    Issues with mesh leveling.
    566
    • Col_Clucksundefined
      Col_Clucks
      A few months ago I watched CNC kitchen's video about putting a duet board in a prusa machine and decided to follow his guide. I have it up and running now and I have to say that its my favorite printer right now. It does have an issue however with mesh leveling.
      My height map shows that the difference between the highest point and the lowest point is .345 mm. Is the difference too much?
      I have it set up and it will probe 9 points on my bed and generate a height map, but it doesn't look like it's using it on the print. To test it out I printed little squares on top of my probe points. When printing the squares are too close, too far, and just perfect. It's also an exact match to the height map that G29 generates where the low points are too far and the high points are too close. I've added my start gcode so maybe yall can pick out something I am doing wrong. I am using G32 to level the X Gantry. I am using G29 S0 to run auto level and then right after it G29 S1 to apply it.
      G90 ; use absolute coordinates
      M83 ; extruder relative mode
      M140 S[first_layer_bed_temperature] ; set bed temp
      G28 ; home all axis
      M190 S[first_layer_bed_temperature] ; wait for bed temp
      M104 S[first_layer_temperature] ; set extruder temp
      G32 ; gantry leveling
      G29 S0 ; mesh bed leveling
      G29 S1 ; apply mesh
      M109 S[first_layer_temperature] ; wait for extruder temp
      G1 X10 Y-3.0 Z0.5 F6000.0 ; go outside print area
      G92 E0.0
      G1 X60.0 E9.0 F1000.0 ; intro line
      G1 X100.0 E12.5 F1000.0 ; intro line
      G92 E0.0
      M221 S{if layer_height<0.075}100{else}95{endif}
      • fcwiltundefined
        fcwilt @Col_Clucks
        @col_clucks
        Welcome to the wonderful world of Mesh Bed Compensation.
        Just a quick note: G29 S0 which creates the height map also applies the height map so you don't need to include the G29 S1 - it doesn't hurt, it's just redundant.
        Also it has been said on more than one occasion that after you use G32 to auto level the bed you should reset the Z=0 Datum in the center of the bed using a single G30.
        Other than that everything looks fine, code wise.
        Col_Clucksundefined 1 Reply Last reply Reply Quote 0
          Col_Clucks @fcwilt
          @fcwilt Would it be better to do this in firmware by adding that in my bed.g or in my start gcode? or if I add it to g32 is it going to try and include it in my gantry leveling? This has the center probe added in.
          ; bed.g
          ; generated by RepRapFirmware Configuration Tool v3.2.3 on Mon Mar 15 2021 19:09:36 GMT+0100 (Mitteleuropäische Normalzeit)
          M561                                                       ; Clear any existing bed transform.
          G28 ; home
          G1 Z220 F10000
          M558 F10000
          G30
          M558 F100 A5 S0.003
          G30 P0 X33 Y106 Z-99999 ; probe near a leadscrew, half way along Y axis
          G30 P1 X235 Y106 Z-99999 S2 ; probe near a leadscrew and calibrate 2 motors
          ;add here G30 X112 Y101
          M558 F200 A1
          G1 X10 Y210 Z10 F10000
          • fcwiltundefined
            fcwilt @Col_Clucks
            @col_clucks said in Issues with mesh leveling.:
            ; bed.g
            G28 ; home
            G1 Z220 F10000
            M558 F10000
            G30
            M558 F100 A5 S0.003
            M558 F200 A1
            I put the commands to set the Z=0 Datum in my bed.g file.
            But I don't understand your current bed.g file.
            There is this section - the G28 is fine but what is the intent of the next 3 commands?
            > G28 ; home
            > G1Z220 F10000
            > M558 F10000
            > G30
            There is this section - the G30s look fine but why the M558? Typically you set M558 once and use it for all probing procedures.
            M558 F100 A5 S0.003
            G30 P1 X235 Y106 Z-99999 S2 ; probe near a leadscrew and calibrate 2 motors```
            There is this section - you cannot probe a single point that way to set the Z=0 Datum. You have to use a G1 Xnnn Ynnn move to position the probe taking into account the probe X and Y offsets. Then you just do a plain G30.
            And at the end you once again use M558. Same observation as above applies.
            Hopefully you can clarify things for me.
            Thanks.
              Col_Clucks @fcwilt
              I should probably add comments to my code when I'm asking for help haha.
              @fcwilt said in Issues with mesh leveling.:
              @fcwilt
              > G28 ; home
              > G1Z220 F10000
              > M558 F10000
              > G30
              These commands run the gantry to the top and physically levels the gantry by hitting the top of my z axis. When the printer powers off the axis sags a bit and it want to get the gantry as close to level before I apply any correction. I changed the feed rate because the default rate was miserably slow to run all the way to the top and back down.
              M558 F100 A5 S0.003
              Here I am setting the feed rate to a lower speed for accuracy before I probe for gantry leveling.
              So this is how you would do it?
              G1 X112 Y101;
              G30;
              The last step is to move my print head to the park position. i am just changing the feed rate to make the move faster as I am impatient.
              fcwiltundefined engikeneerundefined 2 Replies Last reply Reply Quote 0
              • fcwiltundefined
                fcwilt @Col_Clucks
                @col_clucks
                So after the G1 Z220 F1000 the G30 is going back toward Z0 to probe the bed?
                Are you aware with firmware 3.3 and later in the M558 you can do F10000:100 and obtain two feed rates automatically?
                From the docs:
                From RRF 3.3 you can provide two F parameters instead of one, where the second is lower than the first, for example F1000:500. When doing a plain G30 command, an additional probe will be done using the first speed to establish the approximate bed position, before one or more additional probes are done using the second speed. The first speed will not be used when probing at a defined point or when mesh bed probing.
                In theory that would do what you want without having to change it with separate M558 commands.
                You may want to try it and see if it works to your satisfaction.
                You have the correct idea for setting the Z=0 Datum with the G1 move and then the G30.
                But I don't know what your probe X and Y offsets are so I cannot confirm the G1 X and Y values are going to move the probe to the center of you bed.
                As to the last M558 changing the feed rate - since it is not followed by a probing command what is it going to affect?
                Thanks for taking the time to help me understand what everything was doing.
                Much appreciated.
                Col_Clucksundefined 1 Reply Last reply Reply Quote 1
                • engikeneerundefined
                  engikeneer @Col_Clucks
                   G28 ; home
                   G1 Z220 F10000
                   M558 F10000
                   G30
                  Why not just do this?
                   G28 ; home
                   G1 Z220 F10000 ;go up to level against the frame
                   G1 Z10 ; Note, the feedrate is stil F10000
                   G30
                  Saves having to redefine your probe speeds etc 🙂
                  i3 clone with a bunch of mods
                    Col_Clucks @fcwilt
                    @fcwilt The point I put is correct for the G30 but even after doing that it still isn't using the mesh.
                      Col_Clucks @engikeneer
                      @engikeneer The bed.g works just fine as is. I still need help getting the printer to apply them mesh though.
                      • fcwiltundefined
                        fcwilt @Col_Clucks
                        Well perhaps something that happens after you enable the mesh with the G29 S0 G29 S1 is disabling it again.
                        Something in the slicer start code maybe?
                          Col_Clucks @fcwilt
                          @fcwilt so I took that out and it is changing the z height now so great success there. However it doesn’t seem like it is correcting enough. That may be an issue with the pinda 2 I’m using so I’ll start looking there
                          • fcwiltundefined
                            fcwilt @Col_Clucks
                            It sometimes seems to be that mesh bed compensation is changing Z enough - though I can see the Z steppers moving tiny amounts.
                            Perhaps it is a speed issue and that some setting is preventing the Z steppers from changing fast enough to be at the correct height where the actual filament is being laid down?
                            I have no idea.
                            • Trafimundefined Trafim referenced this topic
