    Duet2/RRFW 3.3 -estop'd it Now dead PanelDue7 connecting
    Using Duet Controllers
    524
    • T3P3Tonyundefined
      T3P3Tony administrators @SputnikOC3d
      This post is deleted!
      • SputnikOC3dundefined
        SputnikOC3d
        @T3P3Tony / @Phaedrux - any chance someone could look this over real quick and at least tell me where to look to get the dwc installed on my sd card - so I might begin to try and configure a new sd card.
        My other related post to this machines issues has now gone 5 days now - with zero reply. Ive done my fair share of google and forum thread searching for the answers as well.
        SIamundefined 1 Reply Last reply Reply Quote 0
        • SIamundefined
          SIam @SputnikOC3d
          @sputnikoc3d Have you tried to read the SD-Card with your PC ? If yes can you see the files on it?
          I would make first a new SD-Card, maybe your old one have a defect. Here you can find how you can set up a new SD-Card https://duet3d.dozuki.com/Wiki/SD_Card#Section_Creating_the_file_structure
          Hypercube-Evolution-Hybrid, Piezo Orion, Orbiter
          Duet WiFi 1.02 or later + DueX5
          RepRapFirmware for Duet 2 WiFi/Ethernet 3.4.0beta4 (2021-09-27 11:30:36)
          Duet WiFi Server: 1.26
          Duet Web Control 3.4.0beta4 (2021-09-27)
          SputnikOC3dundefined 2 Replies Last reply Reply Quote 0
            SputnikOC3d @SIam
            @siam - Thank You.
            I did try and read the old factory supplied 8 GB SD card. Windows 10 in a pc card reader - tells me its unreadable or unformatted.
            In the 20 some -odd searches I did on the doczuki till 2 am, for stuff like the link you sent I got nothing remotely close to that url - guide - Uggghhhh ... Guess I was getting referenced to the pages that help you fix or update an existing working and previously formatted SD Card. Didnt see links from those to the one you posted which might be smart for future reference and ... it might be wise to have someone review the texts above and massage that language a bit to make it like crystal clear for people. When following docs in unknown territory - people tend to NOT make assumptions and read docs and take them very literally - and dont imply or impune guesswork in the process. That said these docs should leave no room misunderstanding.
            As well as indicate where and how to get all needed file to operate the machine onto the sd card
            DWC included.
            Guess I get to start all over fresh from scratch. FUN.
              SputnikOC3d @SIam
              @siam - another thing ... The RED LED for Diag mode is still on after several reboots and or attempts at removing the sd card and pressing the reset button.
              My machines last moves were to home z with the bl touch pin out and down and I estopped it ...
              Maybe its in diag mode as it finds no confi.g et al ...
              • SIamundefined
                SIam @SputnikOC3d
                @sputnikoc3d
                It seems to me that you have pressed the erase button on your duet, in this case you should follow this docu to fix this issue
                When the LED for Diag is lit, then is the duet board in program mode
                https://duet3d.dozuki.com/Wiki/Installing_and_Updating_Firmware#Section_Fallback_procedure_Num_2~~
                SputnikOC3dundefined 1 Reply Last reply Reply Quote 0
                  SputnikOC3d @SIam
                  @siam - pretty sure mine has a soft reset button and the erase is a jumper - no ?
                  • SIamundefined
                    SIam @SputnikOC3d
                    @sputnikoc3d forget my last posting the firmware seems to run, so it will be make sense to create a new SD-Card
                    • NightLonk42undefined
                      NightLonk42
                      Any chance this is a RatRig build?
                        SputnikOC3d @NightLonk42
                        @nightlonk42 - No Caribou / Zaribo bedslinger
