT.
            M115:
            FIRMWARE_NAME: RepRapFirmware for Duet 3 MB6HC FIRMWARE_VERSION: 3.4.0beta3 ELECTRONICS: Duet 3 MB6HC v1.01 or later FIRMWARE_DATE: 2021-08-24 13:58:02
            After that, the console continued to log...
            (19:36:07.449) Lost connection to Linux
            (19:36:07.948) Connection to Linux established!
            (19:37:02.172) Lost connection to Linux
            (19:37:02.668) Connection to Linux established!
            (19:37:56.846) Lost connection to Linux
            (19:37:57.383) Connection to Linux established!
            (19:38:51.540) Lost connection to Linux
            (19:38:52.103) Connection to Linux established!
            With a bit less than 60 seconds in between, these messages seem to correlate with the SPI error messages.
            Then I did a M112 instead of a M122 - emergency reset. DAMN.
            M112 showed an interesting behavior again:
            • 6HC reacted to it and seemed to restart
            • the panel connected to the pi reacted too - however the panels only reaction was showing the overlay stating it is trying to reconnect.
            • Toolboard red LED was blinking fast
            Then nothing more happened.
            Sent a M115 again, same result as before, nothing else happened.
            Then sent a M122 with more unexpected results.
            • 6HC reacted to it again (could hear it as the attached fans reduced speed)
            • pi/panel ended displaying the reconnect dialog, console logs SPI connection reset warning every ~55 seconds again.
            • toolboard started to blink slowly again stating it's connected again
            • M122 did not log anything though
            • 6HC seems not to react to serial commands anymore.
            • Interestingly, the pi->duet connection seems to PARTIALLY work. I was able to control the hotend heater using the panel.
            Reconnected terminal and sent M122 again, this time it returned data.
            The "Last software reset at 2021-10-11 19:27" correlates with when I sent the M115 mentioned above.
            (19:35:56.159) === Diagnostics ===
            (19:35:56.159) RepRapFirmware for Duet 3 MB6HC version 3.4.0beta3 (2021-08-24 13:57:45) running on Duet 3 MB6HC v1.01 or later (SBC mode)
            (19:35:56.159) Board ID: 08DJM-9P63L-DJMSS-6JKDJ-3S86L-98DB9
            (19:35:56.159) Used output buffers: 2 of 40 (12 max)
            (19:35:56.159) === RTOS ===
            (19:35:56.159) Static ram: 151160
            (19:35:56.159) Dynamic ram: 62680 of which 324 recycled
            (19:35:56.159) Never used RAM 136460, free system stack 190 words
            (19:35:56.159) Tasks: SBC(notifyWait,0.4%,326) HEAT(notifyWait,0.0%,320) Move(notifyWait,0.0%,276) CanReceiv(notifyWait,0.0%,772) CanSender(notifyWait,0.0%,374) CanClock(delaying,0.0%,339) TMC(notifyWait,7.3%,59) MAIN(running,92.2%,922) IDLE(ready,0.0%,29), total 100.0%
            (19:35:56.159) Owned mutexes: USB(MAIN)
            (19:35:56.159) === Platform ===
            (19:35:56.159) Last reset 00:08:28 ago, cause: software
            (19:35:56.159) Last software reset at 2021-10-11 19:27, reason: HardFault, GCodes spinning, available RAM 132404, slot 0
            (19:35:56.159) Software reset code 0x0063 HFSR 0x40000000 CFSR 0x00000082 ICSR 0x0044a803 BFAR 0x00000038 SP 0x2041ade0 Task MAIN Freestk 1431 ok
            (19:35:56.159) Stack: 00000000 2041ae78 2041ae7c 2041ae80 00000000 00472b2f 004792f0 610f0200 0a302029 6e6e7500 20676e69 7263616d ff000a6f ffffffff ffffffff ffffffff ffffffff ffffffff ffffffff 2042e5c0 00000000 00000000 00000000 00000000 00000000 204291d0 00000000
            (19:35:56.159) Error status: 0x00
            (19:35:56.159) Step timer max interval 131
            (19:35:56.159) MCU temperature: min 36.8, current 39.0, max 39.1
            (19:35:56.159) Supply voltage: min 23.8, current 23.9, max 23.9, under voltage events: 0, over voltage events: 0, power good: yes
            (19:35:56.159) 12V rail voltage: min 12.1, current 12.1, max 12.2, under voltage events: 0
            (19:35:56.159) Heap OK, handles allocated/used 0/0, heap memory allocated/used/recyclable 0/0/0, gc cycles 0
            (19:35:56.159) Driver 0: position 0, standstill, reads 41029, writes 18 timeouts 0, SG min/max 0/133
            (19:35:56.159) Driver 1: position 0, standstill, reads 41030, writes 18 timeouts 0, SG min/max 0/119
            (19:35:56.159) Driver 2: position 200, standstill, reads 41030, writes 18 timeouts 0, SG min/max 0/122
            (19:35:56.159) Driver 3: position 0, standstill, reads 41033, writes 15 timeouts 0, SG min/max 0/0
            (19:35:56.159) Driver 4: position 0, standstill, reads 41033, writes 15 timeouts 0, SG min/max 0/0
            (19:35:56.159) Driver 5: position 0, standstill, reads 41037, writes 11 timeouts 0, SG min/max 0/0
            (19:35:56.159) Date/time: 2021-10-11 19:35:56
            (19:35:56.159) Slowest loop: 24.80ms; fastest: 0.04ms
            (19:35:56.159) === Storage ===
            (19:35:56.159) Free file entries: 10
            (19:35:56.159) SD card 0 not detected, interface speed: 37.5MBytes/sec
            (19:35:56.159) SD card longest read time 0.0ms, write time 0.0ms, max retries 0
            (19:35:56.159) === Move ===
            (19:35:56.159) DMs created 125, segments created 2, maxWait 2363ms, bed compensation in use: mesh, comp offset 0.000
            (19:35:56.159) === MainDDARing ===
            (19:35:56.159) Scheduled moves 1, completed moves 1, hiccups 0, stepErrors 0, LaErrors 0, Underruns [0, 0, 1], CDDA state -1
            (19:35:56.159) === AuxDDARing ===
            (19:35:56.159) Scheduled moves 0, completed moves 0, hiccups 0, stepErrors 0, LaErrors 0, Underruns [0, 0, 0], CDDA state -1
            (19:35:56.159) === Heat ===
            (19:35:56.159) Bed heaters = 0 -1 -1 -1 -1 -1 -1 -1 -1 -1 -1 -1, chamberHeaters = -1 -1 -1 -1
            (19:35:56.159) === GCodes ===
            (19:35:56.159) Segments left: 0
            (19:35:56.159) Movement lock held by null
            (19:35:56.159) HTTP* is idle in state(s) 0
            (19:35:56.159) Telnet is idle in state(s) 0
            (19:35:56.159) File is idle in state(s) 0
            (19:35:56.159) USB is ready with "m122" in state(s) 0
            (19:35:56.159) Aux is idle in state(s) 0
            (19:35:56.159) Trigger* is idle in state(s) 0
            (19:35:56.159) Queue is idle in state(s) 0
            (19:35:56.159) LCD is idle in state(s) 0
            (19:35:56.159) SBC is idle in state(s) 0
            (19:35:56.159) Daemon is idle in state(s) 0
            (19:35:56.159) Aux2 is idle in state(s) 0
            (19:35:56.159) Autopause is idle in state(s) 0
            (19:35:56.159) Code queue is empty
            (19:35:56.159) === CAN ===
            (19:35:56.159) Messages queued 4606, received 11159, lost 0, longest wait 2ms for reply type 6049, peak Tx sync delay 355, free buffers 49 (min 48), ts 2544/2543/0
            (19:35:56.159) Tx timeouts 0,0,0,0,0,0
            (19:35:56.159) === SBC interface ===
            (19:35:56.159) State: 4, failed transfers: 0, checksum errors: 0
            (19:35:56.159) Last transfer: 10ms ago
            (19:35:56.159) RX/TX seq numbers: 6175/1699
            (19:35:56.159) SPI underruns 0, overruns 0
            (19:35:56.159) Disconnects: 9, timeouts: 9, IAP RAM available 0x2c42c
            (19:35:56.159) Buffer RX/TX: 0/0-0
            (19:35:56.159) ok
            SSHing onto the pi / accessing DWC by network still was impossible.
            • jbjhjmundefined
              jbjhjm
              Tried to find out more on the Pi side, but as it disconnected from network permanently, I cannot ssh onto it without a full restart, which will likely wipe relevant temp data.
              yeah. Not much left to analyze.
              For better preparation for a next crash I have tweaked log settings:
              • /opt/dsf/conf/config.json -> logLevel = debug
              • /etc/systemd/journald.conf -> Storage=persistent
              • jbjhjmundefined
                jbjhjm
                Updated to the latest beta 4. Reading through the changelog I don't think it will change anything regarding the SPI connection issue.
                Any ideas how to continue debugging next time it happens?
                What technical reason is there for the SPI connection failure message to appear?
                • chrishammundefined
                  chrishamm administrators @jbjhjm
                  @jbjhjm Those log settings are far from ideal and in fact I got the same symptoms with persistent logging and long prints as well. The reason is that systemd flushes lots and lots of messages to the SD card in regular intervals, which probably stalls IO access and/or the stdout line at some point (due to the massive amount of log messages; more than 3x the regular G-code file length per print). Either reset LogLevel back to "info" or change the journald storage to "volatile".
                  When DCS becomes unresponsive at some point (probably during a full SPI transfer and longer than 500ms), RRF thinks the Pi lost communication so it invalidates everything.
                  If the resets persist with the standard log level, try out a different SD card and/or reduce IO load on the Pi as far as possible.
                  Duet software engineer
                  • jbjhjmundefined
                    jbjhjm @chrishamm
                    @chrishamm oh dear, thanks for the warning. Will revert the log settings to be more lightweight.
                    I did only tweak these yesterday, so all crashes until now happened with standard log settings.
                    I'm using the SD card shipped with the 6HC, but can try to get a different one.
                    So your guess is the error appears because the Pi is too busy to respond to RRF in time?
                    Besides the RRF communication it handles streaming camera data. I can try to lower fps/resolution.
                      @jbjhjm Yes, I think so. If the logging provider hangs during SPI transfers, it's likely to reset the connection state.
                      • jbjhjmundefined
                        jbjhjm
                        Experienced a crash again, this time it's been different though.
                        Duet suddenly stated the print was 100% done. No other errors.
                        I was not able to do a M115 / M122 this time, but the Raspi still has persistent logging enabled.
                        I will check these logs later and see if anything useful is in there.
                        One thing making me suspicious is I'm having a terrible lot of network disconnects.
                        Whenever a print fails, DWC is offline too, and outside of erronous situations DWC/Webcam sometimes reacts very slow too.
                        I'll do some investigation on how to monitor CPU and network load on the Pi.
                        • T3P3Tonyundefined
                          T3P3Tony administrators @jbjhjm
                          @jbjhjm its also worth ensuring you are giving the Pi enough voltage. look for undervoltage events in the logs
                          www.duet3d.com
                          • jbjhjmundefined
                            jbjhjm @T3P3Tony
                            @t3p3tony thank you, will do!
                            I applied a number of changes today, let's see how they work out:
                            • using 3.4.0b5 now
                            • disabled logging as suggested by @chrishamm - my yesterday's print logged a whopping 1.5 GB. 😵
                            • reduced webcam resolution
                            • installed htop to track CPU/Mem performance
                            • [external] modified my wifi setup; a wifi repeater was causing network performance issues. It would not surprise me if it also affected DWC / pi performance
                            htop stats say that 70-90 % of CPU load is caused by a chromium process. Unfortunately chromium always runs many parallel processes so it is difficult to investigate what this is actually doing.
                            • T3P3Tonyundefined
                              @jbjhjm if you are not running DWC local to the Pi then you can obviously not run chromium at all. If you are running DWC on that Pi then see what its at with only DWC open
                              www.duet3d.com
                              • jbjhjmundefined
                                jbjhjm @T3P3Tony
                                @t3p3tony no voltage issues reported so far by vcgencmd.
                                I'm not sure I understand what you meant with your last comment.
                                DWC is running on the Pi (at least as far as I understand Duet's SPC mode, all that is handled by the Pi while the mainboard only handles printing and reports back values?).
                                DWC also is the only opened chromium tab.
                                Nontheless chromium runs a bunch of different processes.
                                In Time/CPU columns you can see though that there is just one chromium process that uses lots of CPU time.
                                • T3P3Tonyundefined
                                  @jbjhjm I mean are you running the Pi headless and connecting via a network interface on the Pi to the webserver, or do you have a screen connected to a pi and running DWC in a browser on the Pi?
                                  www.duet3d.com
                                  • jbjhjmundefined
                                    jbjhjm @T3P3Tony
                                    @t3p3tony ah now I get you. It's both, the pi has a permanently attached screen, and I often access DWC through network too for more complex tasks and if I'm not in the same room.
                                    • jbjhjmundefined
                                      jbjhjm
                                      ok it seems that the pi's network connection has again crashed just a few minutes ago; it's still listed in the routers active devices list, responds to pings, but DWC does not load anymore. The print is still being executed though.
                                      So I checked what happened on the touch panel: Chrome displayed a white page + a note that it has crashed and if it should reload.
                                      Now this is weird: I dismissed that message, exited fullscreen and then saw another instance of Chrome running below the crashed instance!
                                      I have no clue why it is there. I did not tweak the startup routine provided by duetPi.
                                      After closing the crashed chrome window, it seems that the network connection was recreated too...
                                      Nothing really useful in journal (re-enabled logging hoping to hunt down networking issues). Just way too many network connection losses and reconnects. This is related to the bad wifi that I still have to improve. Disallowed auto-switching frequency bands and 2.4/5Ghz, hopefully that will make the connection a bit more robust.
                                      • T3P3Tonyundefined
                                        @jbjhjm I hope @chrishamm has some ideas about what to look for in the logs as a cause of this.
                                        www.duet3d.com
                                        • jbjhjmundefined
                                          jbjhjm @T3P3Tony
                                          @t3p3tony when my next print is completed I'll do a full restart and check chrome status right after, if two instances are running and such.
                                          If someone can point me into the right direction for finding the duetPi startup script, I'll check if there's anything unusual going on.
                                          Attached bootlog.txt by the way.
                                          Don't know enough about raspi + linux to spot anything useful unfortunately.
                                          • jbjhjmundefined
                                            jbjhjm @jbjhjm
                                            The duplicate chromium seems to be related to beta5.
                                            Just did a full restart and the screen showed a crashed chromium window right away.
                                            This has never happened before so I'm quite sure it has to do with beta5.
                                            Opened a but report to discuss this separately.
                                            https://forum.duet3d.com/topic/25542/3-4-b5-bug-chromium-crashes-on-startup-sbc
