InputShaping-Plugin-0.2.0-pre4 released
changes from pre3 to pre4:
1c1 < # release notes for inputshaping plugin 0.2.0-pre3 --- > # release notes for inputshaping plugin 0.2.0-pre4 29a30 > - home device only if not homed 31a33,36 > - added more parameter validation for test and algorithm > - disable tab record tab when no algorithms defined > - disable tab chart when no records available > - improved error reporting 35c40,53 < - fix initial filtering of records by axis --- > - fixed initial filtering of records by axis > - fixed session cleanup when session is deleted > - fixed data handling when swapping sessions > - fixed can address handling (needs more testing) > - fixed record integrity when referenced algorithm is changed > - fixed CAN address handling when address is null > > ## known issues > > - parameter validation doesn't cover every situation > > ## downloads > > - https://github.com/mfs12/DuetWebControl/releases/tag/inputshaping-plugin-0.2.0-pre4
@Heartleander81, can you test the updated release if this sorted out your problem? I would be interested in your feedback.
can't install itsomething was going wrong, I'm sure that I have installed the latest DWC but today is the old DWC shown ?!?!?!
@SIam, you need to upgrade RRF and DWC to 3.4.0-b4.
@mfs12 for now, it's working but i have a new error for you
@siam, please check that all parameters are set in configure tab. I think you didn't set any axis to test.
BTW this is an known issue which I am trying to find a good solution.
@mfs12 reloading the DWC (F5) solved it
@mfs12 home device only if not homed seems not to work:
and here you can see that the machine always will be homed
@SIam, can you send me you browser dev tools console log?
this might be helpful. best would be to share it via pastebin.
@mfs12
here we go -
@SIam i am a little clueless. On my device it skips that stage. what happens when you hit the run button a second time?
@mfs12 said in InputShaping-Plugin-0.2.0-pre4 released:
The printer will be first homed every time i press the run button
@siam check your PM please.
@mfs12 now the homing is gone but i will get no output in the console when i start the test.
@siam try uninstalling the plugin and reinstalling it
please check the new release...
https://forum.duet3d.com/topic/25351/inputshaping-plugin-0-2-0-pre5-released/
