    All Axes will Home but have not Connected Any Endstops?
    897
    • T3P3Tonyundefined
      T3P3Tony administrators @Pickett
      @pickett I suspect you may have the endstops wired as normally open, not normally closed. As @cosmowave mentions you can change the firmware to work with that, however there are good reasons to normally use normally closed endstops.
      www.duet3d.com
      • cosmowaveundefined
        cosmowave @Pickett
        @pickett If you'd like to change your endstops to normally closed endstops (safer in case of wire failure), you have to wire them to "label" 1 and 3 on the endstops.
        But then, i think you should invert the function again with deleting the "!" in config.g
        Mankati FSXT+, DeltaTowerV2, E3D MS/TC
        • Pickettundefined
          Pickett @cosmowave
          @cosmowave ok now the axis move but are going in the opposite direction so I guess I need to reconfigure my stepper motor direction of rotation in the configurator tool? Also the stepper motors seems to be vibrating really loud now like it is some sort of wiring issue but it is wired correctly i know this cause Im the one whom crimped the terminals, got the Black, Green, Blue, Red order. the Z properly homes cause well it just detracts then it dives --------------------000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000=============================================================================================9999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999999slowly down til it reaches the bed............. Ok will take a break from this for now coz I keep falling asleep onto my keyboard lolz will return for more troubleshooting techniques and what not!!!!! Thanks for everyones help this far will get it figured out one way or another!!!!!!!0000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000r
          cosmowaveundefined T3P3Tonyundefined 2 Replies Last reply Reply Quote 0
            cosmowave @Pickett
            @pickett said in All Axes will Home but have not Connected Any Endstops?:
            Yes correct. You can change direction in config.g. Change S0 to S1
            M569 P0.0 S0 ; physical drive 0.0 goes backwards
            change to
            M569 P0.0 S1 ; physical drive 0.0 goes backwards
            you have to edit the correct axle! I don't know if x or y should be inverted!
            • T3P3Tonyundefined
              @pickett locking this as you have started a new thread about the issue:
              https://forum.duet3d.com/topic/25464/x-y-not-homing-z-is-a-bl-touch-it-is-homing/3
              www.duet3d.com
